MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: Bricktop1 on December 21, 2021, 11:23:55 AM
Hi folks I have a 1994 K 75 I need back blinkers I also need either a small top box with hardware or an option to mount the large top box that I bought please please forgive me I am fairly new with this I’ve had the bike a few years but I just drive I don’t get into the hole life but I need help mounting this box if anyone could identify and tell me exactly what the box in the picture is my bike is the blue one the red bike I will try to post is I believe the hardware I need I don’t know if that hardware will bolt onto a K 75 I don’t know if there is an option to mount this large box on the. OEM rack that’s mounted directly to my faring any help would be extremely appreciate it
So a couple of questions does anyone have blinkers for sale does anyone know exactly what box that is that I have and how I can mount it to my K75 with or without getting those big brackets seen on the red bike that is not mine.
Do you need complete rear turn signals? Black housings AND lenses?
The case you have is a K1100LT 35 liter top case. It mounts to the K1100LT rack like on the tail of the red bike in your pictures. The K1100LT rack can be retrofitted to a K75 or K100 but you'll need some spacers and longer bolts because the mounting points are wider apart on a K1100LT than on a K75.
In theory you also need some spacers at the bottom fronts of the Z racks but I don't know if that's 100% necessary.
You'll need to remove the tail cowl passenger hand holds. To fill up the top holes there you'll need parts 52531456075(left) and 52531456076(right). To fill the bottom holes there you'll need 2 of 51211839913.
Here's the parts diagram for the factory retrofit kit:
https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=51743&diagram=46_0319&partnumber=46542316220
Thank you friend do you have a set of blinkers I could buy?
If youre still looking for a pair of blinkers, i just took the rear ones off my 1997 K1100…i think theyre the same as K75. I just registered here, but message or email me if interested…i could put them on ebay for you if you were nervous cuz im new on here…
Yes I still need blinkers do you have them still sorry my notifications were off
I do still have them. Im pretty sure they are the same ones as the k75…but you may want to also verify. Mine are from 1997 k1100lt. I just took some pictures. Unfortunately, I didnt notice when i took them off that each one has a small crack in the housing. The lenses are in great condition. They both work fine and the cracks arent even really noticeable, but i just saw them while taking these pictures. If you still want them, ill just charge your shipping cost which is probably $15 or so if in the US, maybe a bit less. Sorry i didnt notice the cracks earlier. They really are minimal though if you can use them….
I’m still looking for both complete back blinkers and Either the small top box that will go right on my case 75 rack or everything needed to put my big topbox on my bike any help is much appreciated.
Yes I would love to have them my bike is not perfect as long as they function and work properly and don’t take in water I would love to have them I can Venmo you whatever you want and give you an address let me know. Email me if you like
Realty617@aol.com
Do you have in the other stuff that’s right you with the black or dark gray 1100 is it I’m looking for the hardware to mount the big box I have on my k 75
And thanks in advance. Joseph
