TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: MCRyder on April 09, 2021, 01:07:09 PM
Title: Fuel Lines
Post by: MCRyder on April 09, 2021, 01:07:09 PM
I'm replacing the o-ring of the fuel sender unit.  The tank fuel lines are still holding fuel, but probably the original lines and the rubber covers are cracked.  What kind of fuel line are needed, I'm guessing they are generic and can be sourced locally (?)
BTW, thanks for the answers to my previous posts about this job, very helpful  :1thumbup
Title: Re: Fuel Lines
Post by: The Mighty Gryphon on April 09, 2021, 02:13:41 PM
I can't remember the SAE spec number, but in the tank you need submersible fuel injection line, external lines are regular fuel injection fuel lines.  8mm or 5/16"
Post by: rbm on April 09, 2021, 02:41:53 PM
Any hose that is inside the tank should be rated for immersion. In the US/Canada, the rating is SAE30R10. This is a submersible hose.
30R9 is fuel injector hose that can be used elsewhere but is not submersible and should not be used inside the tank.
Post by: MCRyder on April 11, 2021, 06:43:37 PM
Thanks for the replies.  I should've been more specific, I'm replacing the outside fuel lines and thanks for that info. I also appreciate the info on the submersible hose as that might be a need in the future.
Post by: The Mighty Gryphon on April 11, 2021, 10:18:09 PM
When you buy a fuel filter it may come with a couple short pieces of fuel line to install it.  Don't use them, they are not rated for submersion.  Save the ones that are already there if they haven't turned to black goo or become rock hard.
Post by: Scott_ on April 12, 2021, 05:17:21 AM
TMG, just to clarify your comment above, that only applies to the NAPA 3032(or any non OEM filter for that mater)
It's been so long since I actually purchased a fuel filter from BMW, I can't remember if the OEM filter would come with any small pieces of hose like the NAPA one does.
Post by: Laitch on April 12, 2021, 07:08:08 AM
When I buy a Mahle filter, all I get is a Mahle filter.  177381
