TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Swampyankee on November 06, 2022, 03:53:11 PM
Title: Trying to revive a sleeping bike
Post by: Swampyankee on November 06, 2022, 03:53:11 PM
I'm trying to sort out an start my "new" 86 K100RS.  Got a new battery, resealed the leaking fuel level sender port, went repaired broken wires to temp sensor, and pulled fuel pump and bench tested it with success.
The tank had very little gas in it and presumably old so I put a couple gallons of fresh gas in it.
After much cranking over it would try to start and eventually got running but wouldn't idle. Then would no longer start. I noticed fuel dripping and traced it to the low point of rearmost header pipe. Felt around and thd pipe is dented and perforated, probably rusted thru. I pulled the plugs and they all were wet. I dried them and checked and got spark. Reinstalled them, but the bike is not starting.
Any tricks to bringing an old K100 back from the dead? Or is there something amiss I should be looking for?
Title: Re: Trying to revive a sleeping bike
Post by: daveson on November 06, 2022, 04:02:05 PM
Just to pick up on your comment about fuel dripping from the rear header pipe. The fuel pressure regulator is connected to the rear cylinder by a vacuum hose. The regulator might be leaking, and fuel getting to the cylinder from the vacuum hose. Crank it then pull the hose from the throttle body at cylinder four, if it's damp or has signs of fuel, the regulator is leaking and needs to be replaced.
If it was a small leak and not noticed by the previous owner, the sump oil level could rise over time as it gets contaminated with fuel. That's one reason the oil level wants to be below the top of the sight level glass. If it was a big leak, it could be even worse, like hydraulic lock bending a con rod.
Post by: Swampyankee on November 06, 2022, 04:26:14 PM
I can check that but I had that hose off - it doesn't have a relly tight connection - and it was dry at the time. I checked because after running but not being able to idle i looked at the vacuum taps on all 4 throttle bodies and 2 were open. Not having the proper plugs, I improvised with short pieces of tubing with a screw plugging the end. Classic shadetree mechanic bodge, I know.
Now that I mentioned that, it was after that "repair" that I couldn't get it started again.
Post by: daveson on November 06, 2022, 04:34:01 PM
The hose might be dry if it wasn't started for a while. The hose and plugs want to be tight. Check that the vacuum hose is connected to the pressure regulator. Check also the hose for leaks between the plenum chamber and engine case.
It might be running rich on all cylinders, and run better temporarily with the fuel pump unplugged.
Post by: Swampyankee on November 06, 2022, 04:40:39 PM
I looked for the regulator thinking it was the reason for the gas leak but couldn't locate it. I need to invest in a manual. Where does the regulator reside?
Post by: Laitch on November 06, 2022, 05:37:22 PM
There's a downloadable BMW Repair Manual in the Service Manual section of this site. That will be cost free.  :laughing4-giggles:  The fuel pressure regulator is behind the throttle bodies. See Chapter 13, p13.
Post by: frankenduck on November 06, 2022, 06:07:53 PM
The Fuel pressure regulator (FPR) is located on the back of the throttle bodies.
(https://i.imgur.com/adaaLUv.jpg)
You need to remove the airbox to access it.
How to:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k75pa.rehab/k75parehab.htm#fuelair
Note that you don't need to take the mass airflow sensor out of the top of the airbox if you're just trying to get to  the FPR.
Post by: Swampyankee on November 06, 2022, 06:44:45 PM
I attempted to remove the air box just to trace the fuel return line looking for leaks. I couldn't get the intake air plenum off the airbox before I ran out of time. Gotta get back to it.
Post by: Swampyankee on November 07, 2022, 09:56:45 AM
I failed to mention that this bike probably had not been started in at least a year. Battery was flat dead and wouldn't take a charge. It also looks like it had been left outside for an undetermined amount of time.
I'm out of town for the rest of the week but I hope to look at it again next weekend.
Post by: TommyT on November 07, 2022, 05:58:38 PM
You wrote: "The tank had very little gas in it and presumably old so I put a couple gallons of fresh gas in it."
Did you get the ALL of the old gas out before you added your fresh gas? In my past experience just a little bit of old gas in a MC gas tank will not mix well with fresh gas and will make any bike a no start or not run much above an idle.
Post by: Swampyankee on November 13, 2022, 01:26:32 PM
Back at it after a week away. I drained the tank and got out over a gallon of amber colored fuel and about 4 oz of water.
* 20221113_132739.jpg (47.65 kB . 768x576 - viewed 923 times)
I mopped out the tank as dry as I could and added some fresh gas.
After alot of turning over and purging the filter and lines I managed to start it but no better than my first attempt, and as before it would not idle nor restart. Gas is draining from the exgaust via the pinholes in the low point of number 4 header pipe. I'm beginning to suspect the injectors so i pulled them and they don't look great externally.
* 20221113_132708.jpg (55.29 kB . 768x576 - viewed 954 times)
Is there a way to test them and clean them, or am I better off just replacing?
Post by: frankenduck on November 13, 2022, 01:55:14 PM
Whenever I get a "new to me" K bike I send the injectors to:
https://www.mrinjector.us/
He'll not only recondition them but also repaint them. I've sent him some really beat up injectors before and they came back not only working great but also looking great.
I got a K100 once that had been sitting under a tarp in Seattle rainy for so long that the water had separated from the gas.
Post by: Swampyankee on November 13, 2022, 06:15:48 PM
Thanx for the referral. For what its worth I just went ahead and ordered a set from Mr Injector.
BTW, the bike you mentioned sounds alot like the condition I got mine in. Lots of weather on frame and alloy parts.
Post by: Swampyankee on November 19, 2022, 02:10:06 PM
Got the new injectors installed but motor is not any better. After much cranking with fuel pump plugged in as well as unplugged with a few pops and false starts, i pulled the plugs and tried the oil in the cylinders trick to no avail. Plugs are quite sooted up so I cleaned the electrodes with a bit of sandpaper. Got it to run for a bit but it died. Thinking it may be just out of gas I put 3 gallons of hi test in it, plus i hit it with some starter fluid. That seemed to do the trick and it ran for maybe 5 minutes and eventually settled into a rough idle but would pop and crackle with black smoke when revved as if it were running rich. I experimented with pulling the caps of the vacuum tubes and then sprayed the intake boots with carb cleaner looking for a leak. At that point it died and would not start even with shots of ether. I pulled plugs and found weak or no spark at the plugs, although I could feel the voltage even through the insulated handle of the pliers holding the plug when i lifted it from grounding on the block.
At this point I'm completely miffed. Maybe this is the real reason the PO was selling it, even if he did play up the saying goodbye to an old friend bit.
I will get some new plugs and see if that would improve the sparkulation. Any other suggestions??
Post by: frankenduck on November 19, 2022, 02:24:51 PM
Here's a good K100 troubleshooting write-up by the frog over at the K100 forum.
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k100tshoot/K100.Troubleshoot.Start.2018.pdf
First things I would check:
Resistance across ignition coils. Page 15
Also check the water temp sensor resistance between L-Jet pin 10 and ground.
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/tempsensor/tempsensor.htm
Post by: The Mighty Gryphon on November 19, 2022, 02:31:24 PM
What kind of spark plugs are in it?  NGK D7EA are pretty common and work well, BUT they need the terminal nut on the end to make a good connection to the BMW plug wires.  If you use them, and many of us do, get the nuts.  I have got them from a shop that repairs lawn mowers.  They will often have a bucket of old Briggs and Stratton plugs that you can get a few nuts from.  Another source is to contact NGK USA tech service and ask.  A few years back I got a dozen from them no charge.
Post by: frankenduck on November 19, 2022, 02:50:45 PM
There's a good chance that your crank case breather hose is shot and needs to be replaced.
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/ccb/ccb.htm
Post by: Swampyankee on November 19, 2022, 08:23:03 PM
The plugs are Bosch but I did not take note of the type. They do have the caps on them.
Post by: Swampyankee on November 19, 2022, 08:27:08 PM
I can check that but explain how that contributes to a no start or hard start condition. I should mention again that gas  is overflowing a enough that it dumps out the exhaust. Of course the only reason I know is it drips out of the pinholes in number 4 cylinder header pipe.
Post by: frankenduck on November 19, 2022, 09:31:19 PM
If you're over-fueling that much then my first suspect would be to check the water temp sensor resistance that I referred to above.
Post by: Swampyankee on November 19, 2022, 09:35:28 PM
I believe one of the things the PO was something :mb: about the fan relay, which could be more akin to a temp sensor malfunction.  But you also need to elaborate on the crankcase breather hose comment.
Post by: Laitch on November 19, 2022, 10:03:27 PM
You've indicated there is fuel excessive enough that it dumps into the exhaust system. Why?
1)The crankcase breather hose is allowing so much unmetered air into the system that the mixture is too lean to ignite and injected fuel is not consumed and dumped into the exhaust system.
2)There might not be enough air in the mixture to permit combustion.The air snorkel could be clogged or the air filter could be clogged. The fuel mixture is too rich to ignite; fuel is dumped into the exhaust system.
3)The coils might be damaged so not providing hot sufficient spark for ignition to consume fuel.
4)The primary coil wires might be loose or corroded so the coils cannot supply sufficient spark to ignite the fuel.
5)The plug wires might be degraded enough that they cannot provide sufficient energy spark for ignition so fuel isn't consumed.
6)Degraded throttle body connections are leaking unmetered air into the system so the fuel mixture is too lean to ignite.
All the un-ignited fuel is being dumped into the exhaust system.
Post by: Swampyankee on November 19, 2022, 10:09:02 PM
Thanx for the explanation. I will investigate. One supporting thing to note is that it runs better with all the vacuum plugs removed from the throttle bodies.
One thing to add - when i pointed out a pair of wires with bare ends the PO said he thought they had been chewed through by a rodent. I traced them to the temp sensor at the bottom of the radiator. I pulled the connector and soldered the wires back together and heat shrink tubed over the splices. But it looked like the mouse had done a very clean job of cutting and stripping the wire ends... think. The other thing was the pair of wires were the same colors - purple and yellow IIRC. Since I couldn't tell them apart I assumed it didn't matter which went where. Am I wrong there??
Post by: frankenduck on November 20, 2022, 10:07:45 AM
Unlike many temp sensors that have a temp sensor wire and a ground wire, the K100/K75 temp sensor is a dual temp sensor that grounds to the threads it's screwed into and has "outputs" to both the temp relay and the L-Jetronic. That's why both wires are the same color (violet/green) and they should output the same resistance.
(https://i.imgur.com/vkuuUbM.jpg)
Post by: Swampyankee on November 21, 2022, 10:19:00 AM
So I need to check resistance to ground at both contacts in the temp sender. Good to know. I'm piecing together my understanding of the operating system on this bike. Let's hope I don't screw things up too badly before I get it figured out and running. Although for what I paid and the condition this thing is in, it's probably not a bad bike to learn on. The more I work on this thing, the more discouraged I am with the work needed to restore/renovate. The bike really is pretty ratty, with rusted rear frame section, bad paint on bodywork, etc. I may end up getting it running and then sell it as a good candidate for a cafe/rat/brat bike conversion, and find a better example for running in original condition.
Post by: The Mighty Gryphon on November 21, 2022, 10:50:49 AM
I wouldn't let a little cosmetic damage discourage me.  A lot of us have done repaints, and you aren't the first to find a lot of rusty frame under the tail cowl.  Fortunately, if you take your time, you can make some amazing improvements in the looks of your bike for a not exorbitant amount of money.
The good news is that there are many here who have restored Bricks that were in pretty bad shape and documented their work here at Motobrick.com.  There isn't one job on these bikes that hasn't been documented somewhere here.
The most important thing you need is some patience.  Take your time and our advice and you will have a machine to be proud of.
It looks like you have a decent place to work, so it shouldn't be too hard to do this as a winter project.  I would strongly suggest that the first thing to do right now is to remove the bodywork and do a good clean on the frame and the wiring before the weather gets much colder.  Working on a dirty bike can really make even nice jobs suck.
My favorite cleaner for this step is S100 which you can get at any Harley dealer and a lot of other motorcycle shops.  Once the frame is clean, keep it by your laundry tubs to clean parts as you remove them to be worked on.  Clean parts and a clean bike make this work a lot nicer.
Post by: Swampyankee on November 21, 2022, 01:57:57 PM
I had the bike in the barn initially, but have since moved it to the garage under. The concrete floor, and stone walls for that matter, are a bit safer for working with fuel spills and the like. Plus, since my project cars are in there, it's where all the good tools are.   112350
Post by: Laitch on November 21, 2022, 02:04:00 PM
This manual explains how it all works. You could have downloaded it from the site but I've saved you a step.
Post by: Swampyankee on November 21, 2022, 05:42:03 PM
I did download it but I'm one of those that refer to the instructions as a last resort   :idunno:
Post by: The Mighty Gryphon on November 21, 2022, 05:45:03 PM
Probably not the optimum way to go through life. :idunno:
Post by: frankenduck on November 21, 2022, 06:07:11 PM
Here's part of the owners manual you should read:
(https://i.imgur.com/NWVLsCx.png)
Post by: Swampyankee on November 22, 2022, 07:21:57 AM
Well, I did read THAT part! The bike came with all the original owners and operation manuals, as well as warranty info, etc. and some receipts for maintenance and repairs, which I pored over. I also did read through past threads about these bikes and watched a bunch of Chris Harris videos on maintenance and repair before I even decided on a brick. I also went through the downloaded repair manual to familiarize myself with it, and continue to research info on diagnosing my bike's particular issues. But sometimes it's also good to tap into the collective knowledge of folks on forums like this.
So excuse me if I ask too many questions. Just looking for moral support as much as knowledge....
Post by: Past-my-Prime on November 22, 2022, 06:42:11 PM
Ask away! No one HAS to answer. Other people might have the same question.   :thisplacewhack
Post by: Swampyankee on November 23, 2022, 08:49:30 AM
I assumed your link was to the Repair manual. Now that I'm on a computer and not the tiny screen of my phone, I see what you have provided here, thank you. I did not see that in the downloadable content, or did not recognize what it was. It provides the description of the operation of the FI system that I was looking for. As I go through the steps, I am leaning toward problems with the ignition/spark rather than the injection system. Given the amount of fuel I see being passed through, I would think the bike would start readily, even if it did run poorly and die from a too-rich mix, as long as a good strong spark was present. It does not want to pop even when initially cranked. The other thing is, when I pulled plugs and grounded them to the block checking for spark while cranking. It was pretty weak at best, and jumping across from the side of the center electrode to the base of the prong as opposed to jumping from tip to tip as it should. When I did have it running and idling, the removal of #2 plug wire made no change to the idle, which tells me #2 wasn't even firing.
I plan to check resistance of the coils and if ok, see if a new set of plugs would provide a solid spark. Hopefully I have the same easy fix as this guy. http://www.motobrick.com/index.php?topic=14612.0 (http://www.motobrick.com/index.php?topic=14612.0)
Could corrosion of the hall sensor also be causing poor ignition response? As mentioned earlier, the bike has seen some weather.
Post by: Laitch on November 23, 2022, 09:26:09 AM
If the fuel/air ratio is too lopsided the mixture is unlikely to ignite regardless of spark.
Don't get into the Hall Sensor itself yet. First, clean all ground connections, including the main one under the tank, the hall sensor plug connection, the four-pin tank connection to the fuel pump, the Jetronic and ignition control unit plugs including their respective terminals, and the coil and plug wire terminals themselves unless they are new. The cleaner recommended by many here is DeoxIT D5, often found in music stores selling electronic instrument, sometimes sold in auto part stores and easily found online.
Brick engines are dependent upon good electrical connections. A disused Brick left out in the weather can be stubborn to start and if electrical connections are not thoroughly cleaned up, starting and running might occur but will likely be undependable.
Post by: The Mighty Gryphon on November 23, 2022, 09:37:00 AM
I see that Laitch essentially said everything I have typed while I was typing, so let me just be an echo:
Considering that the bike has been out in the weather for a while, have you gone through and cleaned all the electrical connections?  There are a couple connectors under the tank that carry ignition signals from the Hall Sensors.  A little attention with Deoxit may help things along.  Also, if you haven't already, you should clean the ground connections, especially the one under the tank on the frame backbone.  You should be sure that the coil connections are clean and tight as well.  Over the years here, I've seen many bikes come back from the dead from cleaning the electrical connectors.
I think you are correct to be installing new spark plugs.  If you don't know how old the originals are, they are definitely worth the relatively small expense to be sure you have good ones.
Post by: frankenduck on November 23, 2022, 09:54:04 AM
If you suspect spark problems then the early K100 coils are not as reliable as the late coils.  Do measure the resistance across the coil terminals.
(https://i.imgur.com/v8gFTfN.jpg)
If you can find the newer coils on Ebay or wherever they are interchangeable with the early coils.
Post by: Swampyankee on November 23, 2022, 11:06:18 AM
I will check out coil resistance while I'm in there. I went through the same thing with the coil on my boat last summer.
I use Deoxit for cleaning scratchy pots on my guitars and music gear, and I've already used it on the 4 pin connectors for the fuel pump, so I'll check the other connections you mention. Looks like I'll be pulling the tank again. It'll be a bit heavier this time with the 3 gallons of fresh gas I put in. LOL
Post by: frankenduck on November 23, 2022, 11:09:30 AM
If there's a decent amount of fuel in the tank then you'll want to lean it against a wall with the front pointing up to keep fuel from dripping out. Either that or put a cork/stopper in the rear outlet pipe.
Post by: The Mighty Gryphon on November 23, 2022, 11:51:30 AM
Have you cleaned the ground connection on the left side of the transmission above the shifter?  The wire connected there is the main return from all the bike's electrical stuff to the negative terminal on the battery.  It's sort of in an unnoticed location, but still exposed to the elements.
Post by: Swampyankee on November 23, 2022, 04:46:49 PM
I did clean that one ehen I installed the new battery.
Post by: Swampyankee on January 09, 2023, 08:25:03 AM
Back to work on the brick after the holidays. Got the RS bars from eBay someone posted the link for, as well as a replacement throttle cable (don't ask why I needed one!) so I decided to install both items together. Got the C 'bars stripped with minimal dismantling and disconnections, although I had to bend the mounting brackets on the crash pad to get at the clamp bolts since the bracket ends were under the rear two clamp bolts. The RS 'bars were alot less of a "stretch" to install the controls on, but I overtightened the clamp bolt on the clutch side and snapped the threaded side of the clamp off !@#$%!.
Moving on, I tried bolting the crash pad back where I found it but it sat way too high. I checked on line and found that the C pad is different than the RS pad, in that the RS pad bolts to the 2 cap screws at the back of the handlebar clamp bases. Looking for an alternative to ordering an RS pad on eBay, I thought maybe I could modify mounts on the one I have, by straightening the brackets and possibly re-drilling holes where needed. Upon closer inspection I noticed someone had enlarged the holes in the brackets and had bent the brackets to mount on the clamp bolts. The pad was the original RS pad, modified to mount higher for C 'bar clearance. Straightened the brackets and they lined up perfectly with those 2 cap screws at the back of the clamp bases, albeit with slightly larger holes. Problem solved.
After routing the replacement throttle cable, I installed the ends and tried adjusting the excess slack out, but even with the adjuster at full extension there is still too much slack - as much as 1/4" (?@@??). Is there a spacer I'm missing, possibly down by the throttle bodies? Hint - I bought the cable on eBay. Although the ends are correct, could there be a different cable that requires the extra inner cable length?
The last straw was when I reinstalled the air filter and spring clamps on the air box. The loop in the spring clamp that contains the pin just split, discharging the pin !@#$%! As one of the clamps were already missing, I'm down to one holding the box together. Looks like I'll be looking on eBay for a couple clamps along with a new air filter element (don't ask why!) and a clutch-side handlebar control.
And I still haven't installed new plugs, troubleshot the coils or other electrics to get this thing running! Did I say 1 step forward and 2 steps back??
Post by: daveson on January 09, 2023, 03:38:40 PM
I had the problem with the throttle cable too long when I put a cable from an '88 RT model on an '85 RT model. It was then that I noticed that the cable support brackets at the throttle body had different offsets. That might be the problem. One possibility would be to make a spacer to put under the bracket. It would want to be tapered so that the inner cable leaves parallel to the outer.
Post by: Swampyankee on January 10, 2023, 08:59:51 AM
I was thinking of making a spacer. I could turn one up at work - or have an apprentice do it for me  :laughing1: with an I.D on one end to capture the nylon bushing end of the cable, and the O.D. on the other end to fit in the receiver at the throttle body, and a slit cut in it to fit onto the inner cable. Might just work... Now to determine what length to take up sufficient slack, or just make it long enough so I can drill it deeper if it's too long.
Meanwhile, anyone have a spare clutch-side lever perch?
Post by: Swampyankee on February 18, 2023, 07:09:05 PM
I've been tinkering with the project bike as time permits. New spark plugs made a big improvement in getting it running and I was actually able to take it for a ride. But once the bike warmed up it wouldn't restart without unplugging the fuel pump and burning off excess fuel, then plugging it back in again before it died. No way to operate the bike on a daily ride!
After getting flakey "warm" ohm readings from the temp sensor, I went ahead and ordered a new one. Still waiting for it to arrive.
Can't wait to get it installed and get this thing sorted mechanically so i can move forward with putting the fairings back together.
