TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: KCinSB on November 25, 2020, 10:13:07 PM
I guess its been 5 years ago, when the bike was still on the road, "we" did some brake bleeding. My K75 Buddy and I worked up a rig to pressure bleed the systems, and I recall it was a success after some fine tuning. I recall there was talk of the Dot4 at the time, and I think that's what we used. I still have Dot3 on the shelf in the garage, which I suspect should be simply discarded. I wanted to top of the Fwd reservoir, and now hear there is a Dot5 !! Is that OK to use if I think the fluid in the bike is Dot4?
What's with all the Dots for crying out loud.......... :idunno:
Use fresh DOT 4. DOT 5 is not compatible with DOT 4 or your moto's brake system. Your DOT 3 suppy is probably water-contaminated and should be appropriately discarded.
Here's a link (http://www.motobrick.com/index.php/topic,11014.0.html) to a page that contains a K1100 Riders Manual. It contains specs of your moto's various fluids and other useful information. Scroll down to find the link; click on it to download a copy to your computer. You'll likely be less confused, in some ways, from here on out. The page also contains a link to a BMW K1100 shop manual.
+1 to what Laitch said.... NO to Dot5, NO to Dot3 in the bike.
If the container has been opened, and it's over 1 year old, toss it, even if it is compatible with your cars/trucks(which ever you have).
When I bought my R1100, the PO put Dot3 in the front and it and it messed up most everything, Master seals went out(caused a leak that stripped the paint), both front calipers wouldn't fully release.
Luckily I had the parts from my totaled K to replace them with. A good flush and refill with Dot4 and all is good again.....I've not been so bold as to test the ABS on the front, though it does work for the rear.
Brake fluid is one of the least expensive fluids you need for maintaining a brick.
Five bucks will buy enough to do a complete brake flush on a bike with ABS. Keep the leftover stuff for topping up and toss it next year when you get a new bottle for the next flush.
It is DOT, not Dot, actually should be D.O.T.#
DOT = Department of Transportation and the number relates to the standards of the fluid.
