TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: 85killzillaRS on August 12, 2020, 03:55:50 PM
Title: Battery in tail
Post by: 85killzillaRS on August 12, 2020, 03:55:50 PM
I want to mount the battery in the tail. when I had the battery out I hooked up to the end of new 3' extension leads and meter read 13.3 volts. when I plugged it all together and turned the key to the on position it was dead, no power to the dash lights, nothing.
what am I missing here
Title: Re: Battery in tail
Post by: Laitch on August 12, 2020, 04:31:34 PM
Verify that the cables are connected to the correct terminal polarity.
Post by: 85killzillaRS on August 12, 2020, 04:37:17 PM
polarity is good,
red to red & black to black
Post by: Laitch on August 12, 2020, 05:23:36 PM
That doesn't tell me much. What is the voltage between the negative and positive battery terminals right now?
Post by: 85killzillaRS on August 12, 2020, 05:48:34 PM
13.3 at battery terminals & 13.3 at end of extension leads , I hooked it up to bike with correct polarity
I'm putting it back to stock for the moment & taking a quick ride
going to try and beat my old record of 15 min that I had with old coils  112350
Post by: Chaos on August 12, 2020, 09:05:01 PM
I assume you connected the new leads to the all of the original + and = battery leads?
Post by: 85killzillaRS on August 12, 2020, 09:17:25 PM
yes, I hooked up to the exact ones that I are connected now,  minus extensions
and it is powered currently
Post by: Laitch on August 12, 2020, 10:52:56 PM
Looks like you've found the problem.  icon_cheers   Did you set a record for ride length? :popcorm
Post by: 85killzillaRS on August 12, 2020, 11:50:21 PM
no record ride length yet, just went around the block, some day i’ll do a few miles
for the lead extension deal, Ï tried some 10 guage wire and it looks like that will do the trick icon_cheers
that will be my morning project for tomorrow
