TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Steviescumbag on May 25, 2022, 02:03:14 PM
Hey, in Addition to one of my last topics.
I’m wondering if I can push the bike to a start (if someone pushes me) if I’m having electrical whack on start up which I’m convinced is a grounding problem. Just so I can get it home
Thanks
The only way to find out is to do it.
Yes. (But rolling it downhill is easier.)
I wouldn't try to bump start it yourself. Sit on the bike and have someone else push.
You aren't using the starter so don't need a lot of juice, but you DO need some: for the fuel pump and electronics and sparks.
I have started mine rolling it downhill when the battery was _almost_ dead.
I've been able to bump start mine but it does need enough juice for the pump and plugs
Put it in 2nd or maybe even 3rd gear as trying in 1st will probably just slide the rear tire. And yes, a downhill or someone to push as you sit on the bike is best.
Frank
I’m wondering if I can push the bike to a start . . .YesI have started mine rolling it downhill when the battery was _almost_ dead.Put it in 2nd or maybe even 3rd gear as trying in 1st will probably just slide the rear tire. And yes, a
I recommend the Max-velocity, bum-start method as depicted in video below. In any case, please have somebody make a video of your result so it can be placed in Motobrick.com's instructional archives.
https://www.youtube.com/watch?v=ImtOOKYZtuk&t=105s
Lol okay good to know. But yea I wouldn’t want to try with bump start. The brick is too top heavy. Lol
Absolutely. Find a strong person to push you, or a long gradual downhill road.
And third gear. I agree with that.
Steep hills work fine too.
Just not too steep
Slightly too steep is still OK if you're extra careful.
Just not too steep
When I lived in Seattle I had the steepest hill in the neighborhood at the end of my alley. (Seattle has lots of hills.) I used it several times over the years to bump start. I prefer a steep hill because it takes much less time/distance to get up to speed for a bump start. You do need to feather the clutch when doing any bump start but that's a pretty basic riding skill.
