MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: mdk_mdk on July 05, 2021, 12:49:44 PM
2021-07-30 Update: Bike is sold
2021-07-11 UPDATE: New blinker relay installed, blinkers work properly now!
1990 BMW K75 for sale in Ringoes NJ - $2500 - 58K miles - Color 654 (Black): Good splines, new Shinko tires in 2018, new battery in 2019, includes 2 sets of hard cases, tank bag and lots of parts & spares (Full list below). Bike runs and drives well, pulls hard, revs, handles, and stops with no issues.
Bike can be delivered within 100 miles of Ringoes NJ for free, further than that I would just ask for gas money. Bike is available for inspection & test rides.
I'm selling the bike because I purchased a 2016 BMW S100XR and don't have room for both bikes.
Cold start video is included, bike hadn't been started in a couple of months so it's a true cold start. All pictures were taken this weekend (except splines) and represent the bike as it is.
Please reach out if you have any questions or would like a picture of something not shown.
Google Drive with all the photos (including splines) and cold start video: https://photos.app.goo.gl/PxWJYcjLowTSQRSBA (https://photos.app.goo.gl/PxWJYcjLowTSQRSBA)
Work done on the bike:
Installed new spark plugs
Lubed drive shaft splines (pictures of splines in album)
Replaced rubber alternator bushings
Installed new tires (2018, tons of tread left)
Installed new battery (2019)
Rebuilt front brake master cylinder
Installed battery tender pigtail
Installed new rear shock bushings
2021-07-11 UPDATE:
Installed new blinker relay
Installed new Z pipe
Spares & Parts Included with the bike:
BMW Sport seat
Rear tail bag mount (Have attachment plate also)
BMW OEM Tool Kit & BMW Manual
Spare clutch cable
Progressive rear shock with new thrust bushings (plus spare bushings)
Newer set of BMW tragkorbs with new hinges & OEM BMW Inner Bags
Older spare set of BMW tragkorbs
Spare tragkorb lock & multiple spare lock cylinders
BMW tank bag and mount (elastic was replaced so mount fits tight, map pocket is clear)
Spare rubber alternator bushings
Spare air filter & oil filter (Includes oil filter wrench)
New valve cover inner & outer gaskets
New intake rubber bushings
New Z pipe 2021-07-11 UPDATE: New Z Pipe Installed
Spare 4-Pin Connectors
OEM BMW folding key (un-cut)
Valve adjustment tools (Cut on Waterjet, just needs handles)
Auxiliary lights (to connect to cut-off front wires)
Nelson Rigs bike cover
Rancho shock boots
Spare misc bolts that were replaced with new ones
3D printed storage tray dampers
4 sets of old leather gloves (Came with bike, need to stay with bike)
Longer transmission mounting bolts with heads cut off and screwdriver slots (For removal of transmission during spline service)
Things to Fix/Do:
Red brake light on dash stays on (Both front & rear brakes work, sensor maybe?)
Blinkers don't always cancel, both blinkers come on - Relay maybe? Blinkers fixed 2021-07-11
Install new intake bushings & Z pipe
Install fork boots
Install auxiliary lights up front or clean up cut wires
Lube clutch splines (longer transmission mounting bolts included for the job ala Chris Harris' video)
nice. Looks to be a C model? I had a lot of whack with the flashers on a 75 s I sold, Finally bit the bullet and replaced the [expensive] flasher relay, that fixed it. I'd love to get another 75, especially a C, but I have to sell one of my 1100's first.
It's not a C, just a plain K75, not very common. I had a C back in the day (See my avatar) and it had the small fairing.
I agree on the relay, it's probably the solution.
Thanks for the info. You may be able to get a good used one on ebay, that's what I did. It's an easier sell if everything works.
Do you remember the part number?
you should be able to read it off of this
https://www.ebay.com/itm/143763607782?epid=1341178496&hash=item2178fa90e6:g:dYcAAOSwNXZfdKtx
Ouch! what are they made of, pure gold? Or maybe Bitcoin?
Turn signal relay new (with warning hazard): $200.00 from EME.
Unless you don't have 4-way flashers, in which it's $100.00 from EME p/n 2 306 014 And it's on ebay for $50.
Best to check the part numbers on your own relay.
Good used one. $60. plus shipping. I have all K bike electrical components if anyone is in need. Email me.
Email sent
Thanks @mw074 - The new relay worked perfectly! Blinkers are working properly now.
icon_cheers
112350
Sold for asking price to an Harley rider here in NJ.
Thanks everyone for your help over the last couple of years.
Maybe one day in the future I'll have a brick again....
