TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: AtLarge on November 04, 2021, 02:25:20 PM
Just to be sure... the extra wires are for running lights correct? Can I buy off the shelf jacks that will fit those plugs? I would rather not cut and splice if I don't have to. The MAX fiche is acting up for me and I can't even find the explosion for the pods. Is there a bulb holder part number that I can just replace my original with and use double filament 1157 style bulbs? :idunno:
What "extra" wires?
There's no factory part to run 1157 dual filament bulbs.
Run-n-lites Type 3: http://www.run-n-lites.com/AppGuide-Run-n-lites.html
Mine:
(http://i.imgur.com/FDVNf5Om.jpg) (https://imgur.com/FDVNf5O)
The black plug is for the turn signal. I can see the BMW 1369229 and AMP 926569 part number on that but, the white is blank.
The white connector is not factory. Only the black one is.
I think you nailed it with the Run n lites. When i took off the other one it still had the bulb holder like on that website. Bulb was black so obviously burned out which is why I had not noticed before. Thanks Frank. :-)
