TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Tcapling on February 14, 2023, 09:00:15 PM
Title: Start in neutral
Post by: Tcapling on February 14, 2023, 09:00:15 PM
Hey folks.
Have s 90 k100rs
It's very not stock.
But my question is are they supposed to start in neutral with out pulling the clutch? Because all I get is a N light going off when I push the button unless I pull in the clutch.
Title: Re: Start in neutral
Post by: Laitch on February 14, 2023, 09:31:54 PM
Yes. A Brick should start in Neutral without the clutch hand lever being squeezed, and the neutral light should remain On. It seems than many aftermarket instruments will not provide that function unless modifications are made.
What are the modifications, especially the speedo/tacho array?
Post by: Tcapling on February 14, 2023, 09:38:22 PM
Speedo unit and wiring is all factory at this time.
Engine is the modified bit - but all of nits wiring has been integrated to the bmw harness.
When I use the button to start it it turns over slower than it does if I jump the solenoid trigger wire direct. (With clutch pulled) I found damaged wiring it the clutch portion that has solved the slow turning. But it still won't turn with just the button. I'll investigate the  neutral light to button side of the wiring next I guess.
Post by: rbm on February 15, 2023, 04:12:32 AM
The neutral detect / start enable circuit in the instrument cluster may be defective.  What I'm thinking is that the transistor switching the neutral light is strong enough to supply current for the light but too weak to supply current for the start relay.  Need to repair or replace that circuit.
Post by: K1300S on February 15, 2023, 07:36:22 PM
Is the sidestand down when you are trying to start it?
Post by: Tcapling on February 15, 2023, 07:39:04 PM
No. Side stand is up. Fuel pump p doesn't run with the stand down.
If I bypass the speedo. It seems to function normal. So likely an internal speedo issue
Post by: rbm on February 15, 2023, 10:40:49 PM
When you say speedo, do you mean speedo or do you mean the entire gauge cluster?  How do you just bypass the speedo?
Post by: Tcapling on February 15, 2023, 10:45:00 PM
I mean the entire cluster.
And by bypass I am specifically referring to jumping the green with black tracer to the black with green tracer wire in the connector for the cluster. Effectively removing the clusters internal neutral light circuitry.
Post by: frankenduck on February 18, 2023, 12:20:23 PM
If you do that jump then the starter will work when the bike is in gear - not advisable. I'd just pull in the clutch instead to start so that bike will not start unless the drive train is at least disengaged at the clutch.
Post by: Tcapling on February 18, 2023, 12:24:35 PM
If you do that jump then the starter will work when the bike is in gear - not advisable. I'd just pull in the clutch instead to start.
This was done just for diagnostic purposes. From what I've found the neutral light circuit just can't flow enough power to trigger my solenoid.
This bike is not using a factory starter. Or starter relay,  current demands are much higher from what I can determine. I'll likely just have to put a relay on the trigger side of the solenoid. Like the big rigs run. I hate adding complexity to a circuit but there's not always a choice.
Post by: The Mighty Gryphon on February 18, 2023, 01:03:34 PM
The people trying to help you are basing their suggestions on a stock system which is what almost all the bikes are equipped with and everyone's experience is with.
You could really help us help you by providing a circuit diagram and details on the non standard parts you are using.
Post by: frankenduck on February 18, 2023, 01:36:04 PM
What non-factory starter are you using? And why?
Post by: Tcapling on February 18, 2023, 01:54:37 PM
The bike is now home to a Mercedes Benz om660 engine. 800cc turbo 3 cylinder.
The entire factory harness is being used with the exception of the motronic section. An aftermarket standalone ecu is being used and has been wired in.
I had assumed that the starter should engage while in neutral without pulling the clutch. But since it's been 8 months since I pulled the k100 lump I couldn't remember.
I find that the engine turns slower when using the start button than it does when I trip the solenoid direct for the battery. Hence the thought to use a relay so it will start in n and will turn faster.
Post by: Tcapling on February 18, 2023, 02:01:40 PM
(https://i.ibb.co/DM4yYTt/IMG-20230211-WA0005.jpg) (https://ibb.co/X5XgDMb)
(https://i.ibb.co/G2V77b8/IMG-20230211-WA0003.jpg) (https://ibb.co/d2QBBzV)
Post by: frankenduck on February 18, 2023, 02:03:36 PM
Does the headlight go out when you start with the clutch pulled in?
Does the headlight go out when you start from the N light circuit?
I have no idea how you've rewired things but if, for some reason, the load shed relay isn't turning off the headlight (and a few other  things)when you start from the N light then that would cause the bike to start slower.
Post by: Tcapling on February 18, 2023, 02:08:26 PM
Load shed relay is hooked up however that is a good point. I will have to check and see if it is infact functioning as it should.
Post by: Past-my-Prime on February 19, 2023, 09:38:05 PM
Yes, I'd consider non-brick brick VERY non-oem. I imagine this is from a Smart Car.
And diesel. With a very high compression ratio - may need a bigger battery - not sure how much it takes to turn this engine over. .  .
Was this a fun project or is there actual utility for the conversion?
Post by: The Mighty Gryphon on February 19, 2023, 10:03:01 PM
The starter relay in the stock configuration gets power from either the gear position circuit in the cluster or from the clutch switch on the left handlebar.  The gear position circuit is not a high current source.
Because of this, the relay coil for the starter relay is a low current device so as to not overload the gear position circuit.  I am not familiar with the starter on the Smart Car engine, but if it has a Bendix gear combined with the starter solenoid, the current draw to pull it in will be a lot higher than the K bike starter and require a higher current starter relay that may need a higher coil current that the gear position circuit can't supply.
Have you replaced the Start Relay on your bike?  If so, what is the coil current spec for the new relay?  That could explain your problem.
Post by: frankenduck on February 19, 2023, 10:19:20 PM
According to my advanced Internet research ( :laughing1:) a typical 12V relay needs roughly 150-200 mA to activate the switching coil so I ASSUME that that is the approximate current that the factory GPI circuit board can put out.
As to it starting "slower" that seems odd as a relay either makes a successful pin 30 to pin 87 connection or it doesn't.
However, as  I pointed out in my previous post, if the load shed relay isn't cutting the power to other circuits then that would account for less power to the starter vs. a  direct short circuit to the starter motor.
On top of that there is the weirdness of how the starter grounds things on a K. You need RBM's input on this as he is a much better electron chaser than the rest of us.
Post by: Tcapling on February 19, 2023, 10:31:43 PM
Good eye. It isnindeed a smart car .8l common rail turbo diesel.
Factory battery turns it over quite well surprisingly. But  only so many times.
I will swap it for a yix 30 or an odessy at some point.
It was mostly a because I can project. Though there is a small endurance event in June that I'll be taking it to, and it'll be the first diesel ever in it.
Post by: Tcapling on February 19, 2023, 10:38:11 PM
The problem is likely that I eliminated the factory start relay, and am wired direct to the solenoid/bendix actuator. It would make sense that there justbisnt sufficient current capacity through the stock cluster on the n wire. After much fiddling about with chasing the circuit etc, I stabbed a std bosch 3amp relay in and the starter spins at the faster speed. Now I just need to figure why I have no N light anymore. (had the cluster open to see if there were any burnt traces etc. And eveer thing worked as it should. But once I screwed it back to gether. No more n light. I assume the one wire has ousted out of the connector.)
Post by: Tcapling on February 19, 2023, 10:43:22 PM
I do find it weird that it turns slower as I agree, once a realy is closed, it's closed.
Load shed relay works as intended. Checked it specifically today after your last post.
Wiring a relay between the button and the solenoid makes it spin at proper speed. So i guess that's the route to take. Now to fix my n light so I can test that it functions in n the same.
I can freely admit, 33 year bmw wiring is bonkers. F'n side stand fuel pump cut out has caught me more than once changing a circuit that has nothing wrong with it. Things to get used to I guess.
Post by: Laitch on February 19, 2023, 10:47:43 PM
I do find it weird that it turns slower as I agree, once a realy is closed, it's closed.  Things to get used to I guess.
An 18:1 compression diesel needs more cranking power than a Brick's factory battery can provide—probably twice as much.
Post by: Tcapling on February 19, 2023, 10:56:42 PM
While this is true, the cranking speed difference come when using the factory wiring to trigger the starter circuit. If I use an 18g jumper wire from the Trigger terminal on the starter direct to the battery + it cranks faster.
Same solenoid, triggered by the same battery,  the only difference being the factory bmw wiring...
Post by: Laitch on February 19, 2023, 10:59:32 PM
 :laughing4-giggles:
Post by: The Mighty Gryphon on February 19, 2023, 11:25:45 PM
I'm going to guess that there is an output transistor in the cluster that has been toasted.  I sort of figured that the Bendix would draw more current.  The solenoid has to overcome the spring that disengages the starter gear when the starter is turned off in order to close the power contacts for the motor.  That is going to need a bit more current than 200ma.  Possibly on the order of 2-3 amps.
The clutch switch may have sent enough current to get the solenoid to sort of make contact, but not with enough force to get a good solid low resistance connection for the motor current.
I think the load shed problem is related to the higher current flowing through the new starter and where the activating voltage drop for the load shed is coming from.  Are you taking it from the solenoid terminal or the terminal on the motor itself.  I would think that the voltage at those two points will be different.
Post by: Tcapling on February 19, 2023, 11:28:20 PM
Taking load shed from the motor side of the solenoid  same as the oem set up
Post by: Tcapling on February 19, 2023, 11:30:18 PM
THe clutch switch may have sent enough current to get the solenoid to sort of make contact, but not with enough force to get a good solid low resistance connection for the motor current.
I think the load shed problem is related to the higher current flowing through the new starter and where the activating voltage drop for the load shed is coming from.  Are taking it from the solenoid terminal or the terminal on the motor itself.  I would thing that the voltage at those two points will be different.
After reading all the reply I believe you are 100% correct
Post by: caveman on February 20, 2023, 03:20:53 AM
Tcapling,
That is indeed an interesting project you have going on there!
I am curious if with that starter circuit you are getting the proper ground through the starter for the load shed relay?
Hope you keep us up to speed with this project.
Post by: Laitch on February 20, 2023, 08:14:42 AM
There are a few diesel creations out there (http://www.dieselbike.net/kawasaki/kawasaki.htm); I only knew about the military KLR650. Good luck with this. Maybe a Smart Bike would help some riders from the get-go.  112350
Post by: The Mighty Gryphon on February 20, 2023, 08:32:03 AM
My bikes are already smarter than I am.
Post by: rbm on February 20, 2023, 08:35:20 AM
Seem to be a bit late to the party.
Make sure that the relay you have installed ahead of the solenoid has a snubber circuit across the coil primary.  This is simply a general purpose diode installed in reverse across the coil.  This snubber prevents electrical spikes travelling down the ground wire and taking out the transistors in the ICU.  If those transistors get destroyed, you'll have to replace the entire ICU.
As for the GPI board, the neutral / start enable driver transistor is probably bad and needs replacement.  This could happen during your testing where the attached solenoid tried to draw too much current.  Refer to the schematic for the GPI board here:  REFERENCE: Schematics for OEM Circuits (https://www.motobrick.com/index.php?topic=10566.0)
Look for the GPI schematic and click on large schematic link.  Find the Start Enable circuit.  V8 and V9 form a Darlington driver which turns on or off V10 when a neutral condition is detected.  In your case V10 is probably toasted and needs replacing.  It's a BD370 which are NLA meaning they are very hard to find but can be found on eBay (https://www.ebay.ca/itm/322510895450).
Post by: Laitch on February 20, 2023, 09:29:55 AM
Sadly for me, i'm stuck back at the battery cranking amp/diesel engine interaction square. What does "only so many times" mean—2, 4, 16, steady for 25 seconds? Does the engine have a fuel/block heater?
Post by: Tcapling on February 20, 2023, 09:57:57 AM
The engine has glow plugs, which are triggered by the ecu only when the coolant temperature is below a certain point. If I hook them up their use certainly reduces the number of times the factory battery will crank it at speed.
 While testing the various circuits I have cranked it with out starting (no fuel tank on the bike) an easy 20-25 times while still maintaining the higher crank speed at the end when tested direct. A 25 second crank is supported no problem.
For comparison sake, I have had a high CCA battery from my diesel truck hooked to it and behaves the exact same way.
BecUse if this I don't believe that the battery is the source of my current issue.
Post by: Tcapling on February 20, 2023, 12:51:03 PM
There are definitely a few out there. The hdt klr was my first choice. But they are slow. No part of that would be enjoyable on anything faster that country roads.
The forum section of that site is where I took my inspiration for this project from. I am not the first to make a smart powered k100. There are at least 4 others running around in the u.k. and Europe.
There was even a Dutch (I think( company called evatrack that made a bespoke smart powered adv bike though it used a cvt instead of a transmission.
Mine will just be a diesel first at this particular rally.
Post by: Tcapling on February 20, 2023, 12:53:20 PM
Tha KS for the very well put together info on the Internal circuitry of this dash. It made it extremely easy to zero in on the v10 transistor, which as you and others have suspected, has crapped the bed. Now to source a replacement and reassemble.
Thanks again
Post by: The Mighty Gryphon on February 20, 2023, 01:58:44 PM
That transistor is probably just a switching device that turns on when the transmission is in Neutral.
There are dozens of transistors that would work in it's place.  Maybe Rob could recommend one that would work.  I would guess that the operating voltage and current capacity would be the key specifications to find a replacement.
You could also do a search for "BD370 substitute".
Post by: The Mighty Gryphon on February 20, 2023, 02:00:40 PM
Here, I saved you 2 minutes:
https://alltransistors.com/transistor.php?transistor=25149
