TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: FlatSix on May 31, 2022, 08:26:34 PM
Title: Coil might be bad
Post by: FlatSix on May 31, 2022, 08:26:34 PM
Gents,
Went for a ride with the wife (a month ago before it got blazing hot) and it was barely running.  Quick turnaround (wife not pleased) and parked the brick.  Last ride before that it started fine but seemed to be running rough by the time I got home.  I suppose it didn't magically fix itself.
Removed the plastics to get a good look at things to see what's up.  You know...just the usual, hey maybe something fell off or something.  No obvious missing parts.  Bummer.  Perhaps an air leak (I visually checked but didn't get around to testing with propane) but nearly every rubber part is newish.  Pulled the plugs and they looked good.  Got out the multi-meter to make sure the coils were giving me the juice and got some unexpected readings so I pulled them off the bike to make sure I tested them properly.
Looks like one for sure and possibly both might be bad.  Is 10.72 ohms serviceable for 2 - 3 coil or is it bad too?  It's not easy to get readings on the high voltage side but I happen to have some long probes  :laughing1: and I assure you they were making contact....I promise!
And what kind of junk coil fails after only 35 years? :idunno:
Dave in TX
Title: Re: Coil might be bad
Post by: Laitch on May 31, 2022, 09:02:20 PM
Is 10.72 ohms serviceable for 2 - 3 coil or is it bad too? :
10.72Ω or 10.72kΩ?
Post by: frankenduck on May 31, 2022, 09:21:19 PM
Looks like you have first gen coils.  I'd replace both of them with a good pair of used second gen coils.
Post by: The Mighty Gryphon on May 31, 2022, 09:38:57 PM
+1  The early coils had a problem with insulation breakdown.  Used 2nd generation coils are almost bulletproof.
Post by: frankenduck on May 31, 2022, 09:57:01 PM
If you're looking on Ebay or wherever for coils then it's easy to tell first gen K100 coils from second gen coils. The spark plug lead terminals are orange instead of dark gray.
(https://i.imgur.com/Q16K7Aa.jpg)
Post by: FlatSix on May 31, 2022, 10:06:54 PM
10.72Ω or 10.72kΩ?
Haha!  It's the "K" version of course...my bad.
Post by: FlatSix on May 31, 2022, 10:10:41 PM
Duly noted sirs.  Thanks for the help.  I will be on the lookout for a set of newer second gen ones.  The "new" ones at Max are pretty pricey and not sure if they can even be had.  Yikes.
Post by: Laitch on May 31, 2022, 10:52:43 PM
For the record, here is an extract from the compelling literary work, BMW Diagnose–Testing for K Models, which tells us that one of the coils is OK— until it isn't, which essentially is a description of the general condition of humanity, too.  :laughing4-giggles:
Post by: FlatSix on June 01, 2022, 09:44:47 AM
Thanks Laitch that is very helpful.  The "Troubleshooting Guide" I have saved on my computer just shows the High Voltage segment of the coil should test about 12.6K ohms.  I should be able to get on the road quicker if need be with only one coil.
I do think I am going to try and get two newer version good ones if I can find them.  My objective in rebuilding this bike was to make it as reliable as possible by replacing or upgrading any potential wear items.  The coils were one of those items that I should have just bought new when I put it together.  $$$  You live, you learn.
Post by: FlatSix on June 01, 2022, 11:53:54 AM
Follow up:  Can the coil, part number 12131459890 be used, if the wiring can be adapted?  Looks like it uses a different plug.
Post by: The Mighty Gryphon on June 01, 2022, 12:13:48 PM
That coil is from the K1100 and works with the Motronic system.  Your bike has the Jetronic, and the ignition signals may not be the same.  I would go with a K100 coil to be sure it will work and not damage anything.
https://www.ebay.com/itm/123719811660?fits=Make%3ABMW&hash=item1cce46824c%3Ag%3AITgAAOSwtfhYrLkM&LH_ItemCondition=4
Post by: FlatSix on June 01, 2022, 02:22:29 PM
Thanks TMG, I will stay with what I know works.  The link you sent...that coil has a different plug than mine as well.
Post by: beemuker on June 01, 2022, 02:58:33 PM
List says compatible with K100RS, not 100LT. only 1100lt. keep looking. I just got one for $50 for my R1100.
Post by: Laitch on June 01, 2022, 03:27:43 PM
The list is referring to the 4V version of the RS, not the 2V.
Post by: The Mighty Gryphon on June 01, 2022, 03:35:13 PM
Doh!  The coil I linked is for the Motronic system.  Don't use it.  I don't know what I was thinking when I looked at the listing.
Post by: FlatSix on June 01, 2022, 03:53:36 PM
Thanks guys.  I am on the hunt.
Post by: Duckbubbles on June 02, 2022, 06:46:59 AM
I am using the stock coils on my '85 K100RS with a '93 K1100LT Motronic.  Had to modify the ignition leads to plug into the earlier coils.  I believe the difference between early and late coils is the way the trigger leads attach.  The early coils use separate blade connectors while the later coils use a two pin plug.
Frank
Post by: Laitch on June 02, 2022, 07:54:14 AM
I believe the difference between early and late coils is the way the trigger leads attach. .  .
Another difference is that K1100 4V coils have 0.5Ω primary resistance and ≈13.5kΩ secondary resistance, compared with ≈2.5Ω primary resistance and ≈10.5kΩ secondary resistance in the 2V coils. What you've done is used coils in your K1002V appropriate for use with the Motronic in your 2V. Using them with a Jetronic ECU might have a different result, as indicated by this observation.
I'd be careful about using coils with a lower primary resistance.  This will cause more current to be drawn through the ICU drivers, and possibly destroy the ICU (as the drivers will overheat).
Post by: Duckbubbles on June 02, 2022, 12:32:41 PM
I did no research on the differences in the coils.  I've been using my original '85 coils on my '85 RS while running a '93 K1100LT engine, Motronic, airbox, engine harness, O2 sensor and adapted the '85 bike wiring harness to run the Motronic..  The conversion was done (by me) 19 years and 50,000 miles ago.
Picked up the engine and systems from a salvage yard and probably should have gotten the coils, too.  Wouldn't have had to replace the coil trigger plugs.
Frank
Post by: FlatSix on June 02, 2022, 02:18:26 PM
Frank
It is good to hear you haven't had any issues with this setup, fellow Texan.
In looking for the newer versions of the coil I need I received disheartening news when inquiring about new ones:  "Unfortunately these coils are discontinued by BOSCH and BMW with no aftermarket option available.  We have sold the last of our inventory and will not be able to replace them."
I have not yet exhausted my search.
There must be someone smart with this electrical wizardly that can figure out how to use an alternative coil.
Dave
Post by: The Mighty Gryphon on June 02, 2022, 02:59:24 PM
Just for laughs, you might want to place an order for p/n  12 13 1 459 513 from MaxBMW.  Their website doesn't show it as not available so maybe there are still some around.
It's going to be a bit pricey at $242, but there is no shipping or sales tax.
Post by: FlatSix on June 02, 2022, 03:02:24 PM
I'm ahead you there TMG...waiting to hear back and hoping for good news.
Post by: FlatSix on June 03, 2022, 11:19:13 AM
No joy.  I will post in the WTB section to see if there are any out there.
Post by: Laitch on June 03, 2022, 12:22:33 PM
No joy.
Does that mean Max didn't respond to you, they responded that none are available, they responded that there was a long waiting period before you'd get one, or that you're just despondent in general?
Post by: Duckbubbles on June 03, 2022, 12:42:26 PM
There used to be two motorcycle salvage yards within 100 miles of me- both are long gone.
The last gasp option might be adapting coils from another brand of four cylinder motorcycle.  Perhaps even four separate car coils if they are small enough.
Adapting your spark plug leads is a different story.  Long years ago I tried a set of Luftmeister spark plug leads that were built like automotive style but they had a intermittent misfire so I reinstalled the stockers.
Good luck!
Frank
Post by: FlatSix on June 03, 2022, 12:46:56 PM
Laitch, they responded that they were no longer available.  They really do provide great service there, I have used them for many, many new parts.  Real bummer.
Post by: FlatSix on June 03, 2022, 12:51:32 PM
Good luck!
Frank
Frank I was thinking that there must be a way to accomplish this.  What does one do when used ones can't be had?  Not that I am the one to do it, I am hoping to just get my bike working again.  Salvage yards used to be my playground and back many years ago I used to pull parts for my old Triumph car from a salvage yard near Austin.  That was when I was in college.
Dave
Post by: FlatSix on June 13, 2022, 02:37:24 PM
Update:  I was able to source a set of used coils on the auction site.   They were the old style like I already have, and they were listed as "ignition packs" on the site so not easily found in a traditional search for BMW K coils.  Still holding out on some of the newer coils with the red lugs, but these tested OK so I put 1 of them on the bike to replace the one testing bad.
She fires right up and runs...took her around the block and much better as I was hoping.  I do think I have another problem to look into and I don't think the bike was doing this before.  When I "blip" the throttle from idle there seems to be a slight hesitation.  I am pretty sure that is new.  I think this needs further investigation.
Dave
Post by: Martin on June 13, 2022, 04:41:16 PM
When throttle blipping Bricks can be slow to react due to the airflow meter requiring time to adjust. On the road it shouldn't cause a drama.
Post by: frankenduck on June 13, 2022, 04:43:54 PM
K75s lag coming off idle. I set my idles in the 1100-1200 range to mitigate that.
Post by: The Mighty Gryphon on June 13, 2022, 05:57:12 PM
What you are seeing is the lag in the barn door air sensor.  It takes a bit of time for the vacuum in the cylinders to pull it open and tell the ECU to send more fuel.  Just rolling on the throttle coming off idle is the way to go.
Remember, this is first generation electronic fuel injection control technology that is going on 40 years old.  The Motronic eliminated the barn door and as a result the response when blipping the throttle is much faster on the 4 valve bikes.
Post by: FlatSix on June 14, 2022, 11:13:12 AM
Thanks for the advice guys.  Probably best to just ride her around for a while and enjoy.  Wish it wasn't so darn HOT.
Dave
