TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: rocketbrick on June 15, 2023, 05:19:33 PM
Hey y'all,
I got two saddlebags with my K75 I bought last month. They have all the locks tumblers in tact, but never came with a key. I tried to lockpick them, and even took them to a professional lockpick to get a new key cut, or at least get them opened. No dice.
Any solution on where I can get a new key cut for them and get them open?
You need to find a competent locksmith. K bike lock cores are pretty darned simple.
If you're going to a locksmith that can't pick the lock, get a lock core out and make a key then you're not dealing with somebody who is even remotely competent as a "locksmith."
Here's how simple it is:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/rekey/rekey.htm
I think this guy (me) might be able to help you if you send him one of your latches:
http://www.kbikeparts.com/otherstuff/lostkey/lostkey.htm
If the latches are locked, you can still remove them without getting all hairy-chested about it. Flip the cases over. The case hinges are two-piece. You can slide them off ends in each direction then lift the lid off the case body, flip it over, grind off the latch rivets, lift the latch assembly off the case and BINGO, its ready to mail to the maven of K-landia. :laughing4-giggles:
You need to be careful grinding or drilling off the ends of the rivets though. If you generate too much heat in the process then it melts the plastic around the holes where they mount. Water is your friend.
