TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: ackgs on February 18, 2023, 01:31:03 PM
Title: Need help identifying a part.
Post by: ackgs on February 18, 2023, 01:31:03 PM
Had some work done on my '91 K 75S at a shop they replaced my transmission. Picked up the bike yesterday and I seem to be missing a piece and I can't find in the parts fiche. I'm seeing a lot more of the back of the battery than previously. The piece would be located to the rear of the battery and mounts at the bottom on two roll pins and bushings on the top of the rear of the transmission and extends up past the rear of the battery. Not sure where the top attaches perhaps with the front mount of the rear mudguard. In short it would be "the front extension of the rear mudguard".  I can see it is pictures of K 75 but can't locate it in the fiche. It was there before the work was done. Sorry this is cryptic but I could certainly use a little help. I'll call the shop Monday but if I knew what the name of the part is it would help. Thanks in advance.
Sorry no idea why my pictures are sideways.
Title: Re: Need help identifying a part.
Post by: frankenduck on February 18, 2023, 01:43:05 PM
From the factory there is no front extension of the rear mudguard on K75s.  Only the 4 valve K bikes have that.
Post by: ackgs on February 18, 2023, 02:16:59 PM
Thanks for the reply. I wish I had taken a picture because when I was painting the replacement transmission I noted one of two roll pins was missing and I looked at the bike to see what mounted there and swear there was a piece mounted to it. Curious there is no mud over that area and on the back of the battery like the top of the rear mudguard.
Oh well another mystery. I'll have to find another K to look at.
Post by: frankenduck on February 18, 2023, 02:55:33 PM
Each of those roll pins at the top rear of the transmission has a rubber bushing on it. Part 46621450473
They go into the little indents in the front lip of the rear mudguard.
I wouldn't lose any sleep if one of  those roll pins is missing but you can buy one. Part 07119941381
https://shop.maxbmw.com/fiche/PartsSearch.aspx?&searchtype=undefined&parts=07119941381%0A46621450473
Post by: Martin on February 18, 2023, 03:07:04 PM
It's called a Mudguard rear or sometimes rear wheel cover part #46621450471.
Post by: ackgs on February 18, 2023, 03:19:40 PM
The curved mudguard part right behind the battery is what I think I'm missing.  Thanks again Frankenduck I know the roll pins are not an issue my old transmission has the pins and bushing in there I can use those. The  existing mudguard does not extend down behind the battery it stops at the bracket under the front end of the seat.
Martin Thanks I'm going out to take yet another look at the bike.
The picture of the red bike is not mine just one I just grabbed off the internet because it showed thew mudguard clearly.
Post by: ackgs on February 18, 2023, 03:34:29 PM
OK I think I figured it out. Thinking the rear mudguard is installed backwards. If so I hope they didn't cut it off to make it fit. The lip at the back is supposed to go on the transmission.  Please take a look at the picture and tell me what you think.
Post by: frankenduck on February 18, 2023, 03:34:54 PM
Here's what the mudguard should look like:
(https://i.ebayimg.com/images/g/Z7sAAOSwMwBihIax/s-l1600.jpg)
Post by: ackgs on February 18, 2023, 03:44:46 PM
Frankenduck - Your picture really helps it's much better than the drawings on the fiche! That is what mine looks like - only the lip is on the back of the bike presently and should be on the rear of the transmission. I may order one as they are pretty inexpensive and I won't know if the mudguard is pressed out of shape until I remove it.
Post by: The Mighty Gryphon on February 18, 2023, 03:52:17 PM
That piece hanging off the rear mudguard below the license plate is the piece you are missing behind the battery.
The mechanic who worked on your bike is a flaming idiot.  I would be afraid to ride your bike after he worked on it.  Take some time and check as much of what he worked on as possible.
This is why so many of us work on our own bikes.
Post by: frankenduck on February 18, 2023, 04:05:19 PM
Um, yeah. Somebody who can't figure out which way the mudguard goes probably isn't the sharpest tool in the shed.
Post by: ackgs on February 18, 2023, 04:45:53 PM
Actually I do work on the bike. Picked it up as a nonrunner and brought it back. It was low mileage and always stored inside so good raw material. I rode it for a few years then it developed a transmission leak. I really did not have time nor skills for that. That work process has also been troublesome but hopefully I am by that. That took the last three riding seasons to get through so I've only ridden the bike a little during that period. With the lack of riding things don't jump out at me as would if I had been riding at my usual frequency. The fact that I could see a lot more battery and innards under there did strike me as not normal. Just took a few hours help to figure it out with everybody's help. Haven't had the bike out yet but did do some looking around today and when I swap the mudguard around I'll do some more checking.
Post by: ackgs on February 18, 2023, 05:07:01 PM
Hey it must be in there correct it bolted right up  :idunno: My lawn mower never comes back assembled correctly from the shop. Everybody has a phone with a camera in their pocket take freaking pictures before one begins, I do it all the time.
Post by: ackgs on February 19, 2023, 04:15:07 PM
Well I was able to get out on the bike today after some checking fastners etc. Except for the reversed mudguard so far so good. Rebuilt transmission functions well and shifts smoothly. I'll fix the mudguard  then put some miles on and then figure out the next move.
Thanks for your replies
