TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: Keleven on November 08, 2021, 05:08:30 PM
Title: K1100 starter doesn't turn
Post by: Keleven on November 08, 2021, 05:08:30 PM
Can someone send me pics of starter wirings off a k1100?
I'm putting the bike back together and I have power in the cluster, fuel pump works, but when I press ignition, nothing happens and no sound of starter kicking or turning either.
Thanks a million
Title: Re: K1100 starter doesn't turn
Post by: The Mighty Gryphon on November 08, 2021, 05:34:41 PM
Does the headlight go dark when you press the starter?
Post by: frankenduck on November 08, 2021, 05:48:28 PM
Kill switch pointing straight up?
The start button only gets power if the cluster green N lamp is illuminated or the clutch is pulled in.
And the side stand switch needs to be plugged in with the side stand retracted.
Side stand switch connector - right side of bike under the side cover.
(https://i.imgur.com/ot1xaMb.jpg)
Post by: frankenduck on November 08, 2021, 05:59:53 PM
Here's the BMW wiring diagram:
https://i.imgur.com/jLTfqV1.jpg
Post by: Laitch on November 08, 2021, 06:15:49 PM
You have your motos' models in your signature, now add the years. There are differences in the systems depending on the year of manufacture.
Post by: Keleven on November 08, 2021, 10:55:26 PM
112350
Thank you all,
with going thru all your comments and guidance, I was able to resolve the issue. Moving on to the next stage ...
Post by: The Mighty Gryphon on November 08, 2021, 11:42:54 PM
Ummm, what did you find?
Post by: Keleven on November 08, 2021, 11:52:09 PM
I'm not sure what was the real cause.
I reconnected Gear Indicator, Clutch Sensor, recharged the battery and shifted gears up and down a few times.
I guess one of the above fixed it. The starter cranked a few times and I need to recharge the battery one more time (I know, I need a new battery, but it's coming once I have the bike running and fully functional).
I am moving forward with installing lighting and tires on the powder coated wheels. :-)
Post by: frankenduck on November 09, 2021, 01:05:58 AM
Best battery bang for the buck:
https://www.amazon.com/gp/product/B074VFKRKL
