TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: bgcameron on April 09, 2021, 01:12:31 AM
Title: K75 Engine noise
Post by: bgcameron on April 09, 2021, 01:12:31 AM
Hey guys,
I have a '90 K75S with 53,000 kilometers on it. I am getting a loud, intermittent clacking noise, possibly coming from the front of the engine. It only happens in motion, under a light load at any speed or gear. It seems to happen around 3500 rpm, but it is not a consistent "chatter". It is more like a "clack!...clack clack, clack!". At first I thought it was some noise from the fairings when going over the odd bump. I can even feel it through the handlebars when it happens..
I searched forums and didn't find anyone with a similar issue. It is difficult to isolate exactly where the sound is coming from because it only happens when riding. Help!
Thanks!
Branden
Title: Re: K75 Engine noise
Post by: daveson on April 09, 2021, 05:07:48 AM
I guess that means you can't reproduce it on the centre stand at 3500rpm in gear or neutral. Can you reproduce it while riding at 3500rpm in neutral, or disappears with the clutch pulled in?
A bit of wishful thinking, sometimes it's as simple as a loose spark plug lead, or old plugs or leads. What brand are they?
What about the history, like is it a new problem, or had it for years, or developed suddenly after some repairs, or something like that?
It wouldn't hurt to clean and gap the plugs and leads.
Post by: Laitch on April 09, 2021, 11:06:20 AM
. . . under a light load at any speed or gear. It seems to happen around 3500 rpm . . .
If you go full throttle in first or second gear up to 5000 rpm there is no noise?
Post by: bgcameron on April 09, 2021, 12:34:21 PM
It is so sporadic when riding- I'll be going down a straight stretch of pavement and get a single "CLACK!", sometime more- so it is hard to determine what might mitigate it. I'm sure the problem has existed since i've owned the bike. I have not ridden it much- less than 3000kms. I recently changed the plugs and leads, which did not make any difference.
No, nothing under full throttle as far as I can tell. Light throttle and maintaining a speed seems to do it.
Is it possible that I have a failing cam chain tensioner?
Post by: The Mighty Gryphon on April 09, 2021, 12:53:43 PM
Cam chain slap is a real possibility if the chain is stretched.  Probably will happen on closing the throttle when under hard acceleration.  Pull the cam chain cover on the front of the engine and check the chain and the guides.
Post by: daveson on April 09, 2021, 04:44:08 PM
Unlikely but quick to check for some loose bolts up front, like if the mud guard is loose you might get a clack from it, or calipers, or steering head.
Post by: Laitch on April 09, 2021, 05:38:29 PM
One person's clack might be another's click. Check the header bolts for tightness and the exhaust heat shield for looseness.
Post by: rbm on April 09, 2021, 09:18:44 PM
Are you 100% certain the noise if from the front.  If you are, then ignore this suggestion.  If not, a similar noise might be possible from the alternator region if the monkey nuts are kaput.  To check, remove the alternator and run the engine briefly to see of the noise abated.
Post by: bgcameron on April 10, 2021, 12:08:26 AM
Thanks all,
I've checked everything for looseness and no luck. I am going to see if I can replicate the sound with it in gear and on the center stand. I'll check those monkey nuts too.. does anyone have a video/audio clip of the sound it makes when they are bad?
Post by: daveson on April 10, 2021, 04:43:10 AM
There's an example in the workshop section called "k75 rattle" by Andrej. Sometimes it sounds a bit different, and sometimes there are other causes. Dunno how to do links, near the top of the sixth page at the moment.
Post by: Laitch on April 10, 2021, 08:15:48 AM
Here's the video from daveson's video reference. Because bgcameron's description mentions only a random rattle in a narrow rpm range, its source is unlikely to be this.
https://www.youtube.com/watch?v=i4xJqmm5D6I&t=25s
Post by: bgcameron on April 10, 2021, 02:49:04 PM
^ Definitely not that. The noise I am getting is significantly louder, and will present as anything from a single "Clack!" to a series of "clacks". I'll investigate more today.
Post by: Martin on April 10, 2021, 04:28:59 PM
A bit out of left field, are you sure the noise is coming from the engine? Front shocks have been known to emit the occasional noise. Try bouncing the bike with the engine off.
Post by: bgcameron on April 10, 2021, 07:55:48 PM
trying to capture some of this on video. It is hard to hear among the engine and wind noise, but some can be heard around the 12 second mark. It seems louder on the left side of the engine.. maybe coming from the head? I don't know. Is pinging a possibility? I am using 91 octane without ethanol.
https://www.youtube.com/watch?v=TVWlJaD7aXA
And I am not sure if this is related but it can be heard at idle.
https://www.youtube.com/watch?v=WuRXtWAVLug
Post by: Laitch on April 10, 2021, 08:26:52 PM
That was an excellent effort at recording!  177381
In a previous thread, you noticed "movement of the tensioner" during valve clearance inspection. Does that mean there was slack taken up during rotation of the camshaft? Do you know approximate number of kilometers this engine has traveled and if it has been conscientiously maintained?
Will the engine create that sound when the moto is run on the center stand in neutral at 3500rpm or does it need to be under load?
Post by: bgcameron on April 10, 2021, 08:46:21 PM
Haha, it was a little tricky to record. I started recording on my phone, put it in my pocket and then hung it down when I got up to speed.
Regarding the tensioner, if I remember correctly- there was some slight movement if you were to turn the cams in either direction. I seem to recall the tensioner taking up the slack when turning the cams the correct way.
The bike has 53,000 kms and the for the first 45,000 or so it may have been somewhat neglected. The last owner seemed to be on top of things and did a number of maintenance tasks during his short time of owning it.
I was able to slightly recreate the sound on the center stand , in 1st gear with the brake applied. Now for some confusion- I just had it out and I was going up a slight hill. It did its noise at 3500. I pulled the clutch and held the revs at 3500 and the noise continued to a lesser degree.
Post by: Laitch on April 10, 2021, 11:39:49 PM
When I check valve clearance, all rotation of the camshaft seems direct—no slack or hesitation. Because you can reproduce the sound when the moto is on the center stand, you might be able to rig the first gear-and-brake technique in a way that will allow you to use a mechanic's stethoscope—or a screwdriver tip against the timing chain cover with its handle to your ear—to determine if the source of the noise is within there. At least the stretching to achieve it will be good for your ligaments.  :laughing4-giggles:
If that won't pinpoint the source, you might need to fall back to using my favorite method—ear plug wearing, until the sound gets loud enough to track or goes away. How's the oil level?
Post by: bgcameron on April 11, 2021, 12:42:15 AM
Oil level is good. I may just pull that front cover off to inspect the timing chain.
Is it possible that it's pinging? I'm doubtful because of the cool temperatures and light engine load, but at this point I am open to the possibility!
Post by: daveson on April 11, 2021, 12:52:49 AM
Yep it's well time to remove the front cover.
"it seems louder on the left side"
That reminds me a bit of the clicking sound when a spark jumps on the outside, although it doesn't seem to effect the revs. Maybe remove the spark plug cover and look for any sparks, especially if it's night time.
Post by: Laitch on April 11, 2021, 09:14:31 AM
That's why trying to listen to action within the case was recommend, before removing the cover.  :thisplacewhack
Post by: The Mighty Gryphon on April 11, 2021, 12:49:35 PM
Doesn't sound like pinging to me.  Pinging only happens when opening the throttle to accelerate under heavy load at lower rpm, and goes away as soon as the throttle is backed off, not at a steady speed.  It's been a long time since I've heard an engine ping, and never on a brick, but my recollection is that it is more of a crackling sound than the clack you are hearing.
Post by: bgcameron on April 11, 2021, 07:25:32 PM
Thanks guys. I figured I would rule out the monkey nuts, even though they are an unlikely cause. It's an easy enough job to check them so why not? They are starting to deteriorate/crack so they are worth replacing.
(https://fotobucket.site/uploads/1375779532d145dc418c28691506a74245532de5.jpg)
Post by: daveson on April 11, 2021, 08:18:33 PM
Anyway have you ever had the rocker cover off? There's spose to be a spring pressing against it to provide a path for earth.
Post by: bgcameron on April 11, 2021, 08:24:27 PM
Yes, it is in place.
Post by: daveson on April 11, 2021, 08:44:30 PM
I spose you didn't find any stray sparks from the leads behind the plug cover or coil cover in the dark?
Post by: bgcameron on April 11, 2021, 08:53:21 PM
No sir, not yet anyways. Once I have the alternator back in with new bushings then I will report back to you.
Post by: bgcameron on April 14, 2021, 06:44:32 PM
Thought I would pull the front cover off today and inspect the timing chain. Here is a video of the movement in the tensioner.
https://www.youtube.com/watch?v=43gnHAfMQH4
Post by: Laitch on April 14, 2021, 08:09:47 PM
Chain tension is created by oil pressure acting on that pedestal pushing upward on the lower run of the chain. You might check behind the block beneath the pedestal to determine if the oil passage is clogged. BMW offers little guidance on when to replace a timing chain. If the tensioner doesn't look worn and the oil passage is clear, you could always replace the chain. Sometimes they last over 100K miles or more; sometimes they stretch sooner. I probably wouldn't have been bothered by the noise I heard in your first video.
That's all I've got. Maybe somebody else will chime in.
Post by: The Mighty Gryphon on April 14, 2021, 10:15:58 PM
I think the tensioner mechanism doesn't look like it's working properly.  As Laitch mentioned, oil pressure extends the pintle, but there is a ratchet inside that prevents the pintle from backing down the way yours is. I would take the tensioner off the engine and, as Laitch mentioned, check the oil passage and ratchet.
Post by: daveson on April 15, 2021, 06:51:23 AM
That's absabloodylutely spotless.
Post by: The Mighty Gryphon on April 15, 2021, 10:47:02 AM
I replaced the chain on one of my bikes at 108,000 miles.  These chains aren't long enough to show a lot of stretch that can easily be measured, the wear evidences as "side curve".  I checked it by stretching the chain out and and then bending it into an sweeping curve on a flat surface.  It's been a while, but I think a new chain has a depth of about 1/2-3/4" to the curve.  The old chain I replaced was close to 2".  The side bend play could possibly allow the chain to slap around and hit the case, especially if the tensioner isn't working properly.
If the tensioner has been allowing the chain to slap around for a long time I wouldn't be surprised if the chain is worn.  It's one of those situations where the wear accelerates more wear.
As far as the case slapping, have you seen any metal in the old oil?  Since the cases are aluminum it won't be magnetic.
Post by: Laitch on April 15, 2021, 01:21:56 PM
Inspect the rearward surface of the hole into which the crankshaft seal is mounted on the engine side the timing case cover. Gouges or chipping in that surface indicate chain slap.
Post by: bgcameron on April 15, 2021, 03:01:48 PM
Everything looks clean around the crankshaft seal. The slight play in the tensioner seems to be caused by the ratchet being in between two point of engagement.
Post by: Laitch on April 15, 2021, 05:45:20 PM
Time to move on, bg.  You're doomed to riding it. :laughing4-giggles:
Post by: The Mighty Gryphon on April 15, 2021, 07:02:21 PM
Can you get the ratchet to engage by GENTLY pushing up on the tensioner pintle?  Have you checked the orifice that supplies the oil pressure to the tensioner?  I think there is an o-ring that surrounds that orifice, is it there?
Post by: bgcameron on April 15, 2021, 08:56:14 PM
Tried but it wouldn't click up any further. I showed the video to the local expert at the bmw dealer and he said its normal. You're right Leitch, I am doomed to ride it! I will update you guys if I make any progress.
Post by: bgcameron on April 16, 2021, 12:47:48 PM
Putting it all back together and I noticed some scale in the water pump area. White crusty residue on the impeller, black flaky stuff in the outlet pipe. Any recommendations for a coolant flush product?
Post by: The Mighty Gryphon on April 16, 2021, 01:39:26 PM
I've used Prestone cooling system flush with distilled water for the block, and white vinegar to clean out the radiator inside and out after it's been removed from the bike.
The Prestone stuff does a good job on the whole system, but you might have to run two flushes if the scale is really bad.  The vinegar does a good job of cleaning out the inside of the radiator as well as softening up the bugs that are jammed into the fins so they can be flushed out with a good rinse.
Post by: daveson on April 16, 2021, 10:35:29 PM
Just double checking before the rocker cover goes back on, does the spring make good bare metal contact?
Are there any tell tale signs like black tracking marks where sparks might be jumping?
Now that you found a way to reproduce the sound while the bike is stationary, you might be able to use a screwdriver to pinpoint the source more closely.
Post by: bgcameron on April 17, 2021, 01:56:25 AM
Well she's all buttoned up now, but I did check the spring and its contact area and everything looked good. I am going to run it tomorrow and see what I can find out.
Post by: bgcameron on April 19, 2021, 12:59:33 AM
Took it out tonight.. No sparks seen from the plug wires. Given that it was night time and less traffic, I was able to spend more time leaning on either side of the bike to listen for the noise. I seems to be equally as loud from each side. Now I am wondering if it is something in the drivetrain...maybe the clutch? The clutch seems to make a bit of a clack noise when you are letting it out to get moving, so maybe it is related.
I am at the point now of taking it in to get it looked at. Normally I am more ambitious to fix these things myself.. but my dad passed away yesterday and I just want to take it easy for a while and not stress about my stress-relieving machine.
Post by: daveson on April 19, 2021, 04:02:20 AM
Arh shit bg I know that's a heavy blow.
I'd call this noise a non urgent problem. I recon you can just ride for a while and have another look sometime down the road.
Post by: The Mighty Gryphon on April 19, 2021, 08:46:14 AM
Sorry to hear about your dad.
My advice on the bike is to just go and ride it.  My K75 has rattled at various rpm with an assortment of clanking noises since the day I got her.  45,000 miles later she still runs great and does 7-800 miles days at 85mph with aplomb.
You have checked it out and mechanically it looks okay.  Do a thorough service, then put some miles on it and enjoy it.
Post by: Laitch on April 19, 2021, 09:15:57 AM
If the clutch clacks when the clutch hand lever is released, the clutch arm is likely to be hitting the muffler. If that is the case, the arm could also rattle against the muffler at certain vibrations. It is no cause for worry and a few millimeters of adjustment will stop the rattle.
Post by: daveson on April 19, 2021, 09:44:34 AM
 I think your saying it's easier to reproduce going uphill.
Next time you do a clutch lube, it would be a simple matter to check for output shaft endfloat, and look for balance marks for the clutch.
Post by: The Mighty Gryphon on April 19, 2021, 10:28:54 AM
It's the nature of the K75 muffler that it is very close to the clutch arm at the end of the clutch cable.
A simple test(do it after correctly adjusting the clutch) is to pull the clutch lever all the way in, and then let it snap out.  Do you hear a clank down by the muffler?  Do this a couple times.  If you hear it clank, take up a little bit of cable slack with the adjuster at the lever.  Only take up a tiny bit and check again for the clank.  It should only take a couple mm to stop it.
Outside of this minor adjustment, refer to my advice above.
Post by: bgcameron on April 19, 2021, 04:00:35 PM
I had a look at the clutch lever and thought that it's proximity to the muffler was the likely cause. I did the adjustment, which gave it much more clearance. Unfortunately it didn't fix the mystery noise.
Post by: The Mighty Gryphon on April 19, 2021, 08:02:22 PM
Okay, go get some good ear plugs(I like 3M Skull Skrews) and put some miles on it.
Post by: Laitch on April 19, 2021, 10:51:40 PM
I've listened to both your videos. I hear a slight rattle at 12:00 and 18:00. It seems to happen when you accelerate a little. It is so slight that its power to distract you is incomprehensible to me. It's as far from a clack as it is from a quack. All I can come up with is that you're riding at revs that are too low for the gear. Bricks will rattle a little when that happens.
As suggested, earplugs—and shifting at higher revs—are the remedies; the earplugs also preserve your hearing from being damaged by high frequency noise, too. I always wear this reusable, flanged style. Several companies manufacture them.
Post by: The Mighty Gryphon on April 20, 2021, 08:18:59 AM
Here is what is the most likely cause of your noise.  A sloppy fit for the balance shaft drive dog.  The location in the engine and the parts involved will cause the resulting sound to be transmitted throughout the entire engine making it sound like it's coming from everywhere.
* DSCN1758.JPG (46.82 kB . 768x576 - viewed 1288 times)
If you like you can tear down your engine to confirm it.  My bike has made an awful clank at low rpm and under heavy load when I don't downshift enough since I got it 6 years and 45,000 miles ago.  Despite the noise it has run like a bear and taken me across country 3 times since I got it.
I've found that keeping the revs up and wearing earplugs has made our time together much less stressful.  It also helps a lot to keep your valve clearances as close to each other as possible as well as close balancing the throttle bodies.
Post by: bgcameron on April 20, 2021, 10:24:58 AM
Thanks for that info. I am not sure that is the issue I am having though. The engine is completely smooth sounding throughout the rev range, but then right at 3500 rpm under certain light loads it sounds like a rock banging around in a tin can. It is so loud that it is startling. Unfortunately I wasn't really able to capture the sound well in my video.
Post by: Laitch on April 20, 2021, 10:48:01 AM
Then enjoy the hunt! Let us know what it is, how much it cost you to find out and the remedy. Maybe someday, despite everything, you'll ride the moto only to enjoy its g-forces and the scenery flowing past you. icon_cheers  That will be challenging.  :laughing4-giggles:
I wish you peace during this difficult time for you.
Post by: daveson on April 21, 2021, 08:39:16 AM
Would it be worth a bit more searching to try to pinpoint its location?
A few more desperate maybe's. If the noise is louder with the fuel cap opened, have a bit of a look, maybe a filter or hose tapping against the tank,  or pump.
You might have two different noises, one about idle and one at ~3,500rpm. If you pull the clutch in about half an inch (or as much as you can without letting it slip) check if the noise at revs then disappears.
Maybe with a screwdriver to help, check for a healthy click from the injectors, timing light in synch with plugs, headers. Gear box and stuff. Granted it's desperate, but easy checks
Post by: Laitch on April 21, 2021, 09:48:30 AM
More ride, less rumination.  112350
Post by: bgcameron on April 23, 2021, 01:02:55 AM
So I took it out again today. The noise was ever present at any gear and (almost) any speed, as long as there's a light load. Now here is where it gets confusing:
Going up a slight hill, when I heard the rattle I pulled in the clutch and held the RPM around 3500 with the throttle. The noise persisted until the bike slowed down to under 20km/h or so.
I figure this should either narrow it down or do the opposite!
Post by: daveson on April 23, 2021, 08:55:11 AM
You could also call it a tappet noise. Did you check the valve clearances when you had the valve cover off? You might have some excessive gap/s.
Post by: bgcameron on April 23, 2021, 11:45:19 AM
The valve clearance is all within spec.
Post by: Laitch on April 23, 2021, 03:22:00 PM
Your latest description characterizes it as something other than an engine noise, bg. As long as it doesn't start telling you to strip in public or ride to Victoria wearing a loincloth and carrying spear to storm the Parliament Buildings, I think you're OK.
Post by: daveson on April 23, 2021, 07:24:54 PM
Rolling three threads and two forums into one, well done.
A bit of biffo never killed anyone
(excluding fatalities)
Post by: bgcameron on April 23, 2021, 10:19:10 PM
Nobody would bat an eye in downtown Victoria!
I am confident now that it isn't the engine.. I am wondering if it is something to do with the clutch. Whatever it is, it is certainly loud. Cruising on the highway between 3500 and 4000 rpm it is just a consistent rattling sound.
Post by: Laitch on April 23, 2021, 11:06:28 PM
Record the noise under the new conditions you're describing. If you can't find a recording device that will accommodate a microphone with a long cord so you can affix the microphone on the frame, get a friend and have the friend drive next to you operating a boom microphone close to the frame near the intermediate housing while you perform your novel noise propagation technique with the moto. Nobody will bat an eye. Post the video.
Post by: bgcameron on April 23, 2021, 11:51:32 PM
Here is a better video clip of the noise. Don't ask me how I did it haha. The sound is clearly heard at about the 24 second mark.
https://www.youtube.com/watch?v=47n3G3m4HSU
Post by: daveson on April 24, 2021, 05:58:41 AM
How did you do it?
Where was the microphone?
Did you try with the clutch pulled in a small amount (putting pressure on the clutch basket) to see if it eliminates the sound, or changes it?
Good work on this recording.
Post by: Laitch on April 24, 2021, 09:33:27 AM
Instead of being coy, explain how you did it so somebody else who has a similar noise sensitivity can risk life and limb to record it for the benefit of others who want to identify it. :laughing4-giggles:
I have some questions.
Did you remove the timing chain guide rail and inspect within it for wear?
Did you remove the slide rail and inspect within it for wear?
Did you remove remove both the chain tensioner and tensioner strap to inspect them for grooves and other signs of wear?
Did you remove the tensioner plunger (pedestal) housing and the plunger itself to examine the condition of the assembly?
Post by: bgcameron on April 24, 2021, 11:07:00 AM
I taped my phone to the intake pipe on the right side of the air box.
Clutch pulled in, noise continues. Laitch, when the cover was off i checked all those components as you mentioned. Everything looked fine.
Post by: Laitch on April 24, 2021, 11:33:36 AM
How many Kms on the moto?
Post by: Laitch on April 24, 2021, 11:44:48 AM
Does that mean you removed all those components and inspected them? While you're thinking of things to keep from enjoying the ride, check all the exhaust manifold bolts for tightness when the engine is cold.
Post by: bgcameron on April 24, 2021, 02:31:13 PM
I removed everything. The bike has 53,000 kilometers on it. It is a local bike and I am the third owner.
Post by: Laitch on April 24, 2021, 02:55:13 PM
That's early for a timing chain to stretch or wear. Since you've apparently confirmed the proper function of the rest of the parts in there, the hunt will continue. Don't forget your earplugs.  icon_cheers
Post by: daveson on April 24, 2021, 07:25:59 PM
Do you have this regardless of the engine being warm or cold?
I'd almost punt it could be a worn annular spring between the driven gear and idle gea, or shim. Is there a thread with this problem that has sound? In this case I'd just wear earplugs, mind you I wear earplugs without this sound.
Could you post photos of the bike and instrument cluster? Any signs the mileage isn't genuine?
Post by: bgcameron on April 24, 2021, 09:14:29 PM
It seems to happen regardless of temperature. I have no doubt that the mileage is genuine.
Post by: daveson on April 25, 2021, 03:24:54 AM
Why are you confident it's genuine? There's a fair few threads with the plastic cogs broken, they're like thirty years old, most of mine were wonky.
Anyway I'm curious, in Canada are bricks European (i.e. rest of world?) spec. or US? In the US bricks have miles on cluster and no light switch on the right handlebar. In Australia bricks have kilometers and a light switch. Does yours?
Post by: bgcameron on April 25, 2021, 04:50:33 AM
Local bike. The original owner didn't ride it much and the bike sat in storage for at least a few years. The 2nd owner didn't own it for long. The odometer reading between the first and second sale ads only changed slightly.
I believe this it is essentially the same as a US spec bike, but with a km/h cluster.
Post by: daveson on April 25, 2021, 06:09:05 AM
So no light switch but km cluster? Dunno if that's normal for Canadica. How's about photos.
What maintenance history do you know of?
Post by: The Mighty Gryphon on April 25, 2021, 08:06:09 AM
53,000km and spent at least a couple years sitting in a shed before it was sold to a guy who didn't ride it?
53,000km/30,000mi is barely broken in.  Sitting around unused sticks the pintles in the injectors and the rings in the pistons.  I'm surprised it runs.  All that engine needs is a couple thousand miles of 4000+rpm yeehaw to loosen things up.  Buy some friggin' earplugs and ride the damn thing.  You've checked everything and can't find any problems so go and ride it.
Post by: bgcameron on April 25, 2021, 08:25:09 AM
Some internet sleuthing revealed some maintenance history! See the article about splines. Hopefully this link works. If not, I will try to fix it later when I am not posting from my phone.
https://www.google.com/url?sa=t&source=web&rct=j&url=http://static1.1.sqspcdn.com/static/f/760327/10120680/1294422490340/Beemer-Reader-17-09-September-2007.pdf%3Ftoken%3DmUfDhk4UT6LaBs50vL3N690JJFQ%253D&ved=2ahUKEwjV96nysJnwAhWyPH0KHWRFDQQQFjABegQIDhAC&usg=AOvVaw2SZu79ToCsVdlJfSTOSxyh
Post by: The Mighty Gryphon on April 25, 2021, 08:45:37 AM
Is this article by the guy who owned the bike before you?  Here is what splines that get a light coat of HondaMoly 60 every 10,000 miles look like at 98,000 miles(160,000km).
If your splines are okay, and they should be after a mere 53,000km, then throw a little lube on them and ride the damn bike.
When you put the drive shaft back in after you do the lube, make sure it's locked into the transmission output shaft.
Post by: bgcameron on April 25, 2021, 10:49:40 AM
How's about photos.
(https://fotobucket.site/uploads/48b52181cc0def1cb4ac7347ebb16db39874689d.jpg)
Post by: The Mighty Gryphon on April 25, 2021, 12:00:48 PM
My advice is to sell it to me.
Post by: Laitch on April 25, 2021, 12:08:07 PM
You've got a gen-u-ine BMW comfort seat there, bg. They aren't common but get much better reviews for long distance riding than the OEM bench seats.  112350
Post by: daveson on April 25, 2021, 05:24:40 PM
That's absabloodylutely spotless, I should have known.
How's about the instrument cluster.
Hopefully, as has been said, just needs the cobwebs shaken out of it.
Post by: bgcameron on April 25, 2021, 05:54:16 PM
(https://fotobucket.site/uploads/68b6b8849609c3407d260ac20756c05735160017.jpg)
It's actually a reupholstered Corbin. It looks very similar to the comfort seat.
Post by: Laitch on April 25, 2021, 06:13:06 PM
:nono2: We'll need to see its papers. If it was a Corbin, it wasn't reupholstered; it was stuffed.  :laughing4-giggles:
Post by: daveson on April 25, 2021, 06:42:40 PM
All good.
Since you don't have many posts, l looked at them for photos without luck, but noticed at least one valve out of spec. Over max for exhaust, surprising, dunno if you fixed it.
Anyways, it wants a full service and a lot of Kay's.
If you still have the noise, could it be something stupid like a loose air box vibrating? I was chasing a knock in the back of my car once, eventually, eventually I fixed it after emptying the crap out of the trunk. Then repacked it.
Another thing, the annular spring has been under compression for thirty years, regardless of the mileage, it may have lost some tension by now, with the result of a rattly idler gear. Big deal, you don't need an idle gear, you could throw it in the bin (it's only there to reduce noise, if rattly only increases noise.)
Post by: bgcameron on April 25, 2021, 07:08:26 PM
I replaced 2 shims to bring it into spec. One was a hair tight and one was a little loose. I was thinking there might be something loose inside the airbox so I went through it and couldn't find anything.
I've been in touch with a local gentleman who has been riding a K75 since he bought it new in the mid 90's. He's offered some guidance on servicing and thought that the clutch splines are worth looking at.
Is the rattling idle gear the one that tends to make a bit of a zipper type of sound with abrupt revs from idle?
Post by: daveson on April 26, 2021, 12:22:40 AM
Dunno.
How's about a video.
I spose the air box idea was wishful thinking on my part, I forgot the handlebar vibrating symptom.
Post by: bgcameron on April 26, 2021, 12:49:13 AM
Found some good info in here: https://www.k100-forum.com/t10397-engine-clatter
It may be a matter of simply retorquing a the clutch housing retaining nut.
Post by: daveson on April 26, 2021, 06:27:16 AM
That's why I asked if pressure on the clutch changes the sound, but it didn't, making me back away from the idea.
So probably not a good idea to turf the idle gear in the bin, I forgot about its oil gallery, not that it'll come to that anyway.
What an incredible example of attention to detail by BMW, this oil gallery is. It can only rotate a small amount on its shaft, between two teeth of the driven gear.
Post by: bgcameron on April 26, 2021, 06:39:54 AM
So probably not a good idea to turf the idle gear in the bin,  I forgot about its oil gallery.
Perhaps there is still slight contact between the clutch plates that is enough to agitate that gear in the balance shaft. Regardless, I should do a full spline service anyways and torque that nut while I am in there.
Post by: daveson on April 26, 2021, 07:27:13 AM
Yep if the clutch nut turns with your torque wrench at its setting, its been loose.
While you're there,  check that the balance marks are in the right place. There was a thread where an unbalanced clutch caused a noise, but not vibration, surprisingly, maybe since the output/balance shaft turns in the opposite direction to the crankshaft.
Post by: daveson on April 27, 2021, 11:04:43 PM
OK another guess is that reduced tension in the circlip (or it's opened a little) could result in your symptoms, with the result of endfloat on the driven gear and maybe a bit of slop with the idler gear, but only under light load, so while coasting the spring load might be sufficient.
I've added more reasons to your link above.
I think with the crank cover removed you have a small window of access to the driven gear. Probably only useful to check for slop between the drive gear and driven gear pointing to reduced tension from the annular gear. Unlikely, but easy to check for. If there was any endfloat with the key off, you'd think the noise would be at all rpm ranges.
Please chime in if you think this is crap, it could well be, I don't want to waste anyone's time.
Post by: daveson on April 28, 2021, 03:13:47 AM
How the parts interact, this drawing is a k100, but the gears and circlip arrangement is similar. Not exact or to scale, just to help understand it.
Post by: bgcameron on April 29, 2021, 04:48:56 PM
I showed the sound clip to the local BMW expert. He thinks it's the starter clutch. Will start disassembly soon.
Post by: daveson on April 29, 2021, 04:55:27 PM
Are you going to open the starter?
Unfortunately there's no clutch in the starter.
Post by: rbm on April 29, 2021, 05:07:05 PM
I think he's talking about the spray clutch in the intermediate housing.
Post by: daveson on April 29, 2021, 05:17:33 PM
True.  I was wondering if the BMW workshop is going to disassemble soon or bg is going to open the starter soon, or something else.
Post by: bgcameron on April 29, 2021, 08:11:10 PM
Well, I am hoping to do the work myself. Has anyone here checked this component? It seems like the common issue with it is a no-start condition, but I have not read anything about it making noise.
Post by: daveson on April 29, 2021, 08:59:41 PM
What work are you planning on doing? Opening the engine? That's a big job. I'd do some tests first to confirm it's the problem before doing that. Has the starter been working normally, does it sometimes slip? The crank could release the clutch, hard to imagine it could engage it.
If he means the starter is turning the clutch, I'd remove power to it (and insulate) and see if the noise disappears.
Post by: Laitch on April 29, 2021, 09:13:25 PM
:popcorm
Post by: daveson on April 29, 2021, 09:26:53 PM
Dunno if it's been mentioned yet but removing the alternator might have an effect on the noise.
Post by: rbm on April 29, 2021, 09:28:10 PM
it was mentioned.
Post by: daveson on April 29, 2021, 09:38:26 PM
True. I see that now, but I don't think it's been removed because the video example sounded different to bg's brick.
its an easy thing to try.
Post by: bgcameron on April 30, 2021, 01:34:50 AM
I am doubtful that it's the starter clutch.. The starter functions as it should. I am going to to the spline service as planned, torque the nut and hope for the best! Hopefully will get around to it next week.. lots on my plate right now.
Post by: daveson on April 30, 2021, 02:57:06 AM
Good luck.
I'll be keeping an eye out for the result.
Post by: daveson on April 30, 2021, 08:23:21 AM
I've just cast an optic nerve over the video of the timing chain. Any thoughts out there about the timing marks looking to be a little bit out?
Just a stab in the dark.
Post by: bgcameron on April 30, 2021, 11:42:36 AM
I think it's the angle of the video. Look at how the holes in the gears align with the base of the camshaft caps.
Post by: daveson on April 30, 2021, 05:47:53 PM
True.
That dog don't hunt.
Post by: bgcameron on May 02, 2021, 03:14:38 AM
I did the disassembly today. Nothing appears to be out of the ordinary. All the splines are well-lubed, the U-joint feels good. The clutch housing nut seems tight, and it did not move under 100 ft-lbs of torque.
Post by: daveson on May 02, 2021, 03:39:09 AM
I'd mark the nut and shaft for reference, back it off the slightest amount possible (even less than 1/16 of a turn)  it might torque up further cause it takes more to start than to maintain when you get going. If the cover is still off.
Post by: daveson on May 02, 2021, 03:47:38 AM
Anyways was just about to post.
Straining an optic nerve further still.
That black plastic thingy between the steel backing of the chain guide and the tensioner; is that cracked? That's what it looks like to me. If so, could that increase the oil flow and reduce the oil pressure?
Apologies if this is yet another crap shoot.
Post by: bgcameron on May 02, 2021, 04:02:49 AM
When I had that apart I did not see any cracks. I'll recheck that nut torque tomorrow.
Post by: daveson on May 02, 2021, 04:22:33 AM
Ignore my clutch nut post for a mini, you don't want to back off the nut unless necessary. I just zoomed in on the tensioner. If that thingy is broken, it wants to be replaced, regardless.
Have a zoom at it.
Post by: bgcameron on May 02, 2021, 04:33:38 AM
I don't see what you're looking at. Could you do a screen shot and point it out? I had that tensioner strap out of the bike and I checked every bit of it and didn't see any cracks.
Post by: daveson on May 02, 2021, 04:40:03 AM
Dunno how to do that.
Zoom in where the tensioner contacts the backing of the chain guide. Looks like a bit of plastic to eliminate steel to steel contact.
I can't zoom when I press play, but in play mode the right half moves up and down. I'm more confident about it after I zoomed in.
Post by: daveson on May 02, 2021, 04:42:19 AM
This one is from a k100.
Did you check the black bit on the back?
Post by: bgcameron on May 02, 2021, 04:56:21 AM
I see what you mean now. I am 99% sure I checked that and didn't see any cracks. Isn't it more of a rubber than a plastic? Perhaps in the video it is squeezing and making it look like a crack?
Oh dear :( I really don't want to take that timing cover off again..
Post by: daveson on May 02, 2021, 05:11:14 AM
Mine's rigid plastic like.
It's easy access, especially compared to taking the output shaft out.
To me the video shows movement on the right hand side, like its come away from the guides backing, but that's with a small phone screen.
Post by: bgcameron on May 02, 2021, 05:20:00 AM
Perhaps I'll take a look during my next coolant change, which may happen soon because the water pump appears to be leaking from the weep hole. Speaking of leaks- it's leaking gas too.. not much, but there is some corrosion in the bottom left seam of the tank.
I'm tempted to send the bike out for a buoyancy test.
Post by: Laitch on May 02, 2021, 07:47:37 AM
:popcorm
Post by: daveson on May 02, 2021, 08:22:26 AM
This might also explain your zipper sound with abrupt revs from idle.
Maybe try the screwdriver sound test on the timing chain cover, about where the tensioner is, with sudden revs from a helper, and the other conditions.
If you gradually increase revs over 3,500 rpm, does the noise remain, or gradually reduce, or suddenly disappear?
Watchyagot.
Post by: bgcameron on May 02, 2021, 09:10:51 AM
This is the "zipper" sound I was referring to. My bike does this somewhat but it doesn't sound nearly as loud as the rattle I am getting. I've gone over the engine with a stethoscope and I wasn't able to find anything obvious. It's difficult to use the stethoscope while riding.
https://www.youtube.com/watch?v=HfDR3tkR8C0
Post by: daveson on May 02, 2021, 09:33:58 AM
How's about the noise remaining or disappearing, gradually or suddenly, at some point after your noise at 3,500rpm?
I ask because if it disappears, that might be at a point where the oil pressure finally reaches a high enough point for the tensioner to work properly.
Watchyagot.
Post by: The Mighty Gryphon on May 02, 2021, 12:26:38 PM
God!  I'm loving this thread! :popcorm
Post by: bgcameron on May 02, 2021, 12:35:30 PM
Its turning into a bit of a Saga.
Post by: daveson on May 02, 2021, 01:32:02 PM
NFCKNBLVBL.  :popcorm
Post by: bgcameron on May 02, 2021, 02:02:14 PM
Watchyagot.
The noise seems more sudden. Here's another sound clip. The noise starts kicking in at about 15 seconds. Towards the end I pulled the clutch lever and held revs.
https://www.youtube.com/watch?v=Abu6FVNiNlM
Post by: Laitch on May 02, 2021, 04:05:39 PM
Try this (https://ibmwr.org/index.php/2001/11/01/timing-chain-rattle-diagnosis/) on for size, bg. Bon voyage!
Post by: bgcameron on May 02, 2021, 05:12:12 PM
Thanks Laitch. I had a look at that article prior to checking the tensioner and made a point of checking that little piece for wear.
Post by: daveson on May 02, 2021, 06:10:55 PM
Dunnowaddamake outtada last video.
If it's broke, replace it, if your lucky the noise will be gone.
That's not a saga.
I've seen a thread that was longer than War and Peace, that's right and I'll say it again too, it was longer than War and Peace. There was a noise from the water pump and cylinder four so the engine was opened and the output shaft came out. All sorts of measurements were made, and heaps of parts replaced with new. After it was all stitched up, the noise remained the same.
That's a saga.
Post by: bgcameron on May 02, 2021, 06:33:11 PM
Oh man, that sucks. I hate noises but I have boundaries! At least with this job I am doing a full spline service. I've been finding other things here and there while I'm at it and learning lots about the bike.
Post by: daveson on May 02, 2021, 06:56:29 PM
Would you say the sound changes or disappears over a  certain rpm, if so when?
Post by: Laitch on May 02, 2021, 07:00:12 PM
Thanks Laitch.
:popcorm
Post by: bgcameron on May 02, 2021, 10:35:58 PM
It seems to disappear after 4000 rpm.
Post by: daveson on May 03, 2021, 02:53:25 AM
Good link Laitch to Colin Carpenter, so even if it ain't broke, might need replacing due to wear.
Post by: Laitch on May 03, 2021, 09:00:05 AM
. . .  even if it ain't broke, might need replacing due to wear.
:tinhat2:
Post by: The Mighty Gryphon on May 03, 2021, 09:42:48 AM
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=bmw+k75+engine&_sacat=0
Post by: Laitch on May 03, 2021, 10:13:37 AM
 :laughing4-giggles:
Post by: daveson on May 03, 2021, 11:45:59 AM
If I had these symptoms on my bike and that part of the chain guide was broken or worn, I would just replace the chain guide. A partial failure there could explain why the noise disappears at about 4,000 rpm.
Why the tin hat? The reference from Colin Carpenter also says it might need replacing if worn.
Post by: Laitch on May 03, 2021, 03:22:52 PM
bg has asserted that everything in that timing chain case has been inspected right down to the molecular level by bg's own eyes, and everything is OK.  icon_cheers
Post by: bgcameron on May 03, 2021, 03:34:06 PM
If the noise persists after I put the drivetrain back together then I might just check that tensioner again for peace of mind. If that piece is cracked then I'll eat my shorts.
Post by: daveson on May 03, 2021, 07:36:41 PM
I was thinking about people reading the thread, I didn't actually say it needs replacing.
True, I didn't notice wear on mine until after I read the link, and If that piece is broken it may, or may not, have anything to do with the noise, but wants to be replaced anyway.
Bg you won't have to eat your shorts either way. At this point there's still a lot of options, for example it's not surprising it's not worn, it's low mileage, but it's thirty years old. The bonding may have partially failed after you looked at it, while installing, say while the guide rail was clipped to its steel backing, or clipping the tensioner on, and cracked later.
When I zoom in I see a black line between two pieces, with the video I see hinged movement on the right side.
Bg, look at the video on full screen and ask yourself this question "does it look like one piece solidly bonded to its backing?" Show this video to anyone and ask them if it looks like mine (please don't ask them if the timing marks align)
To me it definitely doesn't look like mine. If I'm wrong I won't have to apologise because I already did, so there.
I'm hoping I'm right because that's an easy fix.
Post by: Laitch on May 03, 2021, 08:47:27 PM
Maybe you should step up like bg and eat your shorts, too. It could be a Zoom event, and posting a link to it here would relieve the tedium. bg's getting adept at video.  :popcorm
Post by: daveson on May 03, 2021, 10:20:56 PM
I've already said, on this thread, some of my posts could be crap.
This chip is on the same side as your video, maybe it's just a chip we see.
Post by: daveson on May 07, 2021, 05:02:58 PM
Hmm I'm not so sure now after looking at it on a computer screen.
Post by: daveson on May 08, 2021, 04:16:11 AM
Hey Branden, here is something to consider while the gear box is off. This is my guess, hopefully my last guess.
It's the circlip.
It could be fatigued or partially unseated from its groove, weakening its effectiveness. Your symptoms are a snug fit for this, I think.
Here's the good bit, since your there anyway, with the clutch basket removed you have a small window of view to see if the circlip is fully engaged in its groove, all the way around.
Here's an even better bit, with the seal removed you have access to the circlip, without having to split the engine.
That circlip has been under constant compression for thirty years, it could be fatigued.
The K75 does not have a diaphragm spring, like the K100 does. The side load from the gears, with their helical cut teeth, would put the circlip under substantial compression in emergency braking situations. The K100 has a diaphragm spring to bear that load, which would be stronger. With the K75 that compression could partially dislodge the circlip. I would guess though, it would be more likely to be fatigued after years of accelerating and braking forces.
I would take a photo of the circlip, then check that it makes contact with the bearing and see if it can be pressed further into its groove. I feel that it will make contact but might not at 3,500rpm.
If your able to speak with the previous owners, it would be worth asking about its service history, and maybe if there were any occasions of emergency braking.
If I was that far in there anyway, I would replace the circlip.
It's not the only possible cause of output shaft endfloat, but I think it's an easy access option.
Post by: alabrew on May 08, 2021, 11:16:10 AM
I've had a Brick since 1990. They rattle and make all kinds of noises.They perform wonderfully. The best accessory is noise canceling headphones.
Post by: bgcameron on May 08, 2021, 03:13:40 PM
It's the circlip.
Doesn't the K75 have flat drive/driven gears? Without removing the seal, I was able to look around the edge of the circlip. I used an angled pick to reach the holes in the circlip and verify that they are snug.
Post by: daveson on May 08, 2021, 05:51:40 PM
Your right, I just googled a photo of it. I never noticed that difference between the k100 and k75, but I've only looked close at a k100. I spose the k75 has straight cut gears because the diaphragm spring was deleted.
So ignore the side load comments. Still, let's say the circlip is fatigued from 30 years of compression, like I said I'll guess it's still snug. A weak spring could be OK while the engine is stopped or at idle, but could fail at 3,500rpm.
I mention this because you're only a seal away from access to the circlip.
I'm 99% sure this comment doesn't apply to you, but to anyone who has a brick with a rattle, an unknown service history and has removed the clutch basket, you should check that the circlip has been installed with the concave side facing the bearing. It's only the slightest bit concave and could be easily missed.
Post by: bgcameron on May 08, 2021, 07:04:50 PM
sidenote: as I am getting ready to put this thing back together I will need some spline lube. What is recommended and what should I avoid? Is Castrol Molub-Alloy Paste TA good?
Post by: Laitch on May 08, 2021, 07:22:01 PM
Molub TA will do.
Here's an acceptable way to apply it.
https://www.youtube.com/watch?v=87FfDU5r640
Post by: daveson on May 09, 2021, 05:52:17 AM
Righto here I go again with another long shot, but since the BMW expert mentioned the starter clutch, and I'm hoping the gear box and starter are still off, try this. Put your finger through the hole for the starter, wiggle the idler gear, see if you can move it forward and back with its shaft, you shouldn't be able to, unless the spring is broken.
It's only a 60 second check.
Post by: The Mighty Gryphon on May 09, 2021, 07:23:40 AM
As long as we're getting really serious about this, maybe you should tear down the engine and remove the output shaft and idler gear.  You can then take them to a machine shop to have the dogs welded and given a better fit in the slots so they won't bang around.
While it's apart, pull the pistons and rods to make sure you aren't getting any piston slap and that the big end bearings are in spec.  I'm guessing that you will find all is well, but it might give you some peace of mind.
Post by: daveson on May 09, 2021, 07:54:34 AM
I've been wondering about this topic when it comes up, dunno the answer. If it was the tabs, why don't all k75's do it? And why are the machine marks still on it? 100 ft/lb is more than enough I'm thinking, and it's more than the k100, so that's telling. I think I found from a previous thread, that the tabs are only there so that the shaft can only be installed one way, so a precision fit isn't required.
It would be interesting if someone gets to the bottom of it.
The biggest bonus for me with this thread so far, this is the first time I actually heard it (the later video, post 61)
Post by: Laitch on May 09, 2021, 09:05:40 AM
If the gear could be wiggled on the shaft, wouldn't that be accompanied by audible Clicks?
Post by: daveson on May 09, 2021, 09:10:45 AM
Yeah it was, it was louder than I thought, I spose it's about time I learned how to post videos.
You know what, in that post the sensible part of my brain defeated the biffo part of my brain, which wanted to say "if there's any axial movement there whatsoever, it's because the spring has been under constant compression for thirty years"
Post by: Laitch on May 09, 2021, 09:14:26 AM
. . .it was louder than I thought, I spose it's about time I learned how to post videos.
Louder than you thought, or louder than you expected? Did you check it for rattle after you replaced the spring?
Go to YouTube. Instructions for posting videos are there, then you post the link here.
Post by: daveson on May 09, 2021, 09:32:32 AM
It's from a spare engine I have that's been dismantled for years. I checked the gear on one of my bricks and there was no fore, aft movement. I mentioned the wiggle because if there's a bit of jamming going on you could be tricked into believing there's no movement, when there's actually a lot,  about 5mm.
I meant it was a lot louder than I expected,more than a quack, probably deserves the honour of a clatter, dare I say a knock.
I wonder if the noise would have been louder if the microphone was taped to the starter motor?  It's on the left hand side, that's the side that was originally thought to be louder.
Post by: Laitch on May 09, 2021, 10:36:42 AM
I meant it was a lot louder than I expected,more than a quack . . .
Was that more than the volume of a startled quack, a courtship quack, a maternal quack, a quack in flight or a quack on a still pond in early morning?
Post by: daveson on May 09, 2021, 06:27:56 PM
It was desperately loud, like the sound of an African duck attempting to cross the Mediterranean with a coconut tied to its testicles.
Post by: bgcameron on May 09, 2021, 07:48:34 PM
Who are you, who are so wise in the ways of science?
I checked that gear for movement and felt nothing...nadda.. Ni!
Post by: daveson on May 09, 2021, 07:59:33 PM
Well you have to know these things if you seek the Holy Grail.
One of the jokes lost on young ones watching it now was the intermission. Back in the days you couldn't expect people to remain seated for two hours in a cinema. I remember when the intermission sign came up, people started making their way along the aisle, suddenly the movie started again, and everyone rushed back to their seats.
It's good you have no movement there, it's not easy to replace if Faulty.
Post by: Laitch on May 10, 2021, 10:17:16 AM
. . . it's not easy to replace if Faulty.
Faulty Towers?
Post by: daveson on May 10, 2021, 04:26:30 PM
Yeah,  I was trying to be economical with my words,  since that post was way longer than it deserves to be. I almost got away with it, until you noticed that.
I've noticed that attention to detail is one of the items in your tool box. I've been thinking to myself, I should try that. As you can see from this thread, I need more practice with it.
Post by: daveson on May 10, 2021, 07:27:49 PM
Can you tell us about any non routine work done on your brick, mechanical, cosmetic, anything? Anything by previous owners?
Did your brick come with a workshop manual/s and which?
Post by: bgcameron on May 10, 2021, 07:38:34 PM
The only thing I know of is the Bruno-modded rear drive. Speaking of that- in the article I linked to a few pages back, the original owner said that the U-joint mod was done.. but there is no serviceable U-joint on this driveshaft.
Post by: daveson on May 10, 2021, 07:53:23 PM
Where the frame bolts to the intermediate housing, do you have a shim between the two? I believe you should have.
Post by: bgcameron on May 10, 2021, 08:07:46 PM
Yessir.
I just spoke with the original owner of the bike. He purchased it new in 1990. It sounds like most of the its mileage was done on the highway. He is going to dig up his service history on the bike and send it to me.
Post by: daveson on May 10, 2021, 08:18:11 PM
OK, it's hard to find fault with a low mileage brick that looks absabloodylutely spotless.
I'm running out of useful suggestions, in case you haven't noticed.
The original owner could be the key to this. I'd ask if he noticed this noise, if it developed gradually or suddenly, or anything about it. You might be able to link it to something in the service history.
Post by: Laitch on May 10, 2021, 11:17:45 PM
It didn't seem that hard for bg.  :laughing4-giggles:
Post by: daveson on May 11, 2021, 06:59:49 AM
Yeah I should have said it's hard to find the cause of the fault, I'll bet it didn't leave the factory like that. I have a 1991 K75 S, it doesn't have that noise. Until you get the service history, maybe try the microphone on the starter or a few places to see if you can pinpoint it better, or an Italian tune or something like that.
Where I was going with the previous posts was hoping the frame was removed for painting or something, and not installed correctly. Although that possibility is almost eliminated, it might help someone in the future reading this.
If the frame is attached using the Clymer manual as a guide, the shim location and bolt tightening sequence will be wrong, since the k75 sequence is different to the one given.
Hopefully Gryph might chime in again, at least I'd be interested to know if his noise sounds like your recording.
Gryph, help me out here. Your saying ride, free up the rings, get fuel through the injectors, shake the cobwebs out. Yep, I'm with you there, you know I'm with you there, but your well ridden brick does it too. I'm trying to get something that fits, it's like almost there, but just not there yet.
Post by: Laitch on May 11, 2021, 07:55:36 AM
. . . the original owner said that the U-joint mod was done.. but there is no serviceable U-joint on this driveshaft.
If there is no zerk, the guy's a jerk, to paraphrase Johnny Cochran. :laughing4-giggles:
Post by: Laitch on May 11, 2021, 08:15:30 AM
Until you get the service history, maybe try . . .  an Italian tune or something like that.
I suggest La Primavera by Vivaldi. It's the perfect time of year for that.  112350
Post by: daveson on May 11, 2021, 08:35:42 AM
As soon as you say La, I'm hearing La Bamba I'm off to YouTube land for a dose of it now.
Post by: bgcameron on May 13, 2021, 01:41:40 PM
UPDATE:
Bike is back together and the noise is nearly gone. Under the same riding conditions it will make the occasional "tap" sound but nothing in comparison to the clatter that was audible before. My best guess is that culprit was the nut on the balance shaft.
Post by: Laitch on May 13, 2021, 01:53:44 PM
From your post, it appears like you did nothing to the nut because the nut seemed tight. Maybe the cure was just the laying on of hands. I've seen that work miracles in venues as disparate as fundamentalist churches and South Dade honkey-tonks.  :laughing4-giggles:
Post by: The Mighty Gryphon on May 13, 2021, 02:15:57 PM
  icon_cheers Great!!! icon_cheers  Now, please go out to ride and enjoy the hell out of your bike.  Learn to ignore the noises and concentrate on having a good time.  You have a beautiful bike that can bring you many years of enjoyment.
Post by: bgcameron on May 13, 2021, 02:55:52 PM
I forgot to mention that I replaced the nut and o-ring while I was in there. I gave the new nut just over 100ft lbs of torque.
Post by: The Mighty Gryphon on May 13, 2021, 04:43:43 PM
Okay, if you go back to post #49 in this thread and look at the photo, you will see that the two parts are pulled together by the clutch nut.  When you tightened it, you increased the pressure holding the faces together so they are more difficult to move relative to each other and make the tang clank in the slot.
It's nice that you have reduced the noise, but be aware that some time in the future, the friction between those parts will decrease enough to allow your noise to return.  I hope that by that time you are able to ignore it and just ride the bike.  It won't hurt anything.
Post by: bgcameron on May 13, 2021, 05:06:55 PM
Well, hopefully it doesn't return. Perhaps that wasn't even the issue at all.
I could not accept a clatter as loud as what my bike had. Hard for me to ignore.
Post by: daveson on May 13, 2021, 05:19:40 PM
Bonus, good work.
I'll also guess the clutch nut is on a little tighter, a nut on a bit under 100 might not move cause it takes a bit more to get going.
So it's not eliminated but way better, good. The next rider with these symptoms who is removing the clutch basket has an easy opportunity to see if replacing the circlip eliminates the problem.
Gryph help me out here, the balance shaft isn't doing much more than driving the pump, could the forces overcome 100 ft/lb on the clutch nut? And if so, why don't all k75's do it? And at 3,500 rpm?  And the machine marks are still on yours? I'll have to say this again, I'm not a mechanic and this is over my head, but I think a new circlip MIGHT solve it, and it's easy to get to. I hope this doesn't come across as pushy, just trying to get to the bottom of it.
I spose someone will give the circlip a try in the future.
Branden, just curious, the clamped cuts in the old clutch nut, I spose they were closed?
Post by: The Mighty Gryphon on May 13, 2021, 06:41:33 PM
You WILL have the noise return if tightening the nut corrected it.  If it bothered you that much, I would advise putting the bike up for sale now before it returns.  Waiting until the noise comes back will only lower the final sale price and make the bike harder to sell.
Post by: daveson on May 13, 2021, 07:19:40 PM
Tightening the nut partially corrected it.
I think the clutch nut and circlip both contribute to eliminating endfloat. Let's look at the drawing and imagine the circlip totally fatigued, not just partially. It is so fatigued that there is a gap, between the circlip and bearing, even with the engine stopped. That would be worse again, possibly with a knock at all rev ranges. In that case you would still have a knock even with the clutch nut at 150 ft/lb.
On the occasion that the noise remained after pulling the clutch in, until it got to 20km/h, that again points to the circlip, I think. Pulling the clutch in compresses an already weakened circlip. In the video I think I hear the noise momentarily between gears when the clutch is pulled in. That was why I asked earlier about pulling the clutch without disengaging it, since it only happened under load.
There's a service bulletin relating to the earlier version about output shaft noise, due to, amongst other things, a loss of pressure applied by an idler gear diaphragm spring. The minimum action recommended, was that it be replaced. In the newer version, it's replaced with shims, pressure is applied on the bearing by the circlip. That also makes me think that replacing the circlip could be a fix, and can be replaced without splitting the engine, so that's one good thing.
Post by: bgcameron on May 14, 2021, 02:05:31 AM
Bonus, good work.
Yes, they were closed.
Perhaps the noise wasn't caused by the clutch nut at all. As Laitch said, "laying hands on it".. perhaps there is something between the engine and the rear wheel that tends to get cocked somehow and it gets fixed in the process of a simple spline lube.
Gryph, I may be a little OCD but I am not a defeatist. It would be silly for me to sell such a gem of a bike. These machines are rare around here and I've got enough mechanical aptitude to keep it running. Did you listen to my last two recordings of the noise? I was really hoping you would chime in and let us know if this is similar to what your bike was doing.
Throughout this process of the teardown there is a tool that I borrowed from the 30-year/370,000 km K75 owner that was extremely helpful. He took scissor jack and welded a plate to match the holes on the bottom of the gearbox where the center stand attaches. There are a couple of skids on the bottom to keep it from tipping over. This made removal and installation of the gearbox incredibly easy!
(https://fotobucket.site/uploads/870c65cdec2749dc5fcdbbb8a085b1e9f83bd61e.jpg)
Title: Re: K75 Engine noise
Post by: daveson on May 28, 2021, 10:02:46 PM
Rather than looking at a k100 drawing, and imagining the differences for a k75, here is a k75 drawing. Again, not to scale or exact, just to help visualize it.
Post by: daveson on February 13, 2022, 08:30:51 PM
Just adding a post to this old thread cause I have since read about three other problems similar to this, where the noise was related to the alternator. It could be the alternator, but more likely the rubber dampers between the alternator and the engine. They could have shrunk and/or hardened. It's an easy check. Since the dampers are about thirty years old, this noise could be the result even though this brick is in top condition and only has minimal mileage on it.
