TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: redwolfstudio on February 16, 2022, 07:00:00 AM
et
Hi everyone,
So, here I am slowing putting my K75 RT project back together and about to place the battery when I realized I forgot to pay attention where the neg goes?!?
Thanx for your help!
Positive on the left, negative on the right.
The other end of the negative lead is attached to the transmission above the shifter.
If you want to be really anal about your grounds, you can make a #14 wire with ring connectors at each end and run it from the ground point on the frame under the fuel tank down to the ground point on the transmission.
Super! Thank you Mighty Gryphon :-))
