TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Cafe racer on October 01, 2020, 09:57:15 PM
Checking the cooling fan operation. I had the bike idle untill the fan came on, gauge just above the centre, it run for only a minute, and gauge dropped to centre, this cycled a few times, I pointed my temperature measurement gun at the water pump, 105°c before tha fan, then when fan stopped it was 95°c again I cycled this a few times, the bike was in direct sun and ambiance temperature was around 26°c
So is this normal? Looks ok to me...
sounds like it is operating correctly
this from
https://ibmwr.org/index.php/2007/06/01/cooling-fan-diagnostics/
regarding two valve K bikes
according to the 93 K75S Owners' Manual:
Thermostat starts to open at 85 C (185 F)
Fan Cut-in at 103 C (217 F)
Overheat Warning Light at 111 C (232 F)
Pressure relief valve opens at 120 C/1.1 bar (248 F/16 psi)
Vacuum relief (return valve) opens at -0.1 bar (-1.45 psi)
