MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: wmax351 on June 14, 2021, 08:48:18 PM
Title: Motobrick MPG Guages
Post by: wmax351 on June 14, 2021, 08:48:18 PM
I still have a good number of partially completed MPG gauges for K-bikes, but no time to put them together. If someone wants to take over the project, I'm glad to send them to them. Assembly just requires some soldering, wire cutting, and crimping. The cases are already pre-drilled.
http://www.motobrick.com/index.php?topic=2997
Title: Re: Motobrick MPG Guages
Post by: Scott_ on June 15, 2021, 05:39:00 AM
Max, any chance these can be fitted to a '97 R1100?
The injector connector should be the same, however the speedo is mechanical so I'm thinking it might not work.
Post by: wmax351 on June 15, 2021, 11:12:44 AM
It could be easily. If the speedo is mechanical, you can use a magnet and reed switch setup like a bicycle speedometer. You would just need to run an additional wire from one of the 5v lines out to the sensor, and back to the speedometer input.
Post by: Scott_ on June 15, 2021, 06:00:26 PM
You know, about 30 minutes after I posted that this morning, it dawned on that my Fuel+ system(on my K) uses just that, a reed switch and magnet....
