TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: 85killzillaRS on July 08, 2020, 12:02:32 PM
Title: Engine Runs A Short Time Then Stalls
Post by: 85killzillaRS on July 08, 2020, 12:02:32 PM
Ï have ridden only twice since installing motor
both times it has started and ran great
Then after about a mile it dies and wont start, gas flows but no spark
Ive walkes it home twice, then waited over night, and it starts right up
-anyone have any ideas
Title: Re: Engine Runs A Short Time Then Stalls
Post by: The Mighty Gryphon on July 08, 2020, 12:17:47 PM
Can you hear the pump run for a second after you press the start button?  The four pin tank connector is a pretty common reason for non-running and random quitting.  It's the first thing I would check.
Post by: 85killzillaRS on July 08, 2020, 12:37:54 PM
gas pumps through, Ï can smell it and see it on a plug Ï pulled
Literally there is no spark
It just fired up
Im not ready to go for another mile ride and the push home
Post by: 85killzillaRS on July 08, 2020, 12:46:08 PM
yesterday gas was pumping and no spark
this morning it has fired right up
if Ï go for a very short ride it will die,
then fuel but no spark
Ï am not ready to do the same thing again
Post by: The Mighty Gryphon on July 08, 2020, 12:47:19 PM
When it shuts down, is it a quick shutdown like turning the engine off, or does it break up and die gradually?
Is the engine still cold when it shuts down?
If you pull the plugs out and dry them, will the engine start?
Are the spark plugs black and sooty?
Post by: Laitch on July 08, 2020, 01:04:11 PM
Ï go for a very short ride it will die, then fuel but no spark
Do you intend to check the frame ground connections for corrosion and tightness, battery connections for corrosion and tightness, the coil wires and terminals for corrosion and fit, the individual coil outputs, and tight connections on both the ignition control unit and the Jetronic connector, or have you already done that?
Post by: Martin on July 08, 2020, 01:49:51 PM
Hall effect sensors can overheat and shutdown, once they cool down enough they will recommence working. A hairdryer/ heat gun can be used to see if it is a problem. Start it up on the centre stand and point the heat gun at the sensor. If it shuts down you have found your gremlin.
Post by: Chaos on July 08, 2020, 02:42:15 PM
+1 on the HES.  When the go bad they work fine cold, quit working when they head up.
Post by: 85killzillaRS on July 08, 2020, 02:44:03 PM
all connections are good, battery is a new sealed dry cell
 when it stalls, it is as if gas was shut off.
Both times it stalled a bit after fan came on. Ï checked for any water leaks and didn’t see any. A heated hall sensor would make sense. I’ll try the heat gun on the sensor while it’s running method now.
Post by: 85killzillaRS on July 08, 2020, 03:15:41 PM
so heat gun pointed at small T-shaped cover on right front of block or do Ï need to open it up 1st ?
Post by: Chaos on July 08, 2020, 04:23:37 PM
take the t shaped cover off and heat up the innards, see if it stops running
Post by: daveson on July 08, 2020, 06:04:32 PM
Also, the fan shouldn't come on after a short one mile trip. Possibly the temperature signal is whack.
Post by: 85killzillaRS on July 08, 2020, 06:13:00 PM
it’s 105F today and Ï do have a heavy right wrist  :)
Post by: daveson on July 08, 2020, 06:17:53 PM
I'd still have a long sleeve shirt on.
Post by: 85killzillaRS on July 08, 2020, 06:52:17 PM
Ï always wear helmet, leather jacket, pants, boots, & gloves regardless of temp
it’s so important to keep the body & brain looking & working well !!!
Post by: 85killzillaRS on July 08, 2020, 10:34:52 PM
Ï looked it up
60f in Australia today - LUCKY
it was 105 here today and i’ve been in the F*ing garage
Ï should be riding sooner or later
Post by: 85killzillaRS on July 08, 2020, 11:15:43 PM
Ï put a heat gun on uncovered Hall, seemed hot enough, but it still ran. So i’ll put things back together and go for ride tomorrow. I’ll bring tools with me to pull plugs, and try to stay close to home for highly probable push back. If Ï can go early it should be warm and not HOT yet. It’s 9pm here now, perfect time to go work in garage for a little while. I’ll post any results tomorrow AM. Thanks for all correspondence, Ï do appreciate it!!!
Post by: Laitch on July 08, 2020, 11:44:50 PM
It's probably also like the electricity was shut off, too.  :laughing4-giggles: If it shuts off again when the fan starts, I might be tracing the fan wiring.
Post by: The Mighty Gryphon on July 09, 2020, 08:21:01 AM
When I shut off the fuel to an engine it stumbles to a stop.  Is that what yours did?  So, did it stumble to a stop, or did it shut off suddenly?
It's almost impossible for the fan to come on after 1 mile.  How long are you letting it idle before you go for a ride?  From the time you started the engine, how long does it take to shut down?  Is it the same every time?
Post by: daveson on July 09, 2020, 09:25:21 AM
"I checked for any water leaks and didn't see any"
You got any water?
Post by: Laitch on July 09, 2020, 10:23:16 AM
You got any water?
If you mean sufficient coolant in the radiator and its reservoir, that's a good question needing an accurate answer.  112350 Does the temperature light come on before the fan starts, when the fan starts or after the fan starts?
Post by: 85killzillaRS on July 09, 2020, 12:25:17 PM
some good info was posted,
i’ll go for a ride in a bit
today Ï will time it from startup & pay close attention to when fan starts, my radiator is full and catch can is half full, fan wiring is just the plug connected. It’s actually kind of nice expecting trouble, Ï won’t go far at all. Ï should be back in an hour or so and post my findings.
Ç
Post by: 85killzillaRS on July 09, 2020, 03:46:48 PM
Ï didn’t get started as early as Ï wanted, but now everything is put back together and i’ll go as soon as Ï shower, it’s already 108F today. So i’ll stay pretty close to home. All connections are good and tight. Lights work, rad is full, catch can 1/2, a gallon or two fuel. Someone asked if Ï have a pre-ride checklist. That’s pretty much it for a close to home cruise.
When/if Ï have trouble today, what should Ï be checking. Before, it wouldn’t spark for basically rest of day so Ï should have plenty of time to go through what Ï need to. I’ve seen some sort of trouble shooting guide here a while back. Would someone please post a link. Alright, i’ll be outta here in 20min
Post by: Laitch on July 09, 2020, 03:52:07 PM
Type troubleshooting guide into the search box at the top of the page, select entire forum then press Search.
Post by: 85killzillaRS on July 09, 2020, 04:08:17 PM
oh yeah, oil is good
it’s nice having the sight on the side of block ;)
Post by: daveson on July 09, 2020, 05:55:01 PM
Make sure the FU computer (fuel injection control unit, under the seat) is plugged in fully home.
Post by: daveson on July 09, 2020, 06:15:47 PM
I had a problem similar to this. The bike would go for about one minute, then stop. After endless hours of research, thinking about it, motobrick, and working on it, the problem disappeared as quick as a flash, after replacing that bloody FU computer.
Note to self for the one hundredth time, do the quick easy stuff first.
Post by: 85killzillaRS on July 09, 2020, 07:43:05 PM
¡¡¡ ok !!!
Ï started it, let it warm for a min & then drove 1/4 mi stopped and put a gallon of super. Then drove around neighborhood for about 15 min, 2nd & 3rd gear. Then it died, as if something was just turned off. It wouldn’t fire. The red light with triangle in middle of dash is on now. Ï did have bottle of ice water to cool the hall sensor. Ï pushed it home, maybe 1/4 mile. This was all maybe 2hrs ago. It’s in front, Ï went out a little while ago; same deal, gas is flowing but no spark. The one thing Ï did notice is that red light in dash is on when Ï turn key on. I’ll let it sit for a few hrs and try again?!
kind of makes me miss my ZX10
Post by: Laitch on July 09, 2020, 08:08:35 PM
On a moto without ABS in the USA, the sole purpose of that light is to indicate the condition of the brake and tail light bulbs. To shut it off, you squeeze the front brake hand lever and push the rear brake pedal. If the brake light and tail light bulbs work, the light will turn off. If it doesn't turn off, then check those bulbs for function.
Post by: 85killzillaRS on July 09, 2020, 10:51:08 PM
ok, Ï downloaded the pdf troubleshooting guide earlier. Ï did go for a cruise today close to home 2nd & 3rd gear mostly. it ran real well for about 15 min, then died. Like if something just turned off. i’ll go through the pdf & clean the fuel injection and ignition units as mentioned by Laitch THANK YOU
Post by: The Mighty Gryphon on July 10, 2020, 09:43:50 AM
Bad brake switches will make that light come on as well.  Am dealing with an intermittent front brake switch right now.
Post by: 85killzillaRS on July 10, 2020, 12:32:21 PM
yesterday Ï did go for a quick cruise. Ï ended up pushing home. bike wouldn’t fire, even after sitting outside for a while. The red light Ï mentioned is easy enough to turn off. Ï haven’t ridden it in so long Ï forgot a quick brake application does away with that.
So this morning Ï tried to fire and it made a quick rumble, and now won’t start. That’s newish. Anyway, i’ll put it on lift today and clean the two units and go through through troubleshooting guide Ï downloaded yesterday. Ï wish myself good luck, Im gonna keep after this until something happens
Post by: alabrew on July 10, 2020, 12:54:29 PM
Go to the section of the Guide that tests the Air & Water sensors and MAF at the connector and see what the values are before a ride a and what they are when it shuts off.
Heat also brings to mind expansion and that some connection is opening when it gets hot, finding it is another matter.  :laughing4-giggles:
Post by: 85killzillaRS on July 11, 2020, 12:50:16 AM
it was 109F today, makes it easy to not go work in garage. Ï got everything off and it’s on lift. I went and got some spray electrical contact cleaner. The plan is to open anything Ï see under the tank and clean it up then reassemble. Ï parked it in  moms garage 15 yrs when it stopped pumping water. Ï ended up moving and beat up a Ducati and ZX10 for quite a while. Ï ended up buying a low mile 1985-K motor and threw it in recently. Pretty quick and easy actually. It’s just been sitting there. Several bolts on tail unit pulled out the other day, Ï superglued em back in and they work as they should now. It would make sense connections might have corroded or become dirty in some way. It’s 10:30PM here now and it finally dropped to 99F. I’ll get up early and work on it in AM.
to answer a previous question, yes radiator is full and catch can 1/2
Hopefully I’ll have it all back together and riding down the street by noon, maybe before triple digit temps
Post by: volador on July 11, 2020, 05:21:50 PM
99°F-109°F doesn't sound so bad. Its a dry heat right?
don't know your past history of this 85 K100 other then the engine swap
(http://www.motobrick.com/gallery/3/5332-110720174303-3276349.jpeg)
1) Do you have the 'vacuum or pressure switch' found mounted on the back of the throttle bodies
If present unplug and tape connector somewhere to harness
Plug port on throttle bodies #1
No longer needed
http://www.motobrick.com/index.php?topic=8494.0 (http://www.motobrick.com/index.php?topic=8494.0)
https://www.k100-forum.com/t15097-what-is-this (https://www.k100-forum.com/t15097-what-is-this)
2) Is the fuel pressure regulator connected properly?
check hoses to the Fuel Pressure Regulator found mounted behind the throttle bodies
    1-vacuum hose from throttle bodies to the bottom FPR
    2-middle hose from petrol fuel injection fuel rail
    3-top hose to petrol tank return line
(http://www.motobrick.com/gallery/3/5332-210620134257-3245189.jpeg)
3) need to ensure the tank venting is working properly not obstructed, discharge hoses are connected or "Air Accumulator Cup" is present & hose connected to it routed down the backside of right footpeg plate
possibly have the emissions check valve on the tank vent port/hose which is no longer needed and the engine block may or may not have the tubing/stud port circled below
Picture below you may remove/omit the tubing and gray check valve and cap off the tubing nipple/stub on the front of the block under the radiator shroud.
Or leave rubber tubing and gray check valve in place and disconnect from tank vent and plug rubber tubing with a bolt or suitable hardware.
This was BMW evapoative emission compliance of the time but later removed.
(http://www.motobrick.com/gallery/2/5332-010320105318-2761577.png)
(http://www.motobrick.com/gallery/2/5332-010320105320-2761708.jpeg)
Service Bulletin 2228  http://www.motobrick.com/index.php/topic,4984.0.html
During moto use its possible for petrol and fumes to be expelled from tank especially when full. Sloshing petrol can be sucked up into the tubing vent and expelled under tank pressure.
Exterior petrol tank bottom has 2 tubing nipple piped into the tank for petrol fume vent and the water/rain drain collected from around petrol gas cap.
K100 may or may not have the air accumulator cup 16132307467 installed to collect any expelled petrol or water from tank nipples with 1 rubber hose connected and routed down
to lower right footpeg plate.
Or instead 2 rubber hoses will be connected direct to the petrol tank tubing nipples if there is no air accumulator cup. Again hoses routed down to lower right footpeg plate.
The hole at 6:30 is the water drain. The notch in the petrol tank cap has to line up to that hole. The indicated tubing is the tank vent.
(http://www.motobrick.com/gallery/2/5332-140420012429-29971812.png)
1985 K100 petrol tank bottom
forward tubing/stub is tank vent
rear tubing/stub- petrol cap rain drain
(http://www.motobrick.com/gallery/2/5332-010320112521-2764652.jpeg)
AIR ACCUMULATOR
(http://www.motobrick.com/gallery/2/1601-081019085159.jpeg)
AIR ACCUMULATOR LOCATION
(http://www.motobrick.com/gallery/2/1601-081019085251.png)
Post by: 85killzillaRS on July 11, 2020, 08:20:40 PM
Ï don’t know the installed motor history, other than it has ran quite well several times. The problem was/is spark. I’ve pulled plugs and they look a little dark, what I’d expect from a motor that runs and then dies from lack of spark. I’ve got it pretty stripped down and have been cleaning anything in sight. Ï have been getting fuel the whole time, so I’m really looking to clean what Ï can. The frustrating thing is that is has ran recently and Ï haven’t noticed anything that tells me “a is not connected to b“ or feel something slowly degrade. Like running out of fuel or dirty air cleaner etc. I’m no master mechanic, but I’ve turned quite a few wrenches in my time. 107F now at 6:15P. Time for some dinner then I’ll get back on it for a while.
Post by: daveson on July 11, 2020, 08:31:07 PM
Did this problem only start after you opened the EFI? (under the seat) if so did it look good, including the dielectric grease? Maybe a problem somewhere there.
If not, going to earlier posts, the fan coming on before shutdown, and after one mile, is a strong sign of a false temperature signal. I think I have read that the ECU (or EFI?)  shuts down the engine when it detects overheating, to prevent damage, not sure though, can't seem to get this from the wiring diagram (maybe later models)
Post by: volador on July 11, 2020, 10:10:53 PM
A rich fuel situation can be caused by the above vacuum switch or a faulty temp sensor
If your lacking spark your ICU may be faulty when reaching a higher operating temp. Did you open up the black box under the tank?
Post by: 85killzillaRS on July 11, 2020, 11:03:53 PM
ok some really good points have been made. I’m not ready to replace any expensive units quite yet. The temp sensor and vacuum switch are good places to start tonight. Hopefully ECU, EFI are ok. Ï might start with temp sensor. Seems inexpensive and easy to change. I’m gonna search around for a bit and try to find old one from previous motor. It should at least get me past the 15 min Ï have been able to log in. If that’s the case I’ll definitely want to buy a new one. Maybe Ï can get another ride in. For now, almost everything is off, so clean, clean, clean. It’s really good to have so much input from people around the globe with slightly different bricks and different viewpoints. THANK YOU ALL
Ï’m not quite ready to mortar this brick down yet  boohoo
Post by: volador on July 11, 2020, 11:15:15 PM
Temp sensor on coolant 'T' into engine block test for resistance either sensor 'spade terminals' to sensor body measures ≅ 2.5KΩ @ 20°C
test pins 10 and 5 on the ECU connector plug under the seat for resistance measures ≅ 2.5KΩ @ 20°C
Flat blade screwdriver, 'lever forward' in the hole of the tool-tray to loosen ECU connector plug
check the wires from Pin 10 & 5 of the fuel injection control unit plug for open or shorts
Pin 10 - violet/green
Pin 5- brown
more about LE-Jetronic diagnosis http://www.motobrick.com/index.php/topic,13440.0.html (http://www.motobrick.com/index.php/topic,13440.0.html)
Post by: volador on July 11, 2020, 11:57:09 PM
(http://www.motobrick.com/gallery/3/5332-110720234843-32801193.jpeg)
(http://www.motobrick.com/gallery/3/5332-120720002653-3281543.jpeg)
4) Petrol Tank Check Valve on the 1985 1-Hit Wonder
The petrol tank return check valve may be blocked/jammed with debris & rust. The ball and spring may be omitted to prevent restriction of flow.
Modification of the check valve assembly
http://www.kforum-tech.com/how-to/Modification%20for%20early%20gas%20tank.htm (http://www.kforum-tech.com/how-to/Modification%20for%20early%20gas%20tank.htm)
Post by: Laitch on July 12, 2020, 09:00:42 AM
In Replies #2, #3 and #35, killzilla asserts the engine has no spark. He's arrived at his conclusion by looking at the spark plugs; however, judging from most of the replies being made in this thread, consensus seems to indicate he's out to lunch and should be looking at fuel supply.
I suggest he test each plug to verify its operation and help direct whether investigation should focus on fuel supply or spark to keep it from wandering all over the place.
Post by: 85killzillaRS on July 12, 2020, 09:10:02 AM
very good point, I’m gonna keep cleaning
then I’ll be out to breakfast for bit before Ï close this up & try again
Post by: 85killzillaRS on July 13, 2020, 08:31:18 PM
Ï saw a sig on here mentioning a sisyphean society,
that would be the nicest way to describe my project. It’s frustrating. Ï pulled all plugs. I’m getting fuel for sure. Last night Ï had it put back together, after removing & replacing tank Ï had it turning over and rumbling a bit. Ï stopped, pulled batt to recharge and went to bed. Today Ï got all ready to go and now it just turns over for a sec or two, then cuts out. Last night it would turn over for a while, just didn’t have enough fuel going through yet, after removing and replacing tank. Now it will turn a few sec, then stop. If Ï hold starter button, it’ll turn real quick, stop, then turn over again real quick, stop again, and just keep doing that. I’ve had several bikes before, all carbed and chain drive. So a few things are newish to me(ECU, EFI, shaft drive)
Ï thought for sure I’d be riding today. This intermittent starting thing is making me want to pull my hair out. Ï really do appreciate such varied input, maybe someone has experienced this before.   177381
Post by: 85killzillaRS on July 13, 2020, 08:42:23 PM
KOKO
I’m just keeping on, keeping on
persistence
patience-Ï still have a little
Post by: The Mighty Gryphon on July 13, 2020, 09:44:21 PM
I just noticed that you have an early model K100.  Those bikes have a known problem with the ignition coils.
Are your coils all black or do they have orange parts where the plug wires are connected?
Have you pulled the spark plugs and checked them for spark when they are out of the engine?  If you did, were all the plugs not sparking or just some of them?  Which ones don't spark?
In your next post just answer my questions.  I have lived in El Paso and know how hot it gets in the summer so you don't have to bother me with weather reports.
Just answer the questions.
Post by: The Mighty Gryphon on July 13, 2020, 10:01:49 PM
This is what the good coils look like:
* K100 coil.jpg (69.38 kB . 768x576 - viewed 821 times)
This is what the early coils with problems look like:
* Funky coil.jpg (30.47 kB . 768x576 - viewed 777 times)
Post by: 85killzillaRS on July 13, 2020, 11:20:23 PM
like daveson mentioned i’ve messed with all the quick and not so quick easy things,
as far as heat, it’s fried my hi/low switch and made some tails bolts pull. fixed that stuff.  so would heat affect coils like that, so they work, not work, then work again in morning. plus the temp firing like now. just pulled plugs, they all do fire. but they fire for a sec, stop then fire again for a sec; its not enough to get engine going. all plugs darkish, and Ï do have the orig black coils
haven’t lived here for a while and normally Ï rarely see over 100. been visiting, remodeling moms house, and trying to get the bumble beemer going. my summertime break before going back to school to be RN is slowly ending. I’d love to ride this thing back home to Santa Fe
Post by: The Mighty Gryphon on July 14, 2020, 07:51:00 AM
Dude, you gotta focus.  Answer my damn questions.
Post by: 85killzillaRS on July 14, 2020, 08:19:34 AM
black coils
now only an intermittent spark
all plugs do spark
not frequent enough rythym to get it going
Post by: Laitch on July 14, 2020, 10:22:09 AM
black coils . . .now only an intermittent spark
Your moto is stalled until you do something about this. New orange-top coils cost upwards of $200 per two-cylinder unit. Used orange-tops can be had for as little as $30 per two-cylinder unit right now on eBay. If you're certain the connections to the coils are providing enough current, then replacement is your only option.
Where are the coils from the other engine?
Post by: Laitch on July 14, 2020, 10:39:01 AM
. . . my radiator is full and catch can is half full . . .
That container is not a catch can and should not function like one. It's a coolant reservoir; the cooling system is designed to draw coolant from the reservoir into the radiator when necessary. If the hose outlet inside that reservoir is not fully immersed in coolant, you're defeating the system. Of course, that doesn't matter right now because your moto doesn't run; however, it will matter when your ignition system allows the engine to run long enough to get hot.
Post by: Paul_Waterloo on July 14, 2020, 11:42:15 AM
I am late to the party, but I would bring a timing light with me when I did a ride, and when it dies, put it on all four spark plug wires, one at a time, to determine if they are all dead.
Reading this thread it almost seems like you have a cold solder joint somewhere, like in the Motoronic unit, once it heats up, it open circuits and cuts the control circuit for the spark.
Like I said, late to the party, just offering some advice.
Post by: volador on July 14, 2020, 01:32:02 PM
^ kudos Paul did you read this thread? http://www.motobrick.com/index.php/topic,13767.msg123295.html#msg123295 (http://www.motobrick.com/index.php/topic,13767.msg123295.html#msg123295)   :thisplacewhack
Post by: 85killzillaRS on July 14, 2020, 02:14:07 PM
Paul, you may be late to the party
but as the saying goes
better late than never
thank you for tip
as said about cooling, Ï won’t need unless it actually runs  :popcorm
motor came without coils or alternator
Ï would have attempted to sell those separately also
thnx for now
Post by: 85killzillaRS on July 14, 2020, 02:19:09 PM
Ï do know the can actually gives and takes as in a lot of 4wheeled vehics,
was slightly easier to call it that though
RESERVOIR
Post by: volador on July 14, 2020, 06:36:53 PM
thank you for tip...
thnx for now
Potius Sero Quam Nunquam
How ironic you should say
We chip in for Paul's Aerostich shirt (https://www.aerostich.com/clothing/clothing/t-shirts/potius-sero-quam-nunquam.html)
Post by: Laitch on July 14, 2020, 08:26:06 PM
Irregular sparking is one of the symptoms of coil failure but it seems like in the heat of an El Paso summer, coil failure, cold solder joints and cold cuts could all be likely candidates.  :laughing4-giggles:
Post by: The Mighty Gryphon on July 15, 2020, 12:04:25 AM
In the time I've been hanging around these forums, I've seen a fair number of those early coils fail on other bikes.  There is a reason the design of the coils was changed in 1986 and the earlier version was discontinued.
Post by: 85killzillaRS on July 15, 2020, 02:08:31 AM
bought a pair of orange tops today, cheap, Thanks Laitch
i’ll be riding again real soon, for a few miles anyway   112350
Post by: Laitch on July 15, 2020, 11:19:45 AM
It's too early for a victory dance. Party on general principle and send out an early invitation to Paul_Waterloo.  :laughing4-giggles:
Post by: 85killzillaRS on August 01, 2020, 06:17:17 PM
Ï got some k11 igniting coil packs. same size and cover mounts. spade terminals are gone and theres a plug connector for the two hookups and the ground mounts to frame instead of back through wiring. that was easy enough to connect. needed new plug wires for new different coil terminals. Ï sent back, free returns, just paid return shipping. so Ï did get proper coils. bike runs good now. was just about to go for ride and Ï noticed the fuel rail has a small leak at front end and is spraying fuel. So Ï pulled it off and have started searching online for replacement. Apparently i’m not riding this weekend.
If anybody has a fuel rail, let me know!!!
Post by: Laitch on August 01, 2020, 06:32:39 PM
Clean the leak area with lacquer thinner. Sand it with emery cloth. Let it dry then apply JB WaterWeld over it according to instructions. Let the JB cure for a couple of days in the Texas heat then see how that works for you while you're waiting for a rail to turn up.
It'll be exciting!
Post by: The Mighty Gryphon on August 01, 2020, 06:40:18 PM
If it were mine, I'd remove the rail and take it to a welder to have it brazed.  Heck, silver solder may work as well.  JB Weld under pressure would make me a little nervous.
Post by: Laitch on August 01, 2020, 06:51:16 PM
That's the exciting part.  :laughing4-giggles:
JB claims WaterWeld resists the effects of gasoline and 900psi. I used it on a pinhole pressure line leak in the 5.0L F250HD and it has worked for two years. It's an elderly F250 though, so there's really nothing to lose.
Post by: Laitch on August 01, 2020, 06:57:44 PM
You can get a new one from Max for about $85, zilla.
Post by: 85killzillaRS on August 01, 2020, 08:25:11 PM
it’s already off, i’m going to cleanit really well then braze the ends. a good soldering sounds good too👌
