TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: Steviescumbag on May 16, 2022, 10:21:08 PM
Title: Buzzing when turn signal.
Post by: Steviescumbag on May 16, 2022, 10:21:08 PM
Good day brick friends,
I have a 92 k75 rt. I’m in the middle of changing my after market HID front signals to bar end led indicators.
Before I removed the HID after market the signals were working fine. Now with my leds, the lights turn on but it buzzes and doesn’t blink. I was under the understanding maybe there is a faulty connection somewhere. But when I connect my HID signals it works fine. Any suggestions why this is happening. The wiring of the LED are super thin. Could this be the issue.
Please let me know your thoughts and give me pointers on best way to connect 🙏🏻
Title: Re: Buzzing when turn signal.
Post by: frankenduck on May 16, 2022, 11:30:53 PM
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/ledoemflrelay/ledoemflrelay.htm
Post by: Steviescumbag on May 17, 2022, 10:14:57 AM
Ok ok seems like an easy fix.
Although when I had the HIDs on , I already had LED rears and it worked fine too.
You still think this is the issue?
Post by: Steviescumbag on May 17, 2022, 10:06:41 PM
Update:
This worked, my blinkers work fine and are even blinking again normal rate.
Thank you for the help. It was so easy to do.
I even found a video the helped me get into the relay . Here it is
https://youtu.be/kg5gbUj0IkI
Thanks again
