TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: RetroTexan on August 06, 2023, 05:12:46 PM
Title: Stranded (Fuel Pump shutoff from overheating?)
Post by: RetroTexan on August 06, 2023, 05:12:46 PM
Decided to push it a little too far this morning (but it’s just so much fun to ride!)
Acewell 4553 connected to BEP 3.0
Tach-ok
Speedo-ok
Batt-ok
Temp-only shows -L-•F (instructions say it should read a temp after it has warmed up but no-go)
Fan never kicked on. Then as I was pulling out after grabbing a water, the fuel pump stopped whining and the bike died. Every time I tried the starter, the pump did not kick on like it normally does. Left it to cool down, still no fuel pump. Checked the connections and fuses. Everything else powers on and wants to work, injectors still clicking, starter is ok, etc.
It has sat for over 8 years with no fluids. Could the temp sensors be to blame? Do they ‘go bad’ if they’re left dry for too long? I’m stumped on next steps to take for diagnostics.
It has 2 temp sensors but I only hooked up the one from the standpipe. The one underneath on the pump is left disconnected. I tried switching them but still no-go.
Any help would be greatly appreciated, I’m already addicted to it and need my next fix 🤣
Title: Re: Stranded (Fuel Pump shutoff from overheating?)
Post by: frankenduck on August 06, 2023, 05:52:32 PM
Fuel tank connector or ignition switch are common for causing this type of problem
Post by: RetroTexan on August 07, 2023, 10:57:26 PM
Well, I did like you said and replaced the fuel tank connection. As I was going through the ignition switch connector I realized I didn’t have another 4 pin connector to replace it but everything has strong continuity. Tried to start it again and again strong starter, lights, horn, turn signals, etc but now instead of no noise from the fuel pump I heard a click.  I went ahead and applied voltage to the brown and green/white leads at the fuel tank connector and heard the same click but the pump did not hum.
I took the fuel pump out and applied current directly to the leads, just the same click. Did a bit of percussive maintenance with a rubber mallet but still doesn’t want to budge. Everything in the tank is new but when I look at the pump strainer I see a hole in it.
My guess at this point is that little flap of filter material from the strainer got sucked into the pump and gunked it up real good. I DO NOT want to pay another $180 for another new pump. Anyone know if there’s a good resource on fuel pump disassembly before I go about it blindly on my own?
Post by: Martin on August 08, 2023, 03:19:57 AM
If it is jammed try briefly alternating the polarity back and forth. Doing this sometimes frees them up. If this doesn't work try soaking the pump in vinegar for a few days to a week then apply power and briefly alternate the polarity. I've been running a Chinese pump since 2017 with no problems see link. http://www.motobrick.com/index.php?topic=10054.msg85798;topicseen#msg85798
Post by: RetroTexan on August 08, 2023, 12:18:23 PM
While I was applying voltage directly to the pump leads I alternated the polarity a few times, still just a click in either direction. Until I crack it open later today I won't know for sure but I'm fairly sure that little piece of filter material was sucked up and is causing the issue. I'm not sure vinegar is going to be strong enough to dissolve material that spends its life inside a gasoline tank. But I do appreciate the reply.
Will report back with my findings.
I'm not able to find any information about pump disassembly so I may just go ahead and document the process and write up a post about my discoveries. Oh, and I paid $360 for this pump back in 2016 from Beemerboneyard brand new OEM. It sat in the freshly cleaned and dry fuel tank for the past 7 years so I'm determined to solve the issue of this pump rather than buying aftermarket. At that price, this thing just HAS to be of higher quality and repairability, right? RIGHT?! Please someone tell me I'm right :cry:
Edit: I did find this great close-up video of a pump disassembly, it's different than the OEM pump I have but I'm hoping it will be similar enough to get me going. Link to the video in case others may find it helpful.
https://www.youtube.com/watch?v=i9fz0uBJmPw (https://www.youtube.com/watch?v=i9fz0uBJmPw)
Post by: The Mighty Gryphon on August 08, 2023, 01:14:33 PM
Wow, that hole in the screen looks so nice and square.
Post by: RetroTexan on August 08, 2023, 01:21:27 PM
Yeah, it's weird for sure. 2 of the edges look melted and the other 2 look ripped. I checked and couldn't find anything in the tank other than fuel. I'm guessing I accidentally ripped it when I was installing the pump years back and it just needed an excuse to come loose. The melted edges have me stumped, though.
Post by: frankenduck on August 08, 2023, 07:32:17 PM
Here's how the early K fuel pump can be serviced:
http://www.dws.epizy.com/ktech/K%20Fuel%20Pump%20Repair.pdf
Post by: RetroTexan on August 22, 2023, 02:27:11 PM
In the wise words of a dumb man, “Well there’s your problem right there…”
Looks like a small chunk of the original blue paint somehow made its way into the tank, past the hole in the filter, and lodged itself in the fuel pump. One more problem solved, now time to jb weld the filter hole, put it all back together, and see if it runs again
Post by: The Mighty Gryphon on August 22, 2023, 07:03:43 PM
Wow, it doesn't take much, does it?
Post by: RetroTexan on August 23, 2023, 05:33:19 AM
Surprisingly little, the price we pay for precision. Also, it’s a good lesson for the importance of that pump filter. I sealed up the hole using JB Weld and some mesh filament.
This turned out to be a blessing in disguise since it brought to my attention yet another tank leak. Has anyone had any luck with tank sealants with our aluminum tanks?
Post by: Duckbubbles on August 23, 2023, 09:52:31 AM
I used a product called Kream (maybe Kreem) several years ago to seal a hole in the bottom of my '85 K100RS tank.  Covered the hole with some foil tape from the outside and filled the seam of the welds at the bottom.  Maybe 1/4 inch thick down there.  Like I said, it's been years with no ill effects.  It might be hard to find.  I got mine the Honda shop in San Marcos.
Frank
Post by: The Mighty Gryphon on August 23, 2023, 10:43:05 AM
Is this the stuff you used?
https://www.kreem.com/fueltankliner.html
* Kreem.jpg (14.94 kB . 232x306 - viewed 831 times)
You can get it on eBay.
Post by: Duckbubbles on August 23, 2023, 12:18:53 PM
Exactly that!  Used it maybe 40 years ago on a Kawasaki steel gas tank and a few years ago on my K-bike.  Make sure the tank is empty and absolutely dry inside.  I removed all the fuel pump hardware and electrical wiring.  Just used it on the bottom as the rest of the tank was very clean.
BTW- since you are in there, I would replace the screen as it's available from Euromotoelectrics.com.  No telling how the fuel will react with your fix.
Frank
Post by: Duckbubbles on August 23, 2023, 12:51:27 PM
P.S.- The website suggests you use part A first.  I would not use the part that etches the metal, that is intended to use on steel and no telling what it would do to the aluminum.  I just used the white Kreem by itself.
Frank
Post by: RetroTexan on August 23, 2023, 01:08:16 PM
Hey that's exactly the kind of thing I was asking about! I've been looking for a more purpose built product than JB Weld for fuel tanks. Thanks for the suggestion.
I just shoved my phone inside the pump reservoir and noticed there is still some buildup that I could not see or reach before so I've ordered a cheapo endoscope off Amazon (yay same day shipping) and will get at the rest with some old dental tools when it arrives. I’ll order some of that tank treatment and give it a try
Post by: RetroTexan on August 28, 2023, 11:01:16 PM
It runs! I found a new connector for the ignition switch and switched it out, reinstalled the serviced fuel pump, and everything worked enough to go around the neighborhood a few times. Still no fan though.
I put alligator clips on the fan connector and ran voltage through them, the fan turns on and runs when voltage is directly applied. But after a 15-20 min ride the fan still won’t kick on and the temp on the Acewell still reads -L-•F
Am I supposed to set the Acewell for a certain temp before it reads? Does it control the fan? What’s the risk of running a k bike without a fan in the short term?
Post by: Laitch on August 29, 2023, 09:16:32 AM
The fan won't operate until engine temperature triggers it to operate. Riding around the block a few times won't do it, even in Texas.  :laughing1: If you let it idle, it should start up in 15 minutes or so, especially in Texas.  :laughing4-giggles: Be aware the temperature bulb lighting indicates Overheating. The fan running just means the temperature is being controlled so it doesn't overheat.
The fan responds to inputs from the temperature sensing relay that the relay receives from the coolant temperature sensor, if there has been no interference with circuit. The relay, the coolant temperature sensor and the fan all need to function for the system to operate. The Acewell doesn't govern that process; it only indicates the coolant temperature.
There are threads galore here about Acewell struggles and management. No doubt somebody with experience is likely to come along.
Post by: Duckbubbles on August 29, 2023, 10:29:49 AM
The temp sensing module in the electrical box provides a ground to the fan.  On my '85 RS I provided a separate ground through a rocker switch so I can turn on the fan when I want to- like when I know I will be sitting/going slow for a while.  If I turn it on soon enough the temperature stays constant, even in traffic.  I installed an Autometer direct reading (not electrical) gauge about 100 years ago so I know the temp at any given moment.
Frank
Post by: Laitch on August 29, 2023, 10:36:32 AM
I installed an Autometer direct reading (not electrical) gauge about 100 years ago . . ..
Maybe you have some daguerreotypes you could copy and post of your Autometer in its location, Frank? That could be helpful.
Post by: RetroTexan on August 29, 2023, 10:52:02 AM
Ok thanks Laitch, that answers a question I've had about if I'm using the correct temp sensor which you've confirmed that I am (mine was the RT model and so it had a temp sensor at the coolant stand pipe on top of the engine that I have connected to the BEP 3.0 and an additional temp sensor on the bottom of the engine near the pump that I've left disconnected)
My initial ride on Aug 6 was what originally prompted concern that my issue may be fan related, which lead me to believe the pump failure was due to overheating. That was a ride that lasted about an hour at 10am in Central Texas, so about 90-95 degrees Fahrenheit. I assumed it would have kicked on before then.
Based on what I'm gathering from other threads, is my next step in diagnosis to check the resistance of the pins in the Jetronic connector? Not sure what comes next after changing the fuel tank and ignition switch connectors like frankenduck had mentioned (unless he meant replace the entire ignition switch, key and all).
Post by: Laitch on August 29, 2023, 11:10:49 AM
Remember that the temperature switch in the pump serves an entirely different function—it operates a temperature gauge readout.  There has been confusion around here about the pin numbering sequence in the Jetronic plug. The sequence is in the attached diagram.
Post by: Laitch on August 29, 2023, 11:16:14 AM
. . . that answers a question I've had about if I'm using the correct temp sensor which you've confirmed that I am (mine was the RT model and so it had a temp sensor at the coolant stand pipe on top of the engine
All classic Bricks regardless of model have the coolant temperature sensor in that standpipe next to the radiator. If the system is functioning correctly, the fan will start at idle as I indicated. Start it up and have an iced tea while you wait.  :laughing4-giggles:
Post by: RetroTexan on August 29, 2023, 11:31:10 AM
That's what I'm saying: I've let it idle, I've ridden it for 20+ minutes around the area, and still no fan.
At this junction, I'm assuming there is an issue that's causing the fan not to kick on (either a faulty temp sensor, connection, or something else but I know the fan at least works when voltage is applied). I'm asking for recommendations for next steps in the diagnostics. I've already replaced the connectors, I've searched the forums, and the only other thing I know to do is to check the Jetronic pins (which I'm still researching how to do if anyone has tips and tricks)
Post by: Laitch on August 29, 2023, 11:58:47 AM
There are no tricks to checking the sensor via the Jetronic pins, although you could perform it doing a handstand if you want to create a challenge for others.  :johnny
A multimeter is used. There is a fairly active thread about the self-generated travails a member here went through doing that. You must have missed that and you probably should continue missing it for your own benefit. :laughing4-giggles: You have a cold engine reading and an operating temperature reading. They are 2.5KΩ@20ºC(68ºF) and 300Ω@60ºC(140ºF). The fan starts at 103ºC(217ºF). Pin #13 is ground; pin #10 is the sensor. Those are where you connect your multimeter leads to take the reading. If they are ambiguous, the sensor can be removed for a cold-to-hot water test.
Post by: RetroTexan on August 29, 2023, 01:24:33 PM
Yeah, I read through that thread which is what made me believe checking the pins was the next step in diagnosis.
Post by: RetroTexan on August 30, 2023, 10:40:31 AM
Ok, well I set the Acewell to 185F thinking it would start warning me well before the fan is supposed to kick on. I rode it around the area (feeder road speeds) for a little over 45 minutes. The warning light never came on and neither did the fan. As I was putting it into the garage, I noticed quite a bit of black smoke coming from the exhaust when it was on the side stand. It's running very rich. Which also leads me to believe that it's running much cooler than normal thus not getting hot enough for anything to be happening.
I hit the engine with an infrared thermometer and it only read 165F, which seems very cool for being ran at 50+ mph for almost an hour.
I'm very confused at this point. I'm guessing now there is some issue with the injectors adding too much fuel. These are the upgraded injectors from an M3 with the 4 holes instead of OEM 1-hole injectors. Anyone else with upgraded injectors getting black smoke and very low running temp?
Post by: Laitch on August 30, 2023, 10:52:42 AM
You haven't indicated the results of your sensor test. What were they?
Post by: RetroTexan on August 30, 2023, 11:10:37 AM
I haven't proceeded with diagnosing the sensor issue yet. This issue supersedes the temp sensor. It's going back to the fuel delivery, hence it takes priority over the fan issue I was asking about yesterday.
One problem at a time... and right now it looks like I still have a fuel delivery issue. Do you have experience with black smoke issues?
Post by: Laitch on August 30, 2023, 11:41:00 AM
Is your engine a 2-valve or a 4-valve model?
Post by: RetroTexan on August 30, 2023, 11:55:23 AM
It's a 2-valve model
Post by: Laitch on August 30, 2023, 11:58:48 AM
Put that information in your signature right now so it will show up with every post. The 4-valves operate somewhat differently.
Post by: RetroTexan on August 30, 2023, 12:18:49 PM
Well mine is a 2-valve so if anyone has insight into the diagnostic process after a fuel pump rebuild that would result in black smoke, I'm all ears
Post by: Laitch on August 30, 2023, 12:22:15 PM
You were guided to test the coolant temperature sensor because it plays a role in the timing of fuel injection. A cold engine needs more fuel than a warmed engine. If the sensor sends a signal that the engine is cool when it is actually warm, the injectors will overfuel it. If it sends a signal that the engine is warmed when it's actually cold, it will be hard to start.
So the engine can start great in the morning and wind up blowing coal in the garage when you're finished.
 (https://www.motobrick.com/gallery/4/1601-300823120522.png)
The air flow meter is another essential ingredient in correct fueling. It also houses a critical component—the air temperature sensor. If these items were mishandled during the hacking of the Brick into a scramble, they, too, could be involved in this malfunction. If the temperature sensing switch has gone cactus—as is said in Australia but I don't know if that's said in Texas and I doubt it because fecked or one of its other permutations is probably used—a malfunction there would have multiple effects.
Diagnosis is an orderly process of elimination. Checking the sensor in an overfueling or hard-starting engine is part of the process and a simple one.
Post by: RetroTexan on August 30, 2023, 06:27:56 PM
I'm looking at 1.7kΩ @ 89.5°F and 232Ω @ 174.5°F after 20 minutes of idling on the stand. Slight hiccups around the 15 minute mark, when revved it billowed a big black cloud of smoke but did not produce more billows on subsequent revs until I let it idle again for another 5 minutes, then another big black cloud.
Post by: Laitch on August 31, 2023, 08:19:48 AM
After reviewing your odyssey, including the news that your coolant temperature sensor reading is okay, in conjunction with the rain here ending this morning, along with the fact that this smoke seemed to be a new occurrence and the fuel pump has been disassembled and reassembled previous to its appearance, you might want to consider checking fuel delivery pressure at the rail—a straight forward and relatively uncomplicated procedure. Fuel delivery over-pressure and/or one or more injectors stuck open could cause the smoke you describe.
Verify the air flow meter's wiring plug contacts are clean and its connection is tight.
Post by: RetroTexan on September 27, 2023, 06:25:57 PM
In case anyone in the future has an issue with black smoke, poor gas mileage (18mpg), and the radiator fan not kicking on here is my update:
It was 100% the 'upgraded' fuel injectors I had installed from the M-series cars. The extra injector atomizing holes (4-hole) were spitting too much fuel into the engine and instead of the Jetronic picking up on this and adjusting the fuel delivery it was just coming out the exhaust as unspent fuel (aka black smoke)
I found the old 1-hole injectors that come standard with the bike and the smoke turned from black to white (which is normal for k-bikes). Also, since the engine is burning the fuel completely, the engine is able to heat up to temperature and the fan kicks on as normal now.
Hope this might be of some use to someone in the future!
Post by: Laitch on September 27, 2023, 06:45:37 PM
That "upgrade" didn't seem to be mentioned in your Brick's history, Tex. This discovery of yours is a reminder for all of us to ask about injector swaps when fueling problems seem to be happening. Thanks for the update.
Post by: Martin on September 27, 2023, 07:11:50 PM
A mate of mines son was an injector specialist. After looking at a cutaway view of the K's engine he said stick to the 1 hole injector. The 1 hole injector is designed to spray onto the back of the inlet valve cooling it. It also breaks up the spray allowing it to atomise. The 4 hole injectors will not give you more performance but will increase your fuel consumption. If the 4 hole injector is so superior to the one hole injector why hasn't the companies selling the 4 hole injectors done a dyno comparison.
* Cutaway K Engine Injector angle .jpg.png (59.96 kB . 768x568 - viewed 670 times)
Post by: frankenduck on September 27, 2023, 08:02:30 PM
Yeah, the 4 hole injectors are really popular with the Jeep crowd for some reason. Yet I've never been able to find anyone running actual dyno runs that show any real performance improvement.
JMHO: I'm not a fuel injection expert but the FIs spray fuel onto the back of a hot intake valve which should cause the fuel to mist well just from the heat.
Post by: RetroTexan on September 28, 2023, 09:19:33 AM
@Laitch: yes I did mention them. You were focused on the results of my sensor while I was still focused on the fuel delivery issue. This can be a reminder that there are plenty of incorrect suggestions and advice out there about these bikes.
The 4 hole injectors will not give you more performance but will reduce your fuel consumption.
@Martin: I can report that I had the opposite occur. My fuel consumption INCREASED dramatically and I was only getting 18 mpg with the 4-hole injectors, instead of the 55+ mpg that some riders have reported with the stock injectors. The bike also ran like crud with much higher and very noticeable vibration. Not to mention the black smoke that originally lead me to believe something was wrong.
That edited cutaway you posted is a great visual, thanks for posting it! It looks like the 1-hole injector is able to shoot fuel directly at the back of the valve to help atomize it like Frankenduck mentioned. When I performed my bench tests on the injectors, the 1-hole shot straight out, parallel with the injector itself. But the 4-hole had a spray pattern that was angled outward like a radial crown which leads me to believe, based on that cutaway you provided, that the 4-hole was spraying into the air intake chamber instead of directly onto the hot valve as designed which lead to the poor combustion.
When building the bike, I shouldn't have tried to upgrade anything before getting it up and running. Moral of the story, and say it with me kids: "Don't believe everything you read online.”
Post by: Laitch on September 28, 2023, 11:03:14 AM
@frankenduck:That image you posted is a great visual, thanks for posting it! I
I finally found that reference, Tex. It should have penetrated my concentration. Most disappointments with them involved lackluster performance "improvement" and slight increased fuel consumption.
The helpful cutaway diagram posted by frankenduck is one of a series of excellent Brick engine system images provided by BMW in its 1988 K100/K75 Repair Manual that has been available for download by members of this site for years.
Your observation of getting the engine running before trying to modify it should be taken onboard by other aspiring customizers.
Your persistence has paid off! I hope you will post more photos as you complete this project.
Post by: Martin on September 28, 2023, 03:03:40 PM
Retro I had a typo, dyslexic fingers it was supposed to be increased fuel consumption. A lot of the bum dyno reports of increased performance when fitting the 4 hole injectors can be put down the fact that the 1 hole injectors were blocked or faulty. I had a feelable increase in performance when I finally got my injectors clean after doing them myself. The first two attempts by a local shop were only partially successful. I ended up having to use thinners in my wife's ultrasonic jewelry cleaner with the injectors connected to a pulser multiple times before I got the correct spray pattern. Unfortunately the lid on her jewelry cleaner sort of melted in the process. I upgraded to a 10lt stainless steel one.
Post by: RetroTexan on September 28, 2023, 03:49:12 PM
Honestly, what other explanation is there?! From this experience, I can't possibly understand how anyone would find benefit in running 4-hole injectors on these bikes.
The difference is night and day: my bike just runs so much better with the stock 1-hole injectors! No more black smoke, much less vibration, MUCH better fuel economy, the fan now kicks on properly at temp, no more bogging down on hard throttle at stops.
The only "negative" difference I've found so far is it back fires a bit when twisting the throttle after deceleration while in gear which I'm pretty sure is a result of my after-market exhaust anyways. And I put that in quotation because honestly, it just sounds badass to me
Post by: frankenduck on September 28, 2023, 04:32:16 PM
What's the Bosch number of the FIs?
I think the best 4 holes for Ks are 0280150415
Post by: Martin on September 28, 2023, 06:10:12 PM
The best 4 hole injectors for a K bike are the 1 hole injectors. Also as TMG pointed out the 4 hole type will be more prone to blocking.
