TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: foliver on February 04, 2022, 09:51:54 PM
Title: Light grease for the throttle "chain"
Post by: foliver on February 04, 2022, 09:51:54 PM
Hi all!
i would like to know what kind of grease can i use for the throttle "chain", and to lubricate the handlebar.
In my dismantling i've seen a light grey grease.
What brand and type can you recomend?
Thanks!!
Title: Re: Light grease for the throttle "chain"
Post by: frankenduck on February 04, 2022, 09:57:08 PM
I use aerosol silicone in my throttles. Makes them return much better. Brand doesn't matter.
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/throttlereturn/throttlereturn.htm
Post by: foliver on February 05, 2022, 07:12:03 AM
Thanks Frankenduck, easy!
Post by: foliver on February 22, 2022, 06:51:37 AM
Hi!
i've not find silicone spray here...
So i cleaned all the parts, and use white litium grease.
The throttle returned ok, but when i accelerate, i feel the tooth working inside, like: "cli clic clic clic ( no noise, just tactil sensation)
i thought the grease was not dense enough, so i cleaned all and i applied a more dense grease...
Same feeling, but the throttle doesn't returned anymore....sticky..
I cleaned again, and i returned to White lithium.
So no it returns freely, but i feel the "steps"
examining the tooths i see they have a little wear, but i don't remember that feeling in the past prior to let the bike sleeps..
Pulling the cable by hand is easy, and no friction. the throttle bodies moves freely.
Where can be the problem?
Post by: Laitch on February 22, 2022, 07:59:08 AM
. . . i don't remember that feeling in the past prior to let the bike sleeps..
Maybe your memory isn't what it used to be.  :laughing4-giggles:
Are the marks on the throttle tube gear and the throttle cable gear in alignment? Is the throttle gear cover aligned correctly and screwed down securely?
Post by: foliver on February 22, 2022, 08:48:32 AM
Jajajajaj!! May be..
Yes, marks aligned, top cover well screwed
Post by: Laitch on February 22, 2022, 08:57:01 AM
As long at it both easily twists fully and also snaps back smoothly it is working ok.
Post by: foliver on February 22, 2022, 09:08:13 AM
Ok
When At full throttle the butterfly bodies are full open.
When I close gas I hear the click and I’ve minimal “play in the throttle”
That seems good calibrated. Just the “feeling” is not optimal.
I”ll dismantle again to see
Post by: Laitch on February 22, 2022, 11:00:28 AM
Maybe , as the old song suggests:
🎵you've lost that loving feeling
Bring back that lovin' feelin'
'Cause it's gone, gone, gone🎵
Post by: foliver on February 22, 2022, 11:23:36 AM
I’ll played back in the garage, to see if i can find it again when dismantling!
