TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: michealspencer on June 29, 2021, 12:08:15 AM
Title: Replace the oil pump. Need advice
Post by: michealspencer on June 29, 2021, 12:08:15 AM
Ask And Answer About Shark Navigator Nv360
WHAT IS SHARK NAVIGATOR NV360 ?
Customers interested in household appliances must be familiar with Shark, one of the most popular brands of vacuum cleaners all over the world. Not the latest model, but Shark navigator lift-away deluxe nv360 upright vacuum has still received lots of appreciation from professors and positive Shark NV360 (https://slides.com/allensullivan/shark-nv360-the-best-cleaning-assistant) reviews from customers because of its efficiency and ease of use, therefore kept its position in the top rated vacuum cleaners list.
Before deciding to bring home this machine, we would like to invite you to read this post. In the article, we summarised frequently asked questions (FAQs) from consumers and provided an appropriate explanation for each.
GENERAL QUESTIONS
How many amperes is the electricity used for it ?
Shark navigator lift away nv360 model works in the amperage of 10amps.
Is Shark navigator deluxe nv360 a good choice for hardwood floors ?
Tests have been conducted and this model can work well on hardwood floors like vinyl without any problems.
Does it get any problem with a floor full of pet hair and sand ?
Absolutely no problem, because this model is designed for these tasks.
Can it do well on stairs ?
Shark model nv360 is very effective on stairs thanks to a lift-away canister and an expandable hose equipped. You can bring the debris container out of the entire machine and use the pipe to clean stairs easily.
Can it be effective with high-pile rugs and rough surfaces ?
The model nv360 is extremely powerful on every kind of carpet, it can make even thick or high-pile carpets amazingly clean with one run only.
(https://imgur.com/VQWrZnV.jpg)
FUNCTION ISSUE
How many filters are there in a blue Shark vacuum ?
This model has 3 filters:
 - Foam filter: this filter is placed before the motor that needs cleaning and drying every 3 months.
 - Felt filter: close to the foam filter and requires a similar sanitizing frequency.
 - HEPA filter: this filter is located after the engine and only needs cleaning 1 time every 2 years.
How long is the expandable hose ?
The designed hose is 8.5’ long, but since we can detach the canister during cleaning so the length of this component is not a problem. The shark navigator nv360 (https://www.linkedin.com/showcase/shark-navigator-lift-away-deluxe-nv360-vacuum-cleaner-reviews/)'s lift-away technology allows us to clean narrow spaces without worrying about the hose.
Do the indicator lights show any problem ?
There is an issue with this function, some say it’s a problem but others claim that it’s a good point. The indicator lights of this model make very small sounds.
How can we store the cord ?
There are two prongs sticking out from the machine, you can put the cord around them. There is another notch on the body for you to hook the wire, even while you are working or when you finish the cleaning.
(https://imgur.com/Kj6WOLE.jpg)
How can we maintain the device ?
Any machine will quickly break down if we don’t take good care of it. Always pay attention to the parts of the device before, during and after using it. These include the power cord, the debris container, the detached canister, hose connections, the crevice tool and the filter. Make sure these components are in the right position before using and sanitise them after cleaning, therefore the machine can be maintained to use for a longer time.
CONCLUSION
Well, it can be noticed that Shark navigator lift away deluxe NV360 (https://www.besport.com/post/32178368) can satisfy almost every common need from householders in floor cleaning. You now don’t have to worry or consider whether to choose it for your house or not. On the other hand, the insurance and guarantee policy from Shark can help you with any unexpected problems.
Title: Re: Replace the oil pump. Need advice
Post by: sebas2357 on June 29, 2021, 12:57:36 AM
Hey Michael,  :welcome to the forum!
Unfortunately, you can't remove the gear from the shaft without damaging the part. Even if you do, I'm not aware of any place where you can purchase just the shaft. If you need to replace the shaft due to pitting, you will have to buy a new shaft, which in turn comes with a preinstalled gear. I recently rebuilt my pump and found it had a badly pitted shaft. I purchased my new shaft from EuroMotoElectric. Just make sure you purchase the shaft with the correct number of teeth on the gear. The old one makes a nice desk ornament  :laughing1:
Seb
