TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: BlueK11LT on June 09, 2021, 03:25:57 PM
Title: K1100LT R/H handlebar switches & front master cylinder question
Post by: BlueK11LT on June 09, 2021, 03:25:57 PM
I need to replace my throttle cable because the plastic 90 degree shaped end next to the throttle housing has broke,but i cant figure out how to remove & split the handlebar switch/front master cylinder unit.
Is this part actually one piece? and is there a step by step article on the forum about how to replace the K1100LT throttle cable?
Thanks
Dave
Title: Re: K1100LT R/H handlebar switches & front master cylinder question
Post by: frankenduck on June 09, 2021, 04:58:03 PM
The part in red below is a little metal plate that holds the throttle tube on. You need to remove screws 4 and 5. If you have heated grips be careful not to screw up the wires where they connect at the outer end of the grip.
(https://i.imgur.com/Enq7P4P.jpg)
