TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Ingo on May 10, 2021, 04:34:38 PM
Title: What's this, where should it connect?
Post by: Ingo on May 10, 2021, 04:34:38 PM
Taking brick apart, found this loose under tank. Other end goes to breather in top of valve chain cover and (presumably) to vacuum. Can not find any loose hose or tubing in area of this end...
This is my first post, please excuse any mis-steps of mine.
Had this 1992 K1100LT since about 2006, K100RT before that, coming from R90/6 (souped up to R90/S specs due to it came on a S-frame). Current moto has 44K miles, vibrates like crazy, will address once this is back together, had engine output seal bye-bye...
Title: Re: What's this, where should it connect?
Post by: Scott_ on May 10, 2021, 04:58:35 PM
You can remove it and cap the line where it connects at the top of the block.
I see in your picture that a P.O. has installed "the cup" so what you have is no longer needed.
Originally it connected to the gas tank vapor vent line, so that fuel vapors were drawn into/thru the block and then drawn into the intake air stream for combustion.
Problems occurred when people overfilled the fuel tan and liquid gas would then make it's way down into the oil and cause problems, so BMW did away with it.
Post by: Ingo on May 10, 2021, 05:32:25 PM
Very good, thank you. Will remove since there's waayy too much stuff under the tank, it's very crowded.
Post by: Laitch on May 10, 2021, 05:36:57 PM
Current moto has 44K miles, vibrates like crazy, will address once this is back together . . .
If the moto vibrates in general instead of at a specific place like the front end, consider inspecting the driveshaft u-joints for looseness, stiffness or being out-of-phase, if you haven't done that yet.
Post by: The Mighty Gryphon on May 10, 2021, 06:03:37 PM
Check the steering head bearings, front wheel balance and the engine mounts.  How old are the tires?
Run the engine for a couple minutes to get the headers hot and then squirt a little water on them.  Does it boil off of all four with equal enthusiasm?
Post by: frankenduck on May 10, 2021, 06:55:12 PM
Getting rid of vibration: Sync the throttle bodies and make sure the little black rubber caps on them are not cracked and leaking air.
If the throttle bodies won't sync then a leaking boot between the TBs and cylinder head may need replacing.
Post by: Ingo on May 10, 2021, 07:58:07 PM
Thank you guys for the responses.
Laitch: I don't know what "out of phase" means...
It is definitely the engine causing vibration, pull clutch and there's nothing while rolling. Synchronizing is due once I have her back together. It's going to be a while. Pulled engine apart, was shocked about gaskets and seals and head gasket prices, spent $ 1500.- so far. Wear is marginal, rod bearings are hardly run-in. P.O. must have done oil changes regularly. I only used synth oil, seems to be doing good. Rubber boots on intake look fine, so do the plastic connections. On re-assembly I will check valve play, make sure mechanically everything is good there there. Right now cleaning pistons and going to check their weight (balance). Have to wait for ordered parts to come in. Then I will be working again with little time for wrenching. Took 2 weeks off to work on bike, not nearly enough time...
Post by: The Mighty Gryphon on May 10, 2021, 09:30:39 PM
Drive shaft phasing refers to the alignment of the two u-joints.  The u-joints need to flex the same way in unison.  This will allow the drive shaft to rotate around a stable axis.  Not only does phasing prevent drive shaft vibration, but out of phase u-joints will have a tendency to self destruct.
https://www.youtube.com/watch?v=9K1Sm2xfAyw
Post by: frankenduck on May 10, 2021, 09:43:07 PM
"The inner can slip."   :johnny
No, the insulating rubber flexes.
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/dsphase/dsphase.htm
Post by: The Mighty Gryphon on May 10, 2021, 10:06:05 PM
It's worth noting that there is a spring ring in the splines at the transmission end of the drive shaft that maintains the location of the drive shaft on the output shaft of the transmission.
You need to push the drive shaft onto the output shaft until the ring snaps into the groove on the output shaft.  If you don't, the the front half of drive shaft can float down toward the final drive and the u-joint can hit the inside of the swing arm when the swing arm is at the extremes of rear wheel travel.
Post by: Ingo on May 10, 2021, 10:38:00 PM
What a beach! I didn't plan on taking that apart, too. But as I'm into it this far I might as well make it complete. I can see why the "phasing" would be important. Though it "should" be right, I very much doubt it's ever been apart since it left the factory.
So I've got to take the swing arm off the gear box, right? There is no getting to it from the rear end only?
Post by: frankenduck on May 10, 2021, 11:37:07 PM
Yes, you need to pull the swing arm to see the front U-joint.
It's a heck of a lot easier and much less work than replacing the head gasket.
Before reassembling it helps getting it right if you put some paint or whatever on the rear face of the front half's splines.
(https://i.imgur.com/wdTHcqy.jpg)
Post by: Laitch on May 10, 2021, 11:43:35 PM
Pulled engine apart . . . What a beach!
You've completely dismantled the engine but unbolting the driveline is a beach? :laughing4-giggles:  You've got to be meaning it's una playa hermosa.
The u-joint phasing might be out when it was reassembled after being given a transmission input spline lube or the u-joints themselves might be worn out from he-person throttle and clutch abuse, or there just might have been some loose driveline bolts somewhere. 40K is early for an output shaft seal problem, so maybe all these components were made and assembled on Fridays or Mondays.  177381
Post by: frankenduck on May 10, 2021, 11:46:21 PM
On 4V bikes both the front and rear halves of the drive shaft have circlips in the splines.  Any back and forth occurs in the intermediate splines.
https://www.realoem.com/bmw/enUS/showparts?id=0536-USA-09-1992-89V2-BMW-K_1100_LT_0526,_0536_&diagId=33_1658
Post by: frankenduck on May 10, 2021, 11:55:29 PM
40K is early for an output shaft seal problem.
It's 30 year old rubber. Seals can get old and leak regardless of the odometer.
Post by: Laitch on May 11, 2021, 12:03:13 AM
Seals can get old and leak. . .
I saw an old seal at the zoo once, long ago but I was very young at the time and it might have actually been middle-aged.
Post by: Ingo on May 11, 2021, 12:06:43 AM
Well, a beach nevertheless. Dismantling an engine is nothing new to me, I think I've taken almost all my vehicles engines apart over the years. I keep them for long term. 2 yap bikes and 3 cars where exempt. Last was my souped up WRX, just under 400 hossies proven on dyno afterwards ( and that was 20KMiles ago). It's just that this drive train is new to me and I'm not sure (yet) what I'm dealing with. Do I need parts (seals, circlips...) for this?
Post by: frankenduck on May 11, 2021, 12:26:10 AM
Some moly-based spline lube grease. No need to replace any seals or circlips.
It doesn't always happen but the final drive pivot bearings have needle bearings held in place by plastic bearing races (cages) that like to disintegrate so they might look like this when you take the final drive off.
(https://i.imgur.com/fq8mBFM.jpg)
You can get better bearings here:
https://www.beemershop.com/product/ei-paralever-bushing-kit-for-r80r-r100gs-r100r-k100rs-k1-k1100rslt.html
Post by: Laitch on May 11, 2021, 12:46:27 AM
Both fore and aft boots could be cracked, and the rubber of both lower arm bushings might be rotted requiring replacement of those bushings, too. What is said about old seals also applies to old rubbers. Beware! :laughing4-giggles:
Post by: Ingo on May 11, 2021, 01:12:39 AM
You know what's worse than a hole in the rubber?
Post by: Laitch on May 11, 2021, 01:24:06 AM
Yes.
Post by: frankenduck on May 11, 2021, 01:35:37 AM
Drive shaft out of phase.
Post by: The Mighty Gryphon on May 11, 2021, 08:52:13 AM
The front circlip on the drive shaft is important.
The guy I sold my first K100 16 valve to did the splines but didn't get the front end of the shaft locked in place on the transmission output shaft.  It slid toward the final drive and made a loud clicking sound when he ran the engine in gear on the center stand.
Those circlips are important because they prevent the sliding contact at the transmission and final drive ends of the drive shaft that cause all the wear on the final drive spline in Monolevers.  With all the sliding being localized at the splines that connect the two halves of the shaft, the extended contact area of that spline spreads the load and reduces the pressure on the spline faces which reduces the wear.
Post by: frankenduck on May 11, 2021, 09:45:19 AM
Both the font and rear circlips being engaged are important on the 4Vs. And aside from allowing spline sliding at the ends it also screws up the drive shaft geometry if the ends are loose because the ends aren't as far onto the splines as they should be when the circlips are engaged.
Post by: daveson on May 11, 2021, 09:49:17 AM
+1 Gryph
But I wanna throw something into the mix that I read about monolever bricks way back just before I got one. Because the drive shaft universal joint and the swing arm pivot points are concentric, there's no sliding going on, which is one of the advantages of the compact drive system, and probably still very unusual. Hopefully I've said that right.
Post by: frankenduck on May 11, 2021, 10:19:09 AM
+1 Gryph
It's the circlip that keeps them concentric. Without that the U-joint could slide back and forth and not be concentric at all times.
Post by: The Mighty Gryphon on May 11, 2021, 10:28:25 AM
Exactly.  The center of the u-joint must be in the same place as the swing arm pivot or much unhappiness will ensue.  That end has to be fixed in position.
The problem is that in the monolever the action of the u-joint results in a very small change in the length of the drive shaft.  That change in length is taken up by the splines sliding back and forth at the final drive.  The motion while very small is constant when the shaft is turning with one cycle for every revolution of the drive shaft.  So it's easy to see that those splines rub back and forth literally millions of times between spline lubes.
With a properly phased Paralever drive shaft, the u-joints push and pull in unison so much of the sliding contact is eliminated.  I suspect that was the real reason for the design change, that is to eliminate the spline wear found in the Monolever design.
BMW, rather than admit the Monolever was a flawed design, chose to sell the Paralever as a solution to acceleration "jacking" which because of weight transfer on acceleration was only visible when a bike was run on a dyno, where rear wheel acceleration did not result in weight transfer.
If anything, "jacking" actually helps traction when accelerating because it helps stiffen the rear suspension to handle the weight transfer giving better ground contact.
Post by: Ingo on May 11, 2021, 10:39:10 AM
Understood. The R90 was extreme in the "jacking" and looked real funny under short bursts of gas in first gear! Is this drive shaft work done with the bike assembled? I imagine it might be easier with the gear box installed, before all the other stuff (brake, foot-rest, battery box...) gets installed.
Another q: Anyone with a good idea on carbon crud removal off piston? Experience says "can't use sandpaper" since the crud is harder than the piston itself...
Post by: Ingo on May 11, 2021, 12:54:28 PM
Anyways, at 44 k miles it's time for the spline service as I understand it. Sure it was never done before, I got the moto with about 28K on the clock.
As far as piston cleaning: I'm soaking it in carb cleaner, crape some off and soak it some more, like overnight, seems to kind of work...
Will post some pics of rod bearings and pistons later. Probably just the worst looking parts.
Post by: frankenduck on May 11, 2021, 01:12:30 PM
It's not the splines sliding back and forth that causes the wear on monolever splines, it's sliding UNDER LOAD. That's why only one side of the splines exhibits wear - the side of the splines that is sliding under load when accelerating.
Whether or not monolever spline wear is a "design flaw" is a matter of opinion. Well-maintained (lubricated) monolever drive shaft splines will last over 100,000 miles. Your brake rotors will wear out faster than that. Is that a design flaw? You can similarly look at drive shafts as a wear item - like brake rotors.
Also of interest is that the Z16 splines in the 85 and earlier Ks hardly wear at all compared to the later Z20 splines. I've never figured out why BMW switched over to the Z20 drive shafts. (If you're a cynic you might posit that it is planned obsolescence to sell more parts.)
A downside of the monolever jacking/unjacking effect is that it shifts the back of the bike up and down which changes handling geometry and weight distribution. The paralever does that much less.
Post by: Ingo on May 11, 2021, 02:47:05 PM
So here's pic of rod bearing and pistond. The rod bearings all look pretty much identical in wear. Was hard to find one worse over others.
Post by: Ingo on May 11, 2021, 04:05:54 PM
Turns out that pictured rod bearing is cyl4, the heaviest of the pistons, by ~0.61 gram. Does that difference justify getting the file out?
Post by: Laitch on May 11, 2021, 05:56:41 PM
You're the maestro. It takes a grand jury to convince me to clean an air filter.  :laughing4-giggles:
Post by: frankenduck on May 11, 2021, 06:38:16 PM
Out of how many grams total? If the other pistons weighed a gram then it would matter. If they weigh 100 grams then not so much.
Post by: Laitch on May 11, 2021, 06:42:27 PM
Engineering is rarely free of some design flaws. It was probably too late to go back to the drawing board with that one.  :laughing4-giggles:
Post by: frankenduck on May 11, 2021, 06:52:16 PM
They had the Z16 shafts that they'd designed, manufactured and used in production already. Switching back wouldn't be that hard.
Post by: Laitch on May 11, 2021, 07:57:22 PM
It might be difficult it they or their contractors had tooled up and produced thousands of Z20s with an eye toward using them in future models under development, plus they probably thought everything was ok until, years later, units had accumulated multiple tens of thousands of miles in real-world conditions and were howling like banshees then stalling on the Autobahn.  :laughing4-giggles:
Post by: Ingo on May 22, 2021, 11:19:37 PM
Glad I did the spline job. Splines have been serviced sometime when, but the boot between gear box and swing arm was not correctly installed. It sat ok on the gear box but was half in and half out of the opening in the swing arm. Looked for the clip that's supposed to be inside the rubber in the swing arm hole, eventually found it in the larger diameter in the rubber boot. Almost missed it.... Got the boot installed correctly on swing arm, still have to install swing arm. Getting the boot correctly onto the gear box might be interesting. Pulling the drive shaft: it came apart unexpectedly easy, no idea if it was aligned or not, but it is now. Today I got the new valve stem seals...
