TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Blue85 on November 12, 2020, 11:28:28 AM
Ok my k100rs rear brake pedal way low for me.i cant push my foot down need it flush with the footpeg any ideas?
First, make sure there is not air in the system and the reservoir is full. My Ural had a similar issue with it's mechanical drum brakes, solve it by finding a rubber pedal cover the proper size. Might not raise it a whole inch but every little bit helps.
Saw and re-weld the brake pedal arm?? Glue on a hockey puck?
The bmw brake is set up and functioning as it should.i think i might epoxy a riser on top of it..can remove if needed
