TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: sebas2357 on July 24, 2022, 12:20:49 PM
Title: Plastic On Gas Cap Flaking Off + Exhaust Shield Paint Rusting
Post by: sebas2357 on July 24, 2022, 12:20:49 PM
Greetings again,
It's been quite awhile since I have posted on here. Hope everyone's been alright.
I've got some cosmetic issues going on with my K with the gas cap and exhaust heat shield.  At least for the gas cap, I'm thinking that it could be re-conditioned with line-x? But that would require disassembly no?
Just wondering if anyone has run into the same issues and some recommendations to resolve them. I have attached pictures below.
Thanks,
Seb
Title: Re: Plastic On Gas Cap Flaking Off + Exhaust Shield Paint Rusting
Post by: frankenduck on July 24, 2022, 06:17:59 PM
I'd do ceramic coating on the heat shield.
If you don't have a local vendor I use these guys:
https://www.performancecoatings.com/
Post by: sebas2357 on July 25, 2022, 05:01:20 PM
Thanks for the suggestion Duck, I've reached out to some local places to see what they would charge for the shield. Any suggestions on the gas cap by chance?
Post by: frankenduck on July 25, 2022, 05:50:43 PM
Gas cap:
I've done a gas cap in Line-X.  But it was the later style gas cap without the pushable button in the middle like the early K100s have. The button would complicate matters if doing Line-X.
Another option is chrome. I didn't do this. I bought it on Ebay.
(http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k75pa.rehab/k75parehabpics/K75PA.1985.Chromed.Gas.Cap.jpg)
You need a good roll pin punch to get the roll pin out of the hinge in order to take the top and bottom apart. It's in there pretty tightly.
Post by: Martin on July 25, 2022, 07:00:39 PM
You could always replace it with the later version cap.
Post by: frankenduck on July 25, 2022, 08:59:59 PM
What he said.
If you bought a later one in good condition then you wouldn't have to worry about refinishing it. And from what I've seen the finish on the later ones tends to hold up better as well.
It's also pretty easy to "rekey" the newer style gas caps to work with your ignition key.
Post by: sebas2357 on July 28, 2022, 10:09:34 PM
Aesthetically, I like the push-type gas cap more than the later year type. Seeing what the later type gas cap run for, I think I'm going to dissamble the cap and find a local place that can re-finish the cap.
Thank you for your input everyone, I appreciate it.
Kindly,
Seb
Post by: sebas2357 on January 07, 2023, 05:37:45 PM
Hey again,
I finally got around to ceramic coating my heat shield and wanted to show everyone the results. I think it came out pretty good!
Thanks duck for suggesting the ceramic coating, bike looks amazing now.
Best,
Seb
