TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Classic Motobricks => Topic started by: Swampyankee on October 23, 2022, 04:00:58 PM
I'm a longtime airhead guy. Sold my last R75/6 a couple years ago. Now I'm looking for a new project and since I've always admired K100RSs, I started looking. I looked at a decent 85 model, asking $1600. 60k miles and the owner allegedly bought it with 6k on it in 87 and has ridden and maintained it ever since. A plus to have that kind of history. I might be able to get it a hunnert or so cheaper since he's moving.
He's got the typical upgrades - koni shock, luftmeister exhaust, progressive springs. And it has some typical problems - non working gages, leaky fuel tank, spongy brakes, dead battery. But overall the bike seems in good shape gor the year and mileage.
I would hope to tinker with it over the winter and have a decent rideable "classic" brick in the spring.
So is this an ok investment? Not looking to sell at a profit but it would nice to know that is has some value when done.
Just me but I wouldn't buy a K with a leaking tank unless I knew of a GOOD aluminum welder. Ks that sit often leak at the tank seams of the lower corners so finding a good used one can be difficult unless you get lucky. Also 85s have a different tank than 86+ which could make finding a good used tank even more challenging.
Ride a K75 before you buy a K100. They're both great bikes but the K75, as a triple, has a much smoother engine. They have less power, 75 hp vs. 90 hp of a K100, but IMO are a better ride. I wouldn't get a K75 for 2-up riding though.
JM02 (I have six K75s but only 1 K100 which tells you what my bias is.)
Thanx for the caveat. I've patched leaky tanks in the past using Caswells. I though I could do the same with this one.
Caswell tank epoxy or Caswell aluminum brazing rod?
I actually do know a very good welder. I work in the tool and die industry so I have alot of technical resources. Which is why I didn't think the leaky tank was a deal breaker. But I also didn't know the 85 tank was unique so thanx for that.
That change, and some others, occurred during '85, so you might have the earlier or later model.
My brick, for example, born on 15th November 1985, has the later model tank.
Some thoughts for what they may be worth.
It's said that the '85 K100 had hotter cams than the following years. At 60,000 miles the engine is finally broken in and ready for another 200,000 or so.
Besides the tank, the first couple years had some other unique design features that were upgraded in the following years, so they aren't interchangeable with later parts. Off the top of my head, the seat attachments, the rear cowl to go with the seat, the rear brake disc was slotted and changed to solid, the engine output shaft went from 6 rivets to 12 rivets, and the drive shaft and final drive went from 16 splines to 20.
Problem areas to be aware of are the inside of the fuel tank, drive splines, and brakes. The vibration damper dissolves in the crap ethanol fuel and fills the tank with gooey black residue that coats and clogs the fuel pump and the level sensor. Brake fluid crystallizes and absorbs water that corrodes the master cylinders, especially the rear. Injectors often need cleaning after extended idleness. There is a grub screw in the shift mechanism that loosens on some bikes and leads to a lot of slop in the shifter. The drive cushions for the alternator can disintegrate causing a lot of noise. The O-ring on the output shaft will harden over time and cause a slight leak between the engine and transmission, and there are some rubber bits that crack over time(the infamous Z-tube between the crankcase and the intake air plenum is one).
At $1600 for a bike with 60K on it, none of these things would be that hard to correct. Many of us have dealt with them and lived to tell the tale. The beauty of the classic K is that once you have corrected the results of the idleness, it will be a stone reliable ride that doesn't really require that much maintenance.
A double walled case 75 tank presents significant welding challenges not easily corrected in my experience . I personally would recommend a test ride on a four-cylinder to assess the handlebar vibration before you buy. Some don’t care my hands simply go numb cheers.
Motobricker such as Frankenduck have been a huge huge resource and enhancement to my brick adventures.
greetings Swampyankee. I am a fellow RI'er though from "upstate" (Cumberland).
I owned an 85 RS for 36 years, just recently passed it on to a young fellow who I fear intends to make a horrid cafe-racer out of it.
My bike had 206,000 miles on it all but 400 of them with me in the saddle. Aside from wear and tear items I never experienced a major component break-down.
If it hasn't been done by current owner you will likely have to replace all the rubber bits, vent hoses, manifold gaskets that allow the engine to breath and vent. Make sure the cooling fan works, water/oil pump doesn't leak, no oil drip in weep hole under the engine bell-housing. All of these are easily fixed, the bike is surprisingly easy to work on one you've learned your way around it.
yes, there are items specific to the 85 none of them deal breakers.
Yes they are buzzy and heat shedding is a bother in warmer months but tucked into that machine at 80MPH feels akin to sitting atop a cruise missile. An older version mind you but a joy to pilot through twisties in New England and arrow straight slabs in MT, WY and the Dakotas!
It's cool to have a FYK (first year K).
I miss mine but riding position and garage space became factors for selling. It still ran as new.
Still lots of bits and bobs available on the web and a surprising inventory of new stuff available from folks like morton's.
Hell, even Razee's may have some stuff laying around!
g'luck and happy hunting.
What is meant by "double-walled tank"?
My K 75 fuel tank is aluminum requiring TIG for a repair. The construction has an inner vessel and an outer vessel an air gap air gap between them. To weld the inner is a challenge to reach.
Good to hear from someone from the rolling hills of Cumberland. I'm there often, and pass by on 295 on the way to Attleboro every day.
I'm still mulling over the choice between the K100RS I looked at yesterday, and a 96 Triumph Trophy 1200 north of Bangor, Maine, which I would have to buy sight-unseen and have transported due to the distance and limited time.
On the one hand, the Triumph is 10 years newer and 30k miles less. On the other, I'm really intrigued by the K bike, and being a former Beemer owner, I feel a bit of kinship toward it. You mentioned riding position - I sold an R100RS for the same reason, but it was more about the narrow bars. The seller of the subject K100RS said the bars on his bike are wider - R90S bars possibly - and they don't seem as extreme as my R100RS. On the other hand, I'm not getting any younger and riding comfort me become an issue - the other reason for considering the more upright Trophy.
A MAJOR selling point for my K75 RT was the very comfortable riding position. I like to sit up, have my elbows at a comfortable bend, and my wrists straight. I've done a number of 500 mile days in the saddle of mine, and love every minute of it.
I'm not as fast in the twisties as some others (but plenty fast enough to scare myself) and not as quick off the line (a new clutch has helped with that, however) and my top end is only about 120 MPH so if that's a deal breaker, so be it.
Not trying to talk you off the 100 RS, I've been tempted that direction as well but for me as I age, I'm more and more happy to stick with this.
Another vote for the K75 platform. Silky smooth and able to run at 75 mph for hours on end.
I have done several Iron Butt runs including the Bun Burner 1500 miles in 24 hours on my K75RT. Crossing Kansas with a couple other guys on 1200cc touring bikes I had no trouble keeping up with them, even setting the pace at 90+mph for a couple hours. I burned a tank of gas at 100mph in Montana. Cross country blasts from New York to Colorado or Idaho are pretty easy. One day from the Mississippi to the Rockies is routine for my RT.
Yeah, it probably isn't as fast in the mountains as newer bikes, but it's pretty comfortable in crap weather, the price is definitely right, and it inspires the confidence to run solo through some pretty desolate landscapes.
I did my Bun Burner Gold on a K75RT too. 1,610 miles from San Diego to Beaumont, TX in less than 24 hours. Then I rode another 851 miles to Jacksonville Beach, FL. 2,461 miles in just over 36 hours. Pacific beach to Atlantic beach. And I didn't need to ride at hyperlegal speeds to do that. The only time I ever went more than ten over was crossing Louisiana, but everyone in the left lane was speeding so I figured that my chances of getting a ticket were somewhere between zero and none.
I did mine from Fort Collins, CO to Marilla, NY, 1550 miles in 23 hours and 20 minutes on my 69th birthday. It was the last day of a two week 9,000 trip to the west coast. It wasn't a pleasant ride, I hit a steady rain in North Platte, NE that followed me all the way to Davenport, IA.
The worst part was a couple dozen single lane construction zones totaling 150 miles on I-80 across Nebraska and Iowa where I was barely able to to maintain a 45mph average speed. Every time I was able to outrun the advancing weather I hit one of those damn construction zones. The speed was too slow to get me any protection from the rain behind my fairing.
I'm pretty sure I set a world record for calling other drivers Effing Motherf***ers in a 12 hour period that day.
I was alllmmooost ready to pull the trigger on the Triumph Trophy, but buying sight-unseen is becoming a logistics nightmare, not to mention the risk. I believe the Trophy sitting position is probably more relaxed like an RT so I was favoring that.
However, the seller of the '85 K100RS is offering me the bike at a discount since he'd rather sell it where is rather than transport it to his new home. So the deal is a bit more appealing.
Things that the seller has told me is 1) the bike was originally bought in Germany, ridden there on holiday, and then brought back to CT where the owners subsequently started a MC dealership. Not sure if there are any differences - good or bad - between an '85 bike built for sale in DE vs one built for the US market. 2) the seller pointed out that the 1st owner tricked the bike out at the time with Koni shock, Luftmeister exhaust (is that loud?), Corbin lower solo saddle (lower is better for me), prog springs, and slightly wider 'bars (R90S bars?).
I don't anticipate going long distances with this bike. It would be more of a country road burner. Having a "real" K100RS has it's own appeal, and I'm willing to endure some vibrations - heck, I've owned plenty of vibrators on wheels.
Along with the great support I see from sites like this, I think the bike, as old as it is, maybe my choice. Let's see if I can make a deal....
I think the K1100LT doesn’t get the love it is due. Mine is a 94.
I loved my K100RS, but I am 71 years young and with the aches and pains associated with that age I couldn’t ride the RS for more than an hour or so. After a 100 miles it felt like I was sitting on a C130 jump seat!
I can get on the LT and ride all day!
Great weather protection, plenty of luggage/storage space, smooth and silky on the road (especially if you throw a set of radials on it) and nearly mechanically bullet-proof.
When I first acquired the bike (2010) it had 30K on it and was sitting idle and neglected.
Didn’t take much to get her running as new though I did fiddle with ABS System for quite some time. Decided not to spend more on ABS repair than I did for the bike so I removed all the ABS components, installed stainless steel brake lines and never looked back.
Now has 150K and has become my go-to bike.
It just suits me.
It never occurred to me that deleting the ABS brain was an option. I'm studing the ABS brick on my K11RS right now... Cheers.
As long as we are still having fun..its a good purchase.
Looks like I have the bike for $1350. Now I have to figure out how to get it home...
BTW, I just noticed the ad says it's an '86 not '85. Not sure where I even got that unless I got it mixed up with another K100RS I've been looking at. D'OH!
It will fit on an 8 foot utility trailer. Just go a little diagonal to lift the gate.
My "new" bike is about an hour away. I can borrow ramps and put it in the back of my trusty Ranger like so many others that have followed me home. A trailer would be nicer...
Anyone in RI or CT, USA want to help a brother out? LOL
Prolly better off with the 86. 85's didn't have the fork brace and lot's of other bits unique to that year, thought they are know as "FYK" (finest year K) Hotter cams gave them a little more HP.
Interesting. He has the brace but had removed it. I thought it was an aftermarket piece.
There may have been some non braced 86's produced, the factory one has a 2 piece front fender with the brace in the middle. The 85's had a one piece fender and there were aftermarket braces available.
I'll find out more as soon as I get it home tonight, but it's allegedly a German market bike, imported by the owners. Would that matter?
The overall length of a K100RS is 7.3 feet (2220 mm) and will easily fit an 8 foot long trailer bed.
If the fork brace looks like this then it is an aftermarket Teleflex fork brace:
(https://i.imgur.com/Weu7Vuf.jpg)
IIRC the brace was bright anodized aluminum. I'll get a better look at it when I collect the bike this afternoon.
Got the subject bike home last night. The seller gave me a couple of boxes of parts he had removed including the accessories, the aforementioned fork brace (it's aftermarket), tragkorb mounting brackets, and a bag of bolts and hardware.
Unfortunately, he had gutted the inside of the fairing years ago and hadn't saved any of it. Apparently, he had laid the bike down (as scratches on the crank-side engine case attest) and when he had the fairing repaired and repainted, he removed the mountings for the mirrors and threw away the fairing inners. When I got it home I looked closely and there are none of the mountings, etc. remaining.
(not allowing me to attach a pic here)
Although the focus will be to get the bike running and sorted mechanically, I will be looking for all the inner panels and mounting brackets to restore all that. I downloaded a parts diagram I found online to aid in ID'ing what I'll need.
Question - I see some inner panels that incorporate gages. That seller said there were never gages that he recalls. Was that a later year, US market, or RT/LT thing? This bike is an '86 European market bike.
What are the last seven digits of the VIN?
Some bikes had fuel and temp gauges, some didn't. I'm pretty sure that all RS-SE (Special Edition) and LT bikes had them. All 86 and on bikes should have a connector for them under the tank so you can add them if you want to.
Link:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/auxguages/auxguages.htm
The good news about the fairing is that with so many bikes being hacked to make Cappuccino racers. Almost everything you need will be on eBay. Most of the mounting parts are still available from MaxBMW, and for some strange reason are still reasonably priced.
I will put an ad in WTB section here as well. And maybe mention my needs in the Custom Motobrick section. There's got to be someone on this forum that is stripping or modding an RS.
Do you have an RS or RT? I kinda lost track on this thread. If it's an RS, I may have some parts here. In fact I have a bunch of parts for a K1100RS fairing like the one in my avatar but in gray. I need to get it out of here.
Mine's an '86 K100RS. I don't eed any painted parts, just that black plastic inner pieces.
Let me see what I have.
I was going by what I saw during my first sight of the bike. Upon closer examination the brace is a Telefix. The story I got when I picked up the bike was that the owner added it trying to cure a shimmy. When he switched from Metzelers to Pirellis he took off the brace snd shimmy was gone so he left it off. The more I look, the more apparent it is that the bike was ridden hard and put up wet. Although he said it was his baby it looks like when hardware or bodywork broke he just removed it rather than repair it.
And the tank leak is coming from the fuel level sender in the center of the tank. A previous leak was caused by one of the mounting pins in the rear of the tank which had probably broken off and has been nicely patched by a welder.
And BTW, not sure the German market bike story holds true. The stickers on it say it conforms to all federal standards etc. And last 7 of the VIN are 0043204 since someone asked. Although it does have the headlight on-off switch and the tragkorbs have the Touring logo instead of reflectors.
Those switches could be had here in the States. My K75RT has the headlight switch and it's a U.S. spec bike.
That Corbin seat looks pretty nice. What is the color code? There should be a sticker under the seat.
Is that an Ossa Stiletto in the background? I had a Pioneer that I campaigned for a year in enduros and Two Day Qualifiers. Those 250 cc engines had humongous torque. Too bad the engine was so fragile and the air filter was so low. It was really a desert racer.
VIN 0043204 decodes to a US bike built in 11/85.
Does it have a US DOT sticker like this on the left side of the frame?
(https://i.imgur.com/a72eYu5.png)
I just ran a VIN decoder online and it yielded accurate info including a build date of 11/85, but also said it was a US market bike. So nice story about the brothers importing it blah blah, but BS.
Looks like the sticker under the seat with paint code got painted over. Go figure eh. The seat is worn but in decent shape. I like the fact that its lower than stock. Between that and the S 'bars makes for a more comfortable posture.
The bike in the background is a 73 SDR. I've never raced but I've had a number of Ossas over the years. Makes for an international stable - Spanish Ossa, Italian Benelli, German BMW, not to mention an Audi TT assembled in Hungary and GTI 16V built in Mexico. LOL
I think the story might still be true, I know a lot of Aussies went to Germany to get a BMW, the tax savings more than paid for the trip. If someone with an English accent goes to a dealership there, they probably say if you're going back to the US, they'll give you a US spec model so it will be easier for you to get rego in the US. Or the Vin plate was put on to get rego for the US, it might have a number on the frame on the right hand side.
One thing I'm guessing is US models maybe need a flapper thingy for the fuel filler, I haven't seen that in OZ on bricks, but have on later model cars.
Yes, looks just like that except for the VIN of course. One other clue - amongst all the BMW accessory luggage etc. I found a leather luggage tag that says "German Challenge '86". Couldn't find any info on it but could that have been a scheme by BMW where people had a motorcycle holiday in Germany and had the bike shipped home at the end?
Back in the day, BMW did have a program where you could fly to Germany, get a factory tour and take possession of your brand new K. The only person that I know who did this, Phil Marvin, has passed (RIP) so I don't know if you got a Euro bike or a US bike out of the deal. It might make sense to get a US bike because one with that DOT sticker would be easier to import into the US and title.
The flap was probably put there to please California because that state has a cow over every molecule of gas that might evaporate into the air.
Actually the flapper was originally to prevent you from filling with leaded gas, the leaded nozzle was larger and wouldn't fit through the flapper. I took mine out to get a bit more gas in the tank.
I can't say for sure about motorcycles back in the 80's, but I know two members of the yacht club I work at who bought BMW autos in Germany in the last two years. Both got U.S. models and one of them said he could not get a European model when I asked him if his new car was a Euro spec model. As I understand it, the purchase was set up through BMW N.A.
Others of us went to Germany and bought a euro spec bike (used) and brought it back over the pond and went through the process to register it here. Which wasn't at all painful and allowed an excellent European trip!
I know back in the 60s my old boss went back to the motherland on his honeymoon and bought a '67 SLK new and brought it home with him. They still have it as far as i know.
Someone asked about the paint code tag. I assume it was the one under the seat near the tire pressure label. If so, it has been overpainted and torn, so it is illegible.
The bike looks as though it has been re-painted, and areas where chipped away show either white underneath or in some places red. Although the bottom of the tank shows no signs of overspray on areas like the fuel level sender. The PO said he had the front faring mirror mounts faired over and repainted after laying the bike down. The upper is cracked on the right side - probably when I laid it over while loading it on the trailer. And the lower fairing shows signs of previous repairs.
It would be nice to know what color the bike was originally, since it really should be repainted. Or I could just purchase a good set of bodywork from someone building a cafe from an RS. Or this bike might become my experiment in brick ownership, and just replace it with another RS in better condition...
One other thing that might be evidence of the German purchase story is this "German Challenge '86" luggage tag with the original owner's info on it.
This ViN decoder will tell you the name of the original paint color (in German.)
https://www.mdecoder.com/
Here's where the paint scheme number decal typically is:
(https://i.imgur.com/1V4eDDh.jpg)
I think there were a lot of speedometer problems requiring warranty replacement. When the old unit was replaced there was a paper tag about 1"x2" put where your photo shows the peeling. That tag had the mileage on the old speedometer and the date of replacement. This was apparently done for warranty purposes.
The tag with the paint code was on the other side of the emission information label facing the left side of the bike.
The only tag on the left side as you say, is the Warning about accessories affecting ride characteristics.
Well, that solves it. According to the VIN decoder, the bike was originally Avus Schwarz (black), which is what I got. Too bad, I was hoping for something more sexy, like Columbia Silver or Onyx Schwarz...
It's been painted over, for sure.
Thoroughly painted over. So much so that I didn't even notice it.
Maybe Walmart has forensic paint remover. :laughing4-giggles:
Kind of a moot point since the VIN decoder says the bike was Avus Schwarz, which it still is.
(https://pbs.twimg.com/media/DcNoWXMW0AAgGok?format=jpg)
My friend had an R69US back in the 70s that he nicknamed Shultz after the Sgt. on Hogans Heros. I don't normally name things but maybe i should namd my bike Schwartz.
My wife's reaction when I first drove my Ural home for the dealer "Hey Shultz!! Where's Colonel Klink?"
Never been one for naming bikes. Just "the BMW" and the "RPOS" (Russian Piece of Sh**)
Is there any useful information to be derived from the !!CHECK HISTORY!! links in the VIN decoder? It's not free so I was just wondering.
It broke down the VIN pretty well but nothing I didn't already know since my bike came with most of its original documentation. Just a confirmation if anything. I took a screen shot but I think its saved to my work computer so I can't share it at the moment.
The holiday season is putting a cramp in my garage time. But I had questioned about whether the bars on my bike were RS bars or C bars since they seemed higher. I got a peek behind the crash pad and verified they are S bars.
I may want to try RS bars to see if I can handle the extra lean but that point is a ways off. However, anyone have a set of RS bars they would sell cheap let me know.
:nono2: Those are C bars. The K75S and K100RS bars are the same and are welded at a right angle near the handlebar clamps.
(https://i.imgur.com/9DWcPrp.jpg)
S/RS bars:
(https://i.imgur.com/FoK60Mi.jpg)
Those are the pics. I couldn't find the post that discussed them previously thanx. And yes, "C" bars, not "S". I'd like to find some RS bars.
K75S and K100RSRS bars are the same. Part numbers 32712300384 and 32711453072 were used on both the K75S and K100RS.
