TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: K75RT Keith on June 29, 2020, 01:42:29 PM
I don稚 think the last person to pull the fairing bracket used the correct bolts on my 90 K75rt. Anyone have a description or photo that shows the correct bolt.
Thanks
Click on Diagram #46_0119 Fairing Bracket in section 46-Frame, Fairing, Cases at this site (https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=51743&rnd=07242017) for size, thread pitch and length of fasteners in the bracket parts list.
I知 trying to determine if the mounting bolts should have a pointed end
To which bolts in the diagram are you referring?
The bolts that hold the bracket to the neck of the frame. If you致e remove the fairing and bracket from an RT, you値l know which ones I知 asking about. I read on here somewhere that the bolts have an affect on the fluid block in the frame neck
M6x18 with tapered end. $4.38 a piece at Max BMW (https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=51739&rnd=07242017). See section 31, diagram 31_0387, part list number 03, BMW part number 46 51 2 311 423.
