TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: TonyFrost on September 25, 2021, 10:39:23 AM
Title: Bep 3.0 connections
Post by: TonyFrost on September 25, 2021, 10:39:23 AM
Hi, It's probably a silly question but how do I connect wires to the holes in the bep 3.0? I'm talking about the holes on the right for high beam, neutral etc.
Title: Re: Bep 3.0 connections
Post by: rbm on September 25, 2021, 08:29:16 PM
The BEP 3.0 uses quick-connect terminal blocks.  You use a thin screwdriver or similar to press the orange button you see located at each hole in the terminal block.  Then stick in the bare end of the wire and release the button.  The wire will be captured and not be able to be removed.  Tug on the wire to make sure it is secure.  To release the wire, press and hold in the orange button and pull on the wire.
Post by: TonyFrost on September 26, 2021, 03:57:12 AM
My tabs are white put I'll have a go and see what happens.
Thanks 😊
