TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: alexg on May 04, 2022, 05:21:17 PM
Title: Ignition switched tap: where ?
Post by: alexg on May 04, 2022, 05:21:17 PM
Hi all:
I bought a hyper-light brake light kit and it requires a hot with ignition power source. Any recommendations where is more convenient?
Thanks
Title: Re: Ignition switched tap: where ?
Post by: frankenduck on May 04, 2022, 05:35:21 PM
Green/black wire of the connector for the rear brake switch. (Under right side cover.)
Or white nylon connector in the relay box - green/brown wire.
Post by: alexg on May 04, 2022, 07:00:11 PM
That works. My bike has ABS, can I tap from the computer? Shorter run to the rear light. Thanks !
Post by: frankenduck on May 04, 2022, 07:06:22 PM
If you want to tap near the rear then tail light power - gray/black.
Post by: alexg on May 04, 2022, 08:30:08 PM
Of course, rear position light is always on! Thanks !!!
Post by: alexg on May 05, 2022, 07:46:41 PM
Installed the two 8-LED modules to the side of the regular brake light. Looks like it was designed that way. I am very happy. Tapped all the needed connections at the rear light as well. Thanks for the suggestions.
Post by: Past-my-Prime on May 08, 2022, 03:59:49 PM
Photos? And where did you source your lights?
Post by: alexg on May 11, 2022, 01:09:07 PM
Photo as requested. It is annoying to look at!  Bought it from Sierra BMW in Reno, Nv.
Post by: foliver on May 11, 2022, 10:29:07 PM
Hi Alex, very nice!
this ones?
https://hyperlites.com/?product=u32-kit
Post by: alexg on May 11, 2022, 10:58:04 PM
That brand, but the ones with only 8 LEDs per side. I cannot confirm that the 16 LEDs will fit in the space.
Post by: foliver on May 11, 2022, 11:01:29 PM
Do you have a link?
Post by: alexg on May 11, 2022, 11:11:52 PM
https://hyperlites.com/?product=universal-kit
It is in the same site, just a few clicks away. Cheaper too.
Post by: foliver on May 12, 2022, 05:14:27 AM
Txs Alex!
good find
