TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: makjoh on June 16, 2023, 02:11:52 PM
Title: K1100 lt fuel tank Rubber seal
Post by: makjoh on June 16, 2023, 02:11:52 PM
I've installed a new fuel pump and filter and cleaned up the tank and fuel sensor gauge. Putting everything back I have a leak from the underside of the tank where the 4 screws secure the fuel sender base unit to the tank. Taking off off again I see the new  rubber o ring is intact, but there is a square indentation for another seal?? There wasn't any seal there when I took the unit apart and I cant find any replacement or info on a seal that is square in shape and fits in there?? Its a 1997 BMW K1100 LT.
 Any advice gratefully received.
Thanks brickers 112350
Title: Re: K1100 lt fuel tank Rubber seal
Post by: Laitch on June 16, 2023, 07:05:54 PM
There is only an o-ring used for sealing. If an o-ring of the correct size was used, if the o-ring didn't shift out of position as the sender was installed, and if the cover screws were tightened securely without stripping them, then there should be no leakage.
Post by: makjoh on June 17, 2023, 04:13:24 AM
Many thanks for confirming this Laitch. I have re-examined and will install another new o ring. I can see now when turning the tank upside down that there is a little indentation to accept the O ring. I must have over shot this when I put the base plate back
