TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: andrew_Antoneypillai on July 20, 2021, 02:20:52 AM
Title: 1991 K75s Handlebar tube size
Post by: andrew_Antoneypillai on July 20, 2021, 02:20:52 AM
All in, I have taken the old rubber handle grip off of my 1991 K75s. I would like to replace an aftermarket Handlegrip, can someone let me know what is the size of the Handlebar tube? I have a pair of grip which is 22mm and that will not fit over the tube.
Thanks for your help.
Title: Re: 1991 K75s Handlebar tube size
Post by: Laitch on July 20, 2021, 10:33:12 AM
Welcome, Andrew! You haven't told us about your Brick. Does it have its original handlebar? Where did you get the grips that you are mounting?
When you buy a set of grips for a Brick, you buy a 22mm set because the BMW Brick handlebar tubing is 22mm in diameter. When you receive the set, the clutch lever-side grip will be 22mm in diameter; the throttle-side grip will be larger because it fits over the throttle tube which fits over the 22mm handlebar.
Often 22mm and 7/8" handlebars are advertised for sale as the same size; they are not.  A 7/8" handlebar is 0.225mm greater in diameter than a 22mm bar. To use a 22mm grip on it, the bar end diameter needs to be reduced to fit it.
Post by: andrew_Antoneypillai on July 20, 2021, 10:17:23 PM
I am so sorry, I got my brick about 3 weeks ago from Reading PA, it’s a 1991 K75s, has 75k on it. It came with all original parts. I try to slowly changing something to little more modern I guess.
She runs well, has a little oil leak that needs to be addressed.
Thank you so much you are correct, it worked.
I got this handlebar grip, https://www.amazon.com/gp/aw/d/B07C81S93N/ref=yo_ii_img?ie=UTF8&psc=1#immersive-view_1626833657708
I like the look of it and I can add a side view mirror as well.
