TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: JimVonBaden on July 08, 2022, 11:20:56 PM
Title: 95 K75 Kafe' Racer Project.
Post by: JimVonBaden on July 08, 2022, 11:20:56 PM
I picked this up last weekend. It is a 1995 K75RT with 91K miles on it that sat in a field for the last 13 years. It runs, and not bad, but it is really rough.
The pick-up:
(https://imagizer.imageshack.com/v2/1280x1024q90/923/voHKG3.jpg) (https://imageshack.com/i/pnvoHKG3j)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/8BAml0.jpg) (https://imageshack.com/i/po8BAml0j)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/ZDidDm.jpg) (https://imageshack.com/i/poZDidDmj)
Back in the shop:
(https://imagizer.imageshack.com/v2/1280x1024q90/924/0PlMyv.jpg) (https://imageshack.com/i/po0PlMyvj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/a5tmea.jpg) (https://imageshack.com/i/pma5tmeaj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/D2wTnF.jpg) (https://imageshack.com/i/poD2wTnFj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/9eTJDL.jpg) (https://imageshack.com/i/pn9eTJDLj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/s4siaB.jpg) (https://imageshack.com/i/pos4siaBj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/L11dnf.jpg) (https://imageshack.com/i/poL11dnfj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/McPa2Y.jpg) (https://imageshack.com/i/pnMcPa2Yj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/C48oIA.jpg) (https://imageshack.com/i/pnC48oIAj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/1tMYzI.jpg) (https://imageshack.com/i/pm1tMYzIj)
Tear down:
(https://imagizer.imageshack.com/v2/1280x1024q90/923/mtQvEN.jpg) (https://imageshack.com/i/pnmtQvENj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/b4rv81.jpg) (https://imageshack.com/i/pob4rv81j)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/VTdku7.jpg) (https://imageshack.com/i/poVTdku7j)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/T6F2YZ.jpg) (https://imageshack.com/i/pnT6F2YZj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/tpaDgl.jpg) (https://imageshack.com/i/potpaDglj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/QWXJUA.jpg) (https://imageshack.com/i/pnQWXJUAj)
Pile-O-Parts to dispose of:
(https://imagizer.imageshack.com/v2/1280x1024q90/922/DbofVe.jpg) (https://imageshack.com/i/pmDbofVej)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/TJDTni.jpg) (https://imageshack.com/i/poTJDTnij)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/UPpJYc.jpg) (https://imageshack.com/i/pnUPpJYcj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/c0YtHF.jpg) (https://imageshack.com/i/pmc0YtHFj)
This will take a few months to finish, but it should be a fun project. I plan to tear it down and lube the splines and replace all the bad parts!
Title: Re: 95 K75 Kafe' Racer Project.
Post by: JimVonBaden on July 10, 2022, 08:53:13 PM
Received the Kafe' Racer seat today. It is a little small, but I think I can work with it. Need to decide if I am going to use the side panels or not. They would definitely need to be trimmed and augmented.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/4Fltot.jpg) (https://imageshack.com/i/pn4Fltotj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/9lNLtG.jpg) (https://imageshack.com/i/pn9lNLtGj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/JRRs12.jpg) (https://imageshack.com/i/pmJRRs12j)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/B5ISVI.jpg) (https://imageshack.com/i/pmB5ISVIj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/tQQTK6.jpg) (https://imageshack.com/i/pntQQTK6j)
Post by: frankenduck on July 10, 2022, 10:41:05 PM
That "custom" coil cover is a piece of work. :laughing4-giggles:
Post by: JimVonBaden on July 10, 2022, 10:45:28 PM
Yeah, it is not long for this world. I suspect it had a purpose at one time,, but I have no idea what it was.
Post by: Laitch on July 11, 2022, 07:30:30 AM
A coffee cup holder-holder.
Post by: frankenduck on July 11, 2022, 10:22:07 AM
Jim:
Don't throw that coil cover away. I think that I may have a use for it. (Seriously.)
Post by: JimVonBaden on July 11, 2022, 10:39:21 AM
Jim:
No problem. PM me your address and I will send it to you.
Post by: JimVonBaden on July 11, 2022, 10:08:50 PM
Tore out the fairing stay and extra wiring for the RT. It is looking cleaner.
(https://imagizer.imageshack.com/v2/1280x1024q90/922/RRbzdt.jpg) (https://imageshack.com/i/pmRRbzdtj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/rqHC1A.jpg) (https://imageshack.com/i/porqHC1Aj)
Fairing stay is very straight.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/cuEKg7.jpg) (https://imageshack.com/i/pocuEKg7j)
Need to replace all the coolant hoses, and want to get the one that tucks into the hole in the crankcase cover.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/MsXcaW.jpg) (https://imageshack.com/i/pnMsXcaWj)
Like my old K75;
(https://imagizer.imageshack.com/v2/1280x1024q90/923/8zVQgN.jpg) (https://imageshack.com/i/pn8zVQgNj)
Post by: frankenduck on July 11, 2022, 10:52:23 PM
You'll probably need a K75 radiator too.
When der engineers retrofitted the K100RT fairing to a K75 they replaced some K75 parts with K100 parts:
The K75RT has a gas K100 tank which is slightly larger and a tad wider than the K75, C and S tank. (I tink they used the
 K100 tank in order to make the RT inner knee panels easier to fit.)
Since it has a K100 tank it also uses K100 side covers which attach differently than K75, C and S side covers.
It also has a K100 radiator that is slightly larger.  You'll notice that the K75RT's K100 radiator has a bracket at the bottom to push it forward in order to make up for the K75's "missing" front cylinder. This is why the hose goes in front of the crank cover, not through it like the other three K75 models.
Post by: JimVonBaden on July 11, 2022, 10:55:39 PM
I knew about the tank and side covers, not the radiator, though I suspected. So no way to angle it back to make the hose fit?
Post by: frankenduck on July 11, 2022, 11:02:07 PM
It MIGHT be possible. I've never tried it. Since radiator hoses are flexible it may very well be possible. There's one way to find out - try it.
Post by: JimVonBaden on July 11, 2022, 11:06:54 PM
I'll be the tester then. I hate the hose outside the motor like that.
Post by: frankenduck on July 11, 2022, 11:10:52 PM
In case you've never seen this before, here's a good technique for installing the rad hose through the crank cover:
(https://i.imgur.com/ObmwI8t.jpg)
Post by: JimVonBaden on July 11, 2022, 11:13:55 PM
I had totally forgotten about that. Thanks for the reminder. 112350
Post by: Arktasian on July 12, 2022, 10:38:20 AM
Jim:
Jim, that could very well be a vending machine "coin collector", make sure to M/T it before sending it off to F.D.
Post by: JimVonBaden on July 12, 2022, 07:14:35 PM
Looks like the original K75 radiator mounts are still there, so I could mount a K75 radiator, or just tweak these mounts to tilt the radiator properly. More to come on that.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/AY6K0q.jpg) (https://imageshack.com/i/poAY6K0qj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/uwKcb7.jpg) (https://imageshack.com/i/pmuwKcb7j)
Post by: JimVonBaden on July 12, 2022, 07:18:31 PM
Mocked up the headlight and mount. Needs a bit of tweaking. Makes the instrument look HUGE. But I am likely going with a cafe racer fairing to hide it.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/16PXuZ.jpg) (https://imageshack.com/i/po16PXuZj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/EbrWjk.jpg) (https://imageshack.com/i/poEbrWjkj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/b5Utih.jpg) (https://imageshack.com/i/pmb5Utihj)
Post by: frankenduck on July 12, 2022, 09:17:45 PM
Here's a factory cluster with a 7" headlight. (Not a cafe project, just replacing the C faring.)
(http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/nakedheadlight/nakedh9.jpg)
Post by: JimVonBaden on July 13, 2022, 08:33:36 AM
I went 6" so I could fit this on it:
(https://imagizer.imageshack.com/v2/1280x1024q90/922/HsJXrV.jpg) (https://imageshack.com/i/pmHsJXrVj)
Post by: JimVonBaden on July 13, 2022, 08:45:25 PM
Tank removed, and lots of wiring.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/oXmPBi.jpg) (https://imageshack.com/i/pnoXmPBij)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/KZ1XdO.jpg) (https://imageshack.com/i/pmKZ1XdOj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/9AqnUc.jpg) (https://imageshack.com/i/pn9AqnUcj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/kqLMiK.jpg) (https://imageshack.com/i/pokqLMiKj)
Then played with more mock-up of the seat.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/SaHjOJ.jpg) (https://imageshack.com/i/pnSaHjOJj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/09gDpM.jpg) (https://imageshack.com/i/pm09gDpMj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/kCh6K9.jpg) (https://imageshack.com/i/pnkCh6K9j)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/rxzL2P.jpg) (https://imageshack.com/i/pmrxzL2Pj)
New tires arrived.
(https://imagizer.imageshack.com/v2/1280x1024q90/922/bqEkTq.jpg) (https://imageshack.com/i/pmbqEkTqj)
I need to clean up the take-off parts in prep for sale.
(https://imagizer.imageshack.com/v2/1280x1024q90/922/3nLy4U.jpg) (https://imageshack.com/i/pm3nLy4Uj)
Post by: JimVonBaden on July 16, 2022, 03:46:08 PM
Removed the instrument mount to lower the instruments. I will make a new mount to position it about where it is.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/CObxLN.jpg) (https://imageshack.com/i/poCObxLNj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/qfS572.jpg) (https://imageshack.com/i/pmqfS572j)
Sharp eyes might notice new strap-ons. I'll remove the controls, and old bar and riser, and move them to the strap-ons next.
I put the fairing on and think it will work, except for the lower parts. They will need trimming unless I don't want to turn, at all.
(https://imagizer.imageshack.com/v2/1280x1024q90/922/tRhPkD.jpg) (https://imageshack.com/i/pmtRhPkDj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/HEbI40.jpg) (https://imageshack.com/i/poHEbI40j)
I have some ideas for the fairing parts I will remove.  :euro:
Post by: JimVonBaden on July 17, 2022, 04:25:43 PM
Did a little more mocking up. swapped the switchgear to the strap-ons, removed the bar risers, and snugged it all down.  Then I trimmed the fairing roughly, mocked up the mounts and propped all the current pieces on it.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/y3KtkU.jpg) (https://imageshack.com/i/poy3KtkUj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/Nqwm27.jpg) (https://imageshack.com/i/pnNqwm27j)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/jScYDB.jpg) (https://imageshack.com/i/pmjScYDBj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/7m436C.jpg) (https://imageshack.com/i/po7m436Cj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/Ro5FNc.jpg) (https://imageshack.com/i/pnRo5FNcj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/cOrKAJ.jpg) (https://imageshack.com/i/pmcOrKAJj)
Post by: JimVonBaden on July 21, 2022, 10:04:29 PM
Removed the ABS.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/xszQuc.jpg) (https://imageshack.com/i/pnxszQucj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/uG2NSy.jpg) (https://imageshack.com/i/pnuG2NSyj)
Removed whatever this is:
(https://imagizer.imageshack.com/v2/1280x1024q90/923/298Gbu.jpg) (https://imageshack.com/i/pn298Gbuj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/TOaqKm.jpg) (https://imageshack.com/i/poTOaqKmj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/NPbxS1.jpg) (https://imageshack.com/i/pnNPbxS1j)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/npGze1.jpg) (https://imageshack.com/i/pmnpGze1j)
Did some CAD work on the radiator cover:
(https://imagizer.imageshack.com/v2/1280x1024q90/923/udibR8.jpg) (https://imageshack.com/i/pnudibR8j)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/LlcSC4.jpg) (https://imageshack.com/i/pmLlcSC4j)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/0B89ZX.jpg) (https://imageshack.com/i/po0B89ZXj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/7FONGX.jpg) (https://imageshack.com/i/pm7FONGXj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/AflmZ0.jpg) (https://imageshack.com/i/pmAflmZ0j)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/1Clvnz.jpg) (https://imageshack.com/i/po1Clvnzj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/Q8lD4N.jpg) (https://imageshack.com/i/pmQ8lD4Nj)
I have some 1/4" ABS Sheet that I will make it out of. It will let me curve it with heat.
Post by: JimVonBaden on July 23, 2022, 10:58:43 AM
Made a test wing to cover the radiator side. It still needs work, and I learned a lot about bending 1/4" ABS plastic.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/uZDKRs.jpg) (https://imageshack.com/i/pnuZDKRsj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/8ChgXy.jpg) (https://imageshack.com/i/pn8ChgXyj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/vhpDgq.jpg) (https://imageshack.com/i/povhpDgqj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/8BCWfk.jpg) (https://imageshack.com/i/pm8BCWfkj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/Zx2s0G.jpg) (https://imageshack.com/i/pmZx2s0Gj)
I need to work on the bends, but not a bad start.
Post by: frankenduck on July 24, 2022, 06:49:41 PM
What size are your new handlebars? 7/8" or 22mm?
7/8=22.23mm and the throttle/clutch perches have a tight diameter tolerance so they won't fit on most 7/8" bars.
Have you tried to put the throttle/clutch perches on your new handlebars yet?
Post by: JimVonBaden on July 24, 2022, 08:42:16 PM
This is what I used, no issues with sticking.
https://www.amazon.com/dp/B07MLQJ7SS?psc=1&ref=ppx_yo2ov_dt_b_product_details
They have been on for a while.
Post by: frankenduck on July 24, 2022, 09:28:53 PM
That's great. I know others who have had 7/8" handlebar issues and I had some 7/8" Renthal bars once that wouldn't accept K perches.
Post by: frankenduck on July 24, 2022, 09:38:47 PM
It looks like they're from China and are probably 22mm, not 7/8". The title says 7/8" but the description says 22mm and has the weight listed in kg.
Post by: JimVonBaden on July 25, 2022, 09:47:25 PM
Took the big step and cut off the rear frame, after I welded on the hoop and added reinforcement tabs.
(https://imagizer.imageshack.com/v2/1280x1024q90/922/DSNBSo.jpg) (https://imageshack.com/i/pmDSNBSoj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/JDZ9oV.jpg) (https://imageshack.com/i/poJDZ9oVj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/Y0F6hR.jpg) (https://imageshack.com/i/pmY0F6hRj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/7YYhcr.jpg) (https://imageshack.com/i/po7YYhcrj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/VRK5C0.jpg) (https://imageshack.com/i/poVRK5C0j)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/SBiN9l.jpg) (https://imageshack.com/i/poSBiN9lj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/LtGdVE.jpg) (https://imageshack.com/i/pmLtGdVEj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/Z7WQLI.jpg) (https://imageshack.com/i/pmZ7WQLIj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/ibyPYC.jpg) (https://imageshack.com/i/poibyPYCj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/hJAvMr.jpg) (https://imageshack.com/i/pmhJAvMrj)
Then put on the tank and seat to see how they play together.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/oX8mSv.jpg) (https://imageshack.com/i/pooX8mSvj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/hCe3UL.jpg) (https://imageshack.com/i/pnhCe3ULj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/aJqSTN.jpg) (https://imageshack.com/i/pmaJqSTNj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/SOSfr1.jpg) (https://imageshack.com/i/pnSOSfr1j)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/FEuq8T.jpg) (https://imageshack.com/i/pnFEuq8Tj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/mycyzt.jpg) (https://imageshack.com/i/pomycyztj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/qC45Uh.jpg) (https://imageshack.com/i/pnqC45Uhj)
Sharp eyes will note that my welding is not great, but it has improved dramatically. Fortunately none of it is structural.
I'm likeing how it is coming along. Note that the muffler and rear foot peg brackets are not long for this world either.
Post by: JimVonBaden on July 26, 2022, 07:32:49 PM
Minor work done today. Trimmed the inner fender to match the hoop. It should keep the crap off the rest of the internals. I hate wide open as it limits riding.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/ZsxXGb.jpg) (https://imageshack.com/i/poZsxXGbj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/GviDSp.jpg) (https://imageshack.com/i/pmGviDSpj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/r0TEEV.jpg) (https://imageshack.com/i/pnr0TEEVj)
Trying to decide where to put the license plate. Note the light will not be here.
(https://imagizer.imageshack.com/v2/1280x1024q90/922/qX1mqg.jpg) (https://imageshack.com/i/pmqX1mqgj)
Post by: JimVonBaden on July 27, 2022, 08:58:17 PM
Cut some 1/4" ABS for the seat base and fitted it.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/sDSYID.jpg) (https://imageshack.com/i/pnsDSYIDj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/Un1Uvn.jpg) (https://imageshack.com/i/pnUn1Uvnj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/7D5Hnx.jpg) (https://imageshack.com/i/pn7D5Hnxj)
Then trimmed and hammered up the seat support braces:
(https://imagizer.imageshack.com/v2/1280x1024q90/922/fpVBu5.jpg) (https://imageshack.com/i/pmfpVBu5j)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/PlUKpo.jpg) (https://imageshack.com/i/poPlUKpoj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/AIrEvG.jpg) (https://imageshack.com/i/pnAIrEvGj)
This allowed the seat to sit flat and be supported.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/2DEqaY.jpg) (https://imageshack.com/i/pn2DEqaYj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/F58jGM.jpg) (https://imageshack.com/i/poF58jGMj)
Post by: JimVonBaden on July 29, 2022, 09:52:00 AM
Some goodies came in.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/LhxSFk.jpg) (https://imageshack.com/i/pnLhxSFkj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/JGPdfJ.jpg) (https://imageshack.com/i/pmJGPdfJj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/d1EwU7.jpg) (https://imageshack.com/i/pmd1EwU7j)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/qdoxhs.jpg) (https://imageshack.com/i/pmqdoxhsj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/KMnIiO.jpg) (https://imageshack.com/i/poKMnIiOj)
Post by: JimVonBaden on July 29, 2022, 08:24:38 PM
More new goodies came in, side covers, air filter and clutch cable.
Sharp minds will recall my attempt to replicate the side covers. I lost confidence, so ordered some.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/C2Qlu3.jpg) (https://imageshack.com/i/poC2Qlu3j)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/5yQTTQ.jpg) (https://imageshack.com/i/po5yQTTQj)
Temp mounted the mid-pipe and muffler:
(https://imagizer.imageshack.com/v2/1280x1024q90/923/gtCc8k.jpg) (https://imageshack.com/i/pngtCc8kj)
I thought the passenger peg mount was to heavy looking, so:
(https://imagizer.imageshack.com/v2/1280x1024q90/923/J92k6F.jpg) (https://imageshack.com/i/pnJ92k6Fj)
Then remounted the muffler and mid-pipe:
(https://imagizer.imageshack.com/v2/1280x1024q90/922/mxSpqn.jpg) (https://imageshack.com/i/pmmxSpqnj)
Better, but now need a mount for the muffler.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/1HTi3g.jpg) (https://imageshack.com/i/po1HTi3gj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/tOrgJ3.jpg) (https://imageshack.com/i/pntOrgJ3j)
This works.
Lastly, still working on where to put the plate.
(https://imagizer.imageshack.com/v2/1280x1024q90/922/YDVxxI.jpg) (https://imageshack.com/i/pmYDVxxIj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/AMjWlc.jpg) (https://imageshack.com/i/poAMjWlcj)
Post by: frankenduck on July 29, 2022, 09:55:48 PM
What exhaust is that? Is it made to slip right on the the K75's exhaust header collector?
I guess you haven't run the yet bike but do you have any idea of how loud it is?
Does it clear the  center stand when the center stand is up?
Post by: JimVonBaden on July 29, 2022, 09:59:51 PM
This muffler:
https://www.amazon.com/dp/B088GV1KFK?psc=1&ref=ppx_yo2ov_dt_b_product_details
This midpipe:
https://www.amazon.com/dp/B07YCNCW25?psc=1&ref=ppx_yo2ov_dt_b_product_details
A bit of trimming and the adapter fit the DB killer and is all snug.
No idea how loud, but I suspect it is not bad.
I need to add a bumpstop for the sidestand, to the muffler clamp. No idea about the centerstand yet. But I am sure it will clear. No doubt it will need a bumpstop too.
Post by: JimVonBaden on July 30, 2022, 01:33:46 PM
Spent a silly amount of time organizing my garage to get my portable lift free and set up.
(https://imagizer.imageshack.com/v2/1280x1024q90/922/Su1i9h.jpg) (https://imageshack.com/i/pmSu1i9hj)
Pulled the bike out of the shop and put it on the lift, then shoved the lift, with the bike on it, back into the shop.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/IlLIV4.jpg) (https://imageshack.com/i/poIlLIV4j)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/RxM7Sw.jpg) (https://imageshack.com/i/pmRxM7Swj)
Then spent some time vacuuming out the yuck from the airbox, and the rest of the bike.
(https://imagizer.imageshack.com/v2/1280x1024q90/922/svqHJs.jpg) (https://imageshack.com/i/pmsvqHJsj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/zuM18a.jpg) (https://imageshack.com/i/pozuM18aj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/UVrR63.jpg) (https://imageshack.com/i/poUVrR63j)
Sharp eyes may have noticed the destroyed intake pipe. It was frozen on the airbox and required destruction to remove.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/7qomtA.jpg) (https://imageshack.com/i/pn7qomtAj)
Post by: frankenduck on July 30, 2022, 06:09:09 PM
What the heck is that in the airbox? Alligator eggs?
I'll bet that exhaust weighs a bit less than the factory unit.
I found this mouse nest behind the airbox on a K75RT that I helped a friend bring back to life. It looks like the mouse was stockpiling D-Con poison which makes no sense to me.
(https://i.imgur.com/IgfUkpu.jpg)
Post by: Laitch on July 31, 2022, 02:14:18 AM
Glands à la sauce aux merde de souris.
Post by: JimVonBaden on July 31, 2022, 02:32:30 PM
Acorns.
Weighs about 1/4 as much as stock.
Post by: JimVonBaden on August 07, 2022, 10:15:28 AM
Got a little work done, not pretty, but the seat is now functionally attached.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/O9SjDP.jpg) (https://imageshack.com/i/poO9SjDPj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/XUjknL.jpg) (https://imageshack.com/i/pmXUjknLj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/aeWeYU.jpg) (https://imageshack.com/i/poaeWeYUj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/Gfijb4.jpg) (https://imageshack.com/i/pnGfijb4j)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/6TwLZ9.jpg) (https://imageshack.com/i/pm6TwLZ9j)
Also cut and relocated the lower radiator support to tilt it out of the RT angle to the C angle.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/r7fRso.jpg) (https://imageshack.com/i/por7fRsoj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/Q2M58q.jpg) (https://imageshack.com/i/poQ2M58qj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/v4Qw9R.jpg) (https://imageshack.com/i/pmv4Qw9Rj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/dCCSpF.jpg) (https://imageshack.com/i/pndCCSpFj)
Post by: frankenduck on August 07, 2022, 11:11:31 AM
Before hooking up and filling the radiator, it's a good time to jump 12V to the radiator fan (violet/yellow & brown connector) to make sure that it still works. Replacing it now would be easier than replacing it later.
Post by: The Mighty Gryphon on August 07, 2022, 12:07:55 PM
Just curious, but why didn't you at least rinse off the bike before starting to work on it?  Are you building a rat bike?
Personally I hate doing anything on a dirty machine, and the first job with any "new" bike is a good cleaning, followed by detailing every part that I touch for repair or restoration.  For me anyway, working on a clean bike inspires a higher level of craftsmanship.
I guess it's different strokes for different folks.
Post by: JimVonBaden on August 07, 2022, 02:46:07 PM
Definitely a good idea!
Post by: JimVonBaden on August 07, 2022, 02:48:13 PM
I would have, but the day I picked it up it was scorching hot, and once I started removing plastics to get to the parts that needed cleaning I just kept going. In the end I will have to split the bike for the spline lube anyhow, so I will clean it then.
Post by: JimVonBaden on August 09, 2022, 12:51:42 PM
Received a few parts from Germany, and did a little clean-up.
Parts:
(https://imagizer.imageshack.com/v2/1280x1024q90/923/RZZPX7.jpg) (https://imageshack.com/i/pnRZZPX7j)
Before:
(https://imagizer.imageshack.com/v2/1280x1024q90/924/jsckT6.jpg) (https://imageshack.com/i/pojsckT6j)
After:
(https://imagizer.imageshack.com/v2/1280x1024q90/922/TamWLc.jpg) (https://imageshack.com/i/pmTamWLcj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/SMqePj.jpg) (https://imageshack.com/i/pnSMqePjj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/eJUsXe.jpg) (https://imageshack.com/i/pmeJUsXej)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/eR0DNg.jpg) (https://imageshack.com/i/pneR0DNgj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/rmrMWk.jpg) (https://imageshack.com/i/pmrmrMWkj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/FpoRDl.jpg) (https://imageshack.com/i/pmFpoRDlj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/aS7tNB.jpg) (https://imageshack.com/i/poaS7tNBj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/m6mSqf.jpg) (https://imageshack.com/i/pnm6mSqfj)
Not done, but now I don't get dirty just looking at it!
Post by: JimVonBaden on August 23, 2022, 03:50:51 PM
More or less a non-update. I've continued to strip off a lot of little stuff, refine some stuff, not really picture worthy. I have family visiting, so I needed to clean up the shop (it desperately needed it anyhow), so I will get back on the project next week.
(https://imagizer.imageshack.com/v2/1280x1024q90/924/8PONCR.jpg) (https://imageshack.com/i/po8PONCRj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/B6ntqU.jpg) (https://imageshack.com/i/poB6ntqUj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/z7Fq7N.jpg) (https://imageshack.com/i/pmz7Fq7Nj)
Post by: JimVonBaden on September 04, 2022, 11:03:00 PM
Found an interesting situation that I only have seen on R-Bikes. The front brake master cylinder appeared locked up, even with the calipers removed. Surely this must mean a bad master cylinder? Nope, the brake line from the Master Cylinder was completely blocked. Once removed, the master cylinder acted normal. Good news for me!
Post by: frankenduck on September 08, 2022, 12:41:33 PM
Here's what I do for a straight hose from the master to the right caliper:
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/2vbrakes/2vbrakes.htm
Post by: JimVonBaden on October 01, 2022, 10:16:27 PM
Finally had time to get back to the project. I wanted to check the seals and splines, so removed the swingarm, then the transmission. Fortunately the splines look good. There is significant corrosion on the clutch components, but the clutch friction plate looks great. I will address the rust, and lube the splines. and reassemble the trans and final drive. The swingarm pivot pins look great!
(https://imagizer.imageshack.com/v2/1280x1024q90/924/t49Clv.jpg) (https://imageshack.com/i/pot49Clvj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/bbvMKA.jpg) (https://imageshack.com/i/pmbbvMKAj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/qyjE2E.jpg) (https://imageshack.com/i/poqyjE2Ej)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/fROc9p.jpg) (https://imageshack.com/i/pmfROc9pj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/TagjXl.jpg) (https://imageshack.com/i/pmTagjXlj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/2OL6kA.jpg) (https://imageshack.com/i/po2OL6kAj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/xZWINv.jpg) (https://imageshack.com/i/pmxZWINvj)
Post by: JimVonBaden on October 03, 2022, 11:46:27 PM
Just a bit more.
(https://imagizer.imageshack.com/v2/1280x1024q90/923/twE0HK.jpg) (https://imageshack.com/i/pntwE0HKj)
(https://imagizer.imageshack.com/v2/1280x1024q90/922/sHrann.jpg) (https://imageshack.com/i/pmsHrannj)
Post by: frankenduck on October 15, 2022, 08:35:56 AM
All of that spray paint is going to throw the clutch assembly out of balance. :laughing4-giggles:
Did you consider getting it media blasted?
Post by: JimVonBaden on October 15, 2022, 09:16:31 AM
I didn't even consider removing it. I don't have an alignment tool, and it is not going to hurt anything anyhow.
Post by: frankenduck on October 15, 2022, 10:29:33 AM
You don't need the alignment tool. (I have one and don't use it.)
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/clutchnospecial/clutchnospecial.htm
If it were me, on a bike with that many miles, while I have the trans off, I'd pull the clutch apart just to measure the clutch plate so that if it's near the end of it's life then I could replace it (or at least know how much life is left.) Min spec is 4.5mm. New is 5.55.
It might also not be a bad idea to replace the clutch nut O-ring with a Viton one. (19x4)
The six bolts around the perimeter that hold the clutch together can be sticky. Use heat and a good Allen wrench when removing them. They have shallow heads and can strip if you're not careful. DAMHIK :laughing1:
IN THEORY, you're supposed to replace those six bolts and their lock washers with new but I re-use the old ones and it's never been an issue.
A mini nail puller can be used around the perimeter to pry the clutch apart:
https://www.ebay.com/itm/254451833276
Post by: JimVonBaden on November 30, 2022, 11:07:23 PM
Project is on hold as I refurb a flipper Kawasaki Versys.
https://www.kawasakiversys.com/threads/barnish-find-2009-versys-650.229136/unread
(https://imagizer.imageshack.com/v2/1280x1024q90/923/l8jAPo.jpg) (https://imageshack.com/i/pnl8jAPoj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/zvj4Wf.jpg) (https://imageshack.com/i/pnzvj4Wfj)
(https://imagizer.imageshack.com/v2/1280x1024q90/924/qm2YIl.jpg) (https://imageshack.com/i/poqm2YIlj)
I should be back to it before Christmas.
Post by: JimVonBaden on December 01, 2022, 11:32:48 PM
Tire day coming up. Versys, GS and Kafe'
(https://imagizer.imageshack.com/v2/1280x1024q90/924/Nk4KIu.jpg) (https://imageshack.com/i/poNk4KIuj)
(https://imagizer.imageshack.com/v2/1280x1024q90/923/fSBwHM.jpg) (https://imageshack.com/i/pnfSBwHMj)
Post by: JimVonBaden on April 20, 2023, 11:11:16 PM
Back on the K.
Cutting, grinding, painting the frame and mild fab.
(https://imagizer.imageshack.com/v2/1280x1024q70/922/fpVBu5.jpg) (https://imageshack.com/i/pmfpVBu5j)
(https://imagizer.imageshack.com/v2/1280x1024q70/923/LhxSFk.jpg) (https://imageshack.com/i/pnLhxSFkj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/C2Qlu3.jpg) (https://imageshack.com/i/poC2Qlu3j)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/1HTi3g.jpg) (https://imageshack.com/i/po1HTi3gj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/O9SjDP.jpg) (https://imageshack.com/i/poO9SjDPj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/aeWeYU.jpg) (https://imageshack.com/i/poaeWeYUj)
(https://imagizer.imageshack.com/v2/1280x1024q70/923/RZZPX7.jpg) (https://imageshack.com/i/pnRZZPX7j)
Continued...
Post by: JimVonBaden on April 20, 2023, 11:13:20 PM
(https://imagizer.imageshack.com/v2/1280x1024q70/924/jsckT6.jpg) (https://imageshack.com/i/pojsckT6j)
(https://imagizer.imageshack.com/v2/1280x1024q70/922/JvQLVv.jpg) (https://imageshack.com/i/pmJvQLVvj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/JpHxdA.jpg) (https://imageshack.com/i/poJpHxdAj)
(https://imagizer.imageshack.com/v2/1280x1024q70/923/h1qgLF.jpg) (https://imageshack.com/i/pnh1qgLFj)
(https://imagizer.imageshack.com/v2/1280x1024q70/922/EmVo7W.jpg) (https://imageshack.com/i/pmEmVo7Wj)
Engine looks like new compared to the miles.
(https://imagizer.imageshack.com/v2/1280x1024q70/923/ZPsiNW.jpg) (https://imageshack.com/i/pnZPsiNWj)
(https://imagizer.imageshack.com/v2/1280x1024q70/922/yxLnFp.jpg) (https://imageshack.com/i/pmyxLnFpj)
Post by: JimVonBaden on April 20, 2023, 11:14:41 PM
Some reassembly. Looking pretty good.
(https://imagizer.imageshack.com/v2/1280x1024q70/923/Ejb2RP.jpg) (https://imageshack.com/i/pnEjb2RPj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/UyDJ8A.jpg) (https://imageshack.com/i/poUyDJ8Aj)
(https://imagizer.imageshack.com/v2/1280x1024q70/922/yCzUCe.jpg) (https://imageshack.com/i/pmyCzUCej)
(https://imagizer.imageshack.com/v2/1280x1024q70/923/Vhbbi1.jpg) (https://imageshack.com/i/pnVhbbi1j)
(https://imagizer.imageshack.com/v2/1280x1024q70/922/hIY6Wv.jpg) (https://imageshack.com/i/pmhIY6Wvj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/xMhXYL.jpg) (https://imageshack.com/i/poxMhXYLj)
(https://imagizer.imageshack.com/v2/1280x1024q70/922/421wbN.jpg) (https://imageshack.com/i/pm421wbNj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/2Xd4bi.jpg) (https://imageshack.com/i/po2Xd4bij)
Post by: JimVonBaden on April 23, 2023, 01:12:08 AM
Just a little mock up touch-up while cleaning and sealing my garage floor.
(https://imagizer.imageshack.com/v2/1280x1024q70/924/AWV7nA.jpg) (https://imageshack.com/i/poAWV7nAj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/NHQBqI.jpg) (https://imageshack.com/i/poNHQBqIj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/CfOX2g.jpg) (https://imageshack.com/i/poCfOX2gj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/IqsZww.jpg) (https://imageshack.com/i/poIqsZwwj)
(https://imagizer.imageshack.com/v2/1280x1024q70/924/xJ9UZ6.jpg) (https://imageshack.com/i/poxJ9UZ6j)
Post by: JimVonBaden on June 24, 2023, 04:12:26 PM
Changed direction on the fender. I didn't like the straps, so I filled the holes and made brackets to mount the fender under the mounts.
(https://imagizer.imageshack.com/v2/1600x1200q70/923/3UkMgT.jpg) (https://imageshack.com/i/pn3UkMgTj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/K9XlHS.jpg) (https://imageshack.com/i/pnK9XlHSj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/BZBlMA.jpg) (https://imageshack.com/i/pmBZBlMAj)
Finished up the headlight/fairing mount:
(https://imagizer.imageshack.com/v2/1600x1200q70/922/7l5VME.jpg) (https://imageshack.com/i/pm7l5VMEj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/dkXJbY.jpg) (https://imageshack.com/i/pmdkXJbYj)
Added a stabilizer bracket to the instrument cluster:
(https://imagizer.imageshack.com/v2/1600x1200q70/923/Hv2pKJ.jpg) (https://imageshack.com/i/pnHv2pKJj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/2nWeq1.jpg) (https://imageshack.com/i/pm2nWeq1j)
Removed the front wheel for paint:
(https://imagizer.imageshack.com/v2/1600x1200q70/922/y9xu7q.jpg) (https://imageshack.com/i/pmy9xu7qj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/7NvZGl.jpg) (https://imageshack.com/i/pm7NvZGlj)
Started prepping for paint:
(https://imagizer.imageshack.com/v2/1600x1200q70/922/7ON0Oc.jpg) (https://imageshack.com/i/pm7ON0Ocj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/X64OQb.jpg) (https://imageshack.com/i/pnX64OQbj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/MFda8f.jpg) (https://imageshack.com/i/pmMFda8fj)
Post by: JimVonBaden on June 28, 2023, 11:42:07 PM
Still working the paint prep, between travels.
(https://imagizer.imageshack.com/v2/1600x1200q70/924/wemhxq.jpg) (https://imageshack.com/i/powemhxqj)
Post by: JimVonBaden on July 03, 2023, 07:44:03 PM
Getting close to paint, likely tomorrow if the weather cooperates!
(https://imagizer.imageshack.com/v2/1600x1200q70/923/TMRJdl.jpg) (https://imageshack.com/i/pnTMRJdlj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/wlbWS4.jpg) (https://imageshack.com/i/pnwlbWS4j)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/R4wxAS.jpg) (https://imageshack.com/i/pnR4wxASj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/Whuaed.jpg) (https://imageshack.com/i/pmWhuaedj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/XoFkr8.jpg) (https://imageshack.com/i/poXoFkr8j)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/6fjhk6.jpg) (https://imageshack.com/i/pn6fjhk6j)
Post by: JimVonBaden on July 04, 2023, 02:02:28 PM
Paint done. Primer first!
(https://imagizer.imageshack.com/v2/1600x1200q70/923/n8f4S3.jpg) (https://imageshack.com/i/pnn8f4S3j)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/ocCfIG.jpg) (https://imageshack.com/i/pnocCfIGj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/0UmI0C.jpg) (https://imageshack.com/i/po0UmI0Cj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/WwT5LT.jpg) (https://imageshack.com/i/poWwT5LTj)
Next color, root beer.
(https://imagizer.imageshack.com/v2/1600x1200q70/924/C1PsEh.jpg) (https://imageshack.com/i/poC1PsEhj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/iHm7St.jpg) (https://imageshack.com/i/poiHm7Stj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/VeAohb.jpg) (https://imageshack.com/i/pnVeAohbj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/gmnMtL.jpg) (https://imageshack.com/i/pngmnMtLj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/UEcKzp.jpg) (https://imageshack.com/i/pnUEcKzpj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/EPNGFd.jpg) (https://imageshack.com/i/pnEPNGFdj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/sEdJL8.jpg) (https://imageshack.com/i/pnsEdJL8j)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/BhtNLn.jpg) (https://imageshack.com/i/pmBhtNLnj)
Then Clear:
(https://imagizer.imageshack.com/v2/1600x1200q70/924/usfH7J.jpg) (https://imageshack.com/i/pousfH7Jj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/i0h5qd.jpg) (https://imageshack.com/i/pni0h5qdj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/l8TLpl.jpg) (https://imageshack.com/i/pnl8TLplj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/hxp7ic.jpg) (https://imageshack.com/i/pnhxp7icj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/1BxID8.jpg) (https://imageshack.com/i/pm1BxID8j)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/DmmbQq.jpg) (https://imageshack.com/i/pnDmmbQqj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/eeIv2s.jpg) (https://imageshack.com/i/pmeeIv2sj)
Lots left to do, but am on the home stretch.
Post by: Laitch on July 05, 2023, 11:09:05 AM
Helpful setup details in those photos, Jim. 112350
Post by: JimVonBaden on July 08, 2023, 09:58:06 AM
A little more progress. Trim on the edges, screen on, seat assembled, valves in the rims.
(https://imagizer.imageshack.com/v2/1600x1200q70/923/oyGYOr.jpg) (https://imageshack.com/i/pnoyGYOrj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/SGZW1A.jpg) (https://imageshack.com/i/poSGZW1Aj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/xzz5B0.jpg) (https://imageshack.com/i/poxzz5B0j)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/RSOFWG.jpg) (https://imageshack.com/i/pnRSOFWGj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/gSXzLe.jpg) (https://imageshack.com/i/pngSXzLej)
Today I wire all the lights and finish the hoses.
Post by: JimVonBaden on July 08, 2023, 10:57:03 PM
Wired up the rear lights and installed the inner fender, then the tail light. It is all surprisingly bright.
(https://imagizer.imageshack.com/v2/1600x1200q70/924/nATuqy.jpg) (https://imageshack.com/i/ponATuqyj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/IpVRP5.jpg) (https://imageshack.com/i/pnIpVRP5j)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/DdP9Fz.jpg) (https://imageshack.com/i/pnDdP9Fzj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/zrfiBC.jpg) (https://imageshack.com/i/pozrfiBCj)
Post by: JimVonBaden on July 12, 2023, 08:19:37 AM
Finally off the lift and back on wheels, (what a pain that was doing alone). Mostly mock assembly. Still a lot to do.
(https://imagizer.imageshack.com/v2/1600x1200q70/923/tqv6g0.jpg) (https://imageshack.com/i/pntqv6g0j)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/LwRlH1.jpg) (https://imageshack.com/i/pmLwRlH1j)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/gNVJD4.jpg) (https://imageshack.com/i/pogNVJD4j)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/XYiv3l.jpg) (https://imageshack.com/i/pnXYiv3lj)
Post by: AtLarge on July 12, 2023, 10:25:15 AM
Well done!   :twothumbsupp
Post by: JimVonBaden on July 14, 2023, 09:15:53 AM
A few minor things done. Also finally got the lower radiator hose through the hole in the crank case cover, PITA!
(https://imagizer.imageshack.com/v2/1600x1200q70/923/Rd0sZB.jpg) (https://imageshack.com/i/pnRd0sZBj)
Had to reuse the left side upper radiator hose, the replacement was too short.
(https://imagizer.imageshack.com/v2/1600x1200q70/922/c8PPdQ.jpg) (https://imageshack.com/i/pmc8PPdQj)
Added the new SS brake lines. Not happy with the front, too tight. This is full extension and has a bit of slack, but not as much as I would prefer.
(https://imagizer.imageshack.com/v2/1600x1200q70/924/ZzBnUC.jpg) (https://imageshack.com/i/poZzBnUCj)
The rear wasn't much better, but will do. These were for a K75C according to the seller, so should have been a better fit.
(https://imagizer.imageshack.com/v2/1600x1200q70/922/6dPYPE.jpg) (https://imageshack.com/i/pm6dPYPEj)
Much more to go.
Post by: Laitch on July 14, 2023, 10:00:25 AM
It was never intended to go through the cover on a K75RT. I can imagine the conflict echoing through your shop. Submit! Submit! YOU WILL SUBMIT!  :laughing4-giggles: Ok, ok, man. Chill.
Post by: JimVonBaden on July 14, 2023, 10:05:03 AM
For sure. However, if you remove the wire bracket and tilt the radiator back to the original position, it allows it to be done.
(https://imagizer.imageshack.com/v2/1600x1200q70/924/AY6K0q.jpg) (https://imageshack.com/i/poAY6K0qj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/Q2M58q.jpg) (https://imageshack.com/i/poQ2M58qj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/v4Qw9R.jpg) (https://imageshack.com/i/pmv4Qw9Rj)
Post by: JimVonBaden on July 16, 2023, 08:52:19 PM
Brakes, side panels, and small bits done.
(https://imagizer.imageshack.com/v2/1600x1200q70/923/4jEhP1.jpg) (https://imageshack.com/i/pn4jEhP1j)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/dfz3kJ.jpg) (https://imageshack.com/i/podfz3kJj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/KcFKVj.jpg) (https://imageshack.com/i/poKcFKVjj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/aBLStW.jpg) (https://imageshack.com/i/poaBLStWj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/IEOvfI.jpg) (https://imageshack.com/i/pnIEOvfIj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/eUeWYw.jpg) (https://imageshack.com/i/pneUeWYwj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/lcBKjH.jpg) (https://imageshack.com/i/pmlcBKjHj)
Runs great:
https://youtu.be/6y9Iq3N72vU
Post by: JimVonBaden on July 19, 2023, 08:52:34 AM
Dug it out of the shop and took it for a short ride. Everything works and it rides fine.
A couple of glamor shots then put it away with the others until I get the mirrors and new ignition switch.
(https://imagizer.imageshack.com/v2/1600x1200q70/924/Sudv2K.jpg) (https://imageshack.com/i/poSudv2Kj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/ipppDM.jpg) (https://imageshack.com/i/pmipppDMj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/Njjahu.jpg) (https://imageshack.com/i/poNjjahuj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/PP67jx.jpg) (https://imageshack.com/i/pnPP67jxj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/s8i2tF.jpg) (https://imageshack.com/i/pos8i2tFj)
Post by: The Mighty Gryphon on July 19, 2023, 09:13:12 AM
Normally, I don't like cafe conversions.  I consider them hacked up and ruined machines, but your bike seems to get it right.  I really like the fairing which works nicely with the OEM "lunchbox" instruments.  The color scheme of the paint work goes well with the blacked out mechanicals.  Even the seat, which makes my a$$ cringe, looks good with the overall lines of the bike.
I also like that your photos avoid the macho "urban warrior" theme with the graffiti covered dumpster surrounded by garbage and empty beer cans.  That cliche is such a gay joke. (Not that there's anything wrong with that.)
All in all, very nicely done!  You have a true gentleman's cafe bike.  It would go well with a tweed jacket and corduroy slacks.
Post by: JimVonBaden on July 19, 2023, 09:56:45 AM
Thanks, I have never been a good Cafe Racer fan. They often look contrived and or trash art more than functional. To be fair, I wouldn't want to ride this far. The riding position and handlebars don't work well with my 60 year old back and large tummy. That said, it rides pretty good and has all the stuff to make it legal and a generally all weather bike.
As for the instruments, yeah, I considered a different cluster, but the cost and reduced functionality weren't in the cards for a bike I never really intended to keep.
I has been a fun project though, and I will likely sell it for just enough to break even given the higher miles on it.
Post by: JimVonBaden on July 21, 2023, 02:53:00 PM
Added adjustable mirrors and a new ignition switch. Now ready to ride a bit.
(https://imagizer.imageshack.com/v2/1600x1200q70/922/vjZBWL.jpg) (https://imageshack.com/i/pmvjZBWLj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/7VD91W.jpg) (https://imageshack.com/i/pm7VD91Wj)
Post by: JimVonBaden on July 25, 2023, 09:39:55 AM
Cleaned up. Some pretty shots.
(https://imagizer.imageshack.com/v2/1600x1200q70/924/cwLwDy.jpg) (https://imageshack.com/i/pocwLwDyj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/aUzcXf.jpg) (https://imageshack.com/i/pnaUzcXfj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/6ZdQOC.jpg) (https://imageshack.com/i/pn6ZdQOCj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/wDk04W.jpg) (https://imageshack.com/i/pnwDk04Wj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/E7ReLi.jpg) (https://imageshack.com/i/poE7ReLij)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/tkkt4O.jpg) (https://imageshack.com/i/potkkt4Oj)
(https://imagizer.imageshack.com/v2/1600x1200q70/924/9sc04y.jpg) (https://imageshack.com/i/po9sc04yj)
(https://imagizer.imageshack.com/v2/1600x1200q70/923/eJOgTY.jpg) (https://imageshack.com/i/pneJOgTYj)
(https://imagizer.imageshack.com/v2/1600x1200q70/922/Dfoee1.jpg) (https://imageshack.com/i/pmDfoee1j)
Waiting on a couple decals for the side panels and it is done.
