TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: bmwcyclist on November 25, 2022, 10:42:11 AM
Title: shortcut method to lube the input splines LINK BROKEN, cant find method
Post by: bmwcyclist on November 25, 2022, 10:42:11 AM
The "short cut" method to lubing the K75/100 clutch input splines referenced here: (http://www.motobrick.com/index.php?topic=8895.0) is missing, the link is dead.
I have ALREADY recently lubed the final drive so no I don't need to do that also (thus the need for the Short Cut).
Please let me know if anyone has a copy of these instructions/guidance.
Thank you!
Title: Re: shortcut method to lube the input splines LINK BROKEN, cant find method
Post by: The Mighty Gryphon on November 25, 2022, 12:20:50 PM
I don't know where the link is, but essentially, it involves removing the battery, and removing the transmission screws.  Put the engine up on blocks so you don't need the center stand.
Then you install a couple of the longest 8mm screws you can find(about 4"), one on each side so you can slide the transmission back about 3/4".  Then, you can reach in with a long parts cleaning brush to put a little lube on the clutch splines.  With the transmission in 5th, you can use the rear wheel to turn the shaft to get all the splines.
