TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Al on June 01, 2020, 12:14:20 AM
So I took the fuel tank off my bike to repair a leak at the side panel hanger.
Cleaned up between the hanger and the tank.
Cleaned it with acetone.
Plugged it with Permatex fuel tank epoxy sealant.
Put some fuel in the tank to ascertain that there was no leak.
All was sweetness and light until....
I tried to put the tank back on and it wouldn't seat properly. The tank pins at the back would not go down into their respective grommets on the frame. The tank just rocked from side to side.
I finally removed the tank and looked it over. I saw that one of the "cups" that engage the splined rubber cylinders that stick out perpendicular to the frame was bent up so it couldn't cup the rubber cylinder.
I gently straightened it with a vase grip with rubber sheet protecting the lip from the vise grip jaws.
Tried it again with the same result. The two pins on the back of the tank would not go into their grommets. The tank still rocked from side to side.
Called up my BMW buddy to have look. We slid a piece of cardboard between the bottom of the tank and the central frame top tube. With little bit of pressure on the tank it was apparent that the bottom of the tank is rubbing on the frame tube so that the cardboard strip was hard to slide out.
We could see the frame tube had some scuff marks from the inflation on the bottom of the tank. So we cut away a 1" wide strip of the insulation. Still rocks and pins will not seat in the grommets.
We removed the splined rubber cylinders and rolled some 1 1/8" wide rubber sheet around the steel pins projecting out of the frame. Wound them to about 3/4" diameter, thinking that this would allow the front of the tank to rise up and allow clearance betwixt the tank and frame tube thus allowing the rear to seat in the grommets. Retried the tank with the same result- still rocks and pins will not seat.
Nothing has been modified- it is all factory original.
I have had this tank off at least 6 times since I've owned it and never had a problem like this before.
I am trying to sell this bike and do not want to spend a whack of money and time to get it working right. It seems the only way to get this tank down the rear would be to cut a strip out of the bottom center of the tank and weld in a channel to allow it to clear the frame. NOT going to happen.
What the heck is going on here? Anyone come across this before?
Reads like you need more lube and try pushing fecking harder & get the other dude from your avatar help you push fecking harder too Al
Thanks but all that will do is crush the bottom of the tank.
Without actually trying to do what you are doing, I have found that the key is getting the correct engagement of the front "cups" onto the rubber bushings. If you are too high or (as it seems in this case) too low you won't be able to get the tank into position to lock in the rear grommets. So I'd try to lift the tank up a bit and ensure that it is sliding properly onto the front bushings.
Sounds kind of obvious but that was my own experience with removing / reinstalling the fuel tank.
If the tank hooks that engage the front bump stops are configured correctly and if the pins upon which the bump stops mount are correctly oriented—not bent down, forward or askew however slightly—then maybe the tank floor has deformed for an unknown reason. If this were my project, I'd measure from center-to-center of the tank mounting pins then compare that with the center-to-center measurement of the grommet mounting holes. If the tank pin measurement were greater, I might empty the tank, leave the cap open, invert the tank then put an ice pack on the floor to give metal memory a boost to contract the tank floor some.
It's an interesting challenge.
Past Prime and Laitch, thanks for your input.
I have gone over the tank very carefully. The cups engage the rubber cylinders just fine. But I can't get the rear pins within 3/16" of the rear grommets. I have removed the front rubber entirely just as a point of comparison and the rear still will not go in because the bottom of the tank hits the frame. The bottom of the tank is flat. It has never been damaged. It worked just fine when I took it off to fix the leak. It worked just fine the previous times I had removed it.
Laitch I might try your ice pack since nothing else presents itself as the problem. Maybe I should post a picture of the front, rear and bottom of the tank to see if some eagle eyed Brick Boy sees something I don't. "An interesting challenge" isn't what comes to my mind. A PIA comes closer to my thinking. After hemming and hawing for the last few years I finally decide to sell it and now I can't because some weird juju has happened to it. It will be worth nothing if the tank doesn't mount properly. The bike only has 78,000 miles on it. If my health and leg strength and bank account would allow I'd be keeping it but it has to go, sad as that makes me. I want it gone.
Reading this thread I'm a bit puzzled. Are the pins 3/16" above the center of the grommets, or are they 3/16" to the rear of the grommets?
On occasion I have had trouble with getting the pins in the grommets on my RT, the usual cause is a connector(one of those big ones for the combination switches) not settling down into that huge mass of wire around the frame backbone.
I've also had to reposition that big rubber wishbone shaped pad that runs from the headstock down the two side rails of the frame. That thing can prevent the tank moving forward as well as down. Truth be told, I have no idea what it's for other than to prevent airflow under the tank. As long as you're selling the bike, maybe you can remove it and just include it with the bike.
No matter what, when the tank is finally in place, there isn't any spare clearance under it.
Sorry, Gryph, the 3/16" is how far the pins are from touching the rubber grommets in the center of the hole. i.e above the grommet.
Yeah, I put some wire ties loosely around the the under seat connector bundles. I can see where the tank is scuffing the frame tube. I'll see if I can post some pix tonight.
Maybe I'll try and remove the wishbone and see if that makes any difference. I doubt it but I'll try. Got nothing to lose at this point. The tank goes into the general position no problem it is the pins at the back that cannot be lowered into the grommets 'cause the steenking frame hit the tank. Or is the steenking tank that hits the frame?
Placing lumps of plasticine under the tank may help reveal where the problem is.
This is just a thought but , did you pressurize the tank for any reason after the repair? If all you did was remove the tank, repair the leak and then try to reinstall it and face the problem you are describing I cannot think of anything beyond what everyone else has pointed out. If the tank was pressurized off the bike it could have deformed the bottom of the tank, it is fairly thin aluminum, just a thought. craig
Martin. I'm pretty sure where the tight spot is becuase I can see the rub marks on the frame but I was also thinking of plasticine to show up in a picture to post.
champ, It has never been pressurized. The bottom of the tank is flat and not bulged out at all that I can see. I didn't pressurize it since the leak was quite obvious. Thank you all for the ideas.
Place a sheet of newspaper over the frame under the tank. Push the tank down and try to pull the paper out. That may give you some idea of where the tank is being held up.
Already done did that, Gryph. I put a sheet of cardboard underneath the tank. It is definitely rubbing on the tank and is confirmed by the marks on the heat insulation and scuff marks on the frame tube. I will put some plasticine on the tube and take picture so I can show y'all.
I'll be out turning money into noise this morning with my 6.5 Swede so it won't happen until later.
Unless you capped the tank after the Permatex treatment then exposed the tank to heat, it seems unlikely that distortion of the tank's floor would occur in sunny Manitoba at this time of year. :laughing4-giggles: It is more likely that whatever shock to the tank bent one of the forward brackets also knocked both of them out of their previous positions and the remedy relies on trial-and-error when re-positioning them. A small change in their forward/rearward angle could have a significant difference in the pivot arc of the tank. Their fit over those grommets should be tight, if my moto is used as an example.
Still, the icing of the tank floor could be fun—dry ice especially. :laughing4-giggles:
Cardboard is too thick. Putting a piece of paper under the tank and pulling it out will tear the paper where the tank is being obstructed. This will help locate the problem which, apparently, you still have yet to identify.
Too alleviate this rigamarole
'how much do you want for the moto'?
I've been thinking $3000 Canadian Pesos.
Ive got US$1000 since this moto has got alignment issues
I don't think so. Tracks as straight as and arrow. No handling issues or weird tire wear.
This tank issue has never been a problem before now.
New York is along way from Manitoba.
I got a delivery dude who handle all the logistics. Let me know when you change your mind. Good luck with the fecking tank
Well at a $1700 discount I won't be changing my mind any time soon. I'll cut and weld a channel in the bottom of the tank for far cheaper than that.
Here are some pictures of the fuel tank and frame. I hope this works.
Fuel tank Front Cups:
Fuel Tank Underside:
Front Rubber Cylinders:
Frame Scuffing:
Hard to tell from the photos, but that big rubber wishbone doesn't look right. Have you made sure that the insulation isn't doubled up or folded over someplace?
It's pretty obvious to me that the tank is being held up somewhere and you haven't a clue where or what it is. The only thing I can suggest is putting a piece of paper a couple inches wide and 11 inches long between the tank and the frame and trying to pull it out while the tank is putting just a little downward pressure on it. You are using it as a feeler gauge to see where the tank is hitting whatever the F is holding it up. Once you know what the problem is you can address it.
Gryph, I DO know where it is hitting. On the frame just before the relay box. That is why I included the scuff marks on the frame picture. I HAVE put a strip of cardboard between the tank and frame and it catches there.
The tank rocks a bit side to side which also tells me it is contacting the frame and that's what allows it to rock sideways.
I have felt underneath the front and can feel the rubber cylinders go into the cups. I guess I can pull the Rubber wishbone out but I don't that is the problem.
The insulation appears to be bunched up a bit, this could cause problems. When I insulated my tank it took a couple of goes to get it right as I had no references as to how the insulation should be fitted. I ended up using blue fire proof foam sandwiched between reflective foil and 2" wide chrome tape from the local discount store where I couldn't fit the insulation.
OK, here are some pix I took of plastic on the frame tube under the tank. As can be readily seen the plasticine is crushed right down to the steel on the frame. Hence the rocking motion from side to side.
Martin there is no insulation in that area. That is the red stripe you can see on the under tank photo. That is where I cut the insulation out to see if it would drop down into place.
Plasticine on frame tube in uncrushed state:
PLASTICINE ON FRAME TUBE UNCRUSHED.JPG (177.49 kB . 660x442 - viewed 476 times)
Plasticine on tube with crush marks right down to the steel:
PLASTICINE ON FRAME TUBE IN CRUSHED STATE.JPG (203.68 kB . 660x442 - viewed 472 times)
Close up of crushed plasticine:
The time for action has arrived! Please submit the video to YouTube and post the link here.
Laitch, I'm sure that would be a good idea and even kind of fun but, to quote our Prime Minister, you are asking for more than I can give. I'm a latter-day Luddite. I thought I had hit a high water mark in technological excellence by managing to get some pictures posted OK. Maybe I can find a 10 year-old to help me with it.
Laitch, you are asking for more than I can give.
OK, just tell the tale around the campfire. How about just hooking the tank to the front mounts then sitting on it to induce its coupling into the rear grommets? Something's gotta give. 112350
Curiouser and curiouser said Alice!! Is there anybody that you can swap tanks with and/or do a comparison.
It is raining so I can't even tell a campfire story. The wood is too wet.
Martin, I don't know of another K75 in the area let alone an RT. We are not living at the end of the earth but you can see it from here.
Anyone have an old beat up corroded tank they want to donate to science?
What is a used tank worth?
You need to check the parts book but I believe that besides the early and late models some K100 tanks are the same as the K75RT. I also think a lot of the differences were to do with the fairing contours and the underside should be pretty much the same. A mate has swapped tanks between a K75 RT and a K75s with the fairings removed
Since I have a '94 K75RT, tomorrow afternoon I'll pull my tank up and take a look underneath it to see what it looks like.
I see from the MaxBMW fiche that there are two tanks for the K75RT and the change occurred in January of 1993, so my tank will have a different part number than the one in question. I don't know if they are the same as far as how they fit on the frame.
It's hard to tell from the photos, but the tabs that hold the bushings for the battery covers don't look the same as the ones on my tank. Since the frame for our bikes is the same part number, I suspect the underside of the tank will be the same for both bikes as well, and whatever difference there is will be somewhere else. Tomorrow will tell.
Thank ya. Thank ya very much.
Plasticine on frame tube in uncrushed state looks exactly like artificial worm I put on my hook on Friday's fishing trip
the Mighty G is on to something. As a 'S' aficionado there is a petrol tank revision sometime as was mentioned 1993. The bottom of the tank changed from a 'V' down the center (or similar) to a flat bottom newer version. The rubber bumper mounts also changed space distance reduced I believe compared to older version of petrol tank. I'm uncertain what change was made to the 'RT' as that tank is interchangeable with certain year K100's.
Mine is the flat bottom with ribs running across from side to side. As far as I know it is the original tank from 1990. The bike is low enough mileage that I doubt it was ever replaced. But who knows?
According to my understanding of what I've read in this thread, the tank on Al's moto has always fit his moto. It was secure; it didn't rock or rattle. He removed it to repair a leak and now it doesn't fit. Something Al did—or failed to do—to that tank or its frame fittings during that process is preventing it from being remounted. We already know one of the forward mounting brackets was inadvertently crushed. We don't know what other misstep hasn't been discovered but it's probably there somewhere.
The truth is out there. Laitch you summed it up accurately. This has me completely baffled. I made no changes to the tank other than repairing a small leak under the side cover tab. Nowhere near the frame tube. It should have been a simple remove and replace scenario.
When I tried to put the fairing pocket brackets on they were rubbing on the tank and would have scraped the paint off. Never an issue before.
So I tried to jockey things around a bit to get it to slide into home play with no joy.
I finally pulled the tank off again and then noticed the bent tab. No idea when that happened. I have certainly never put enough pressure on it to bend the tab. I never had a reason to since the tank always went into place easy peasy.
Perhaps today I'll pull the rubber pole off as per Gryph's idea. It would eliminate one variable. Although , I have never had it off since I've owned the bike but what the heck. Nothing ventured- nothing gained.
OK. I think I am making some progress. I think this bike has the wrong tank on it. Volador's comment made me look up a 1990 K75 tank. I found this picture and it would definitely solve the problem:
https://pickupmoto.com/gb/tanks/2099-fuel-tank-bmw-k100-k75.html
Notice that nice groove in the bottom that would allow it to straddle the frame tube.
Mine is flat in that area with ribs that run from side to side.
Why it never caused a problem before now, I have no idea. Maybe a PO bent that lip up and that made is sit properly or close to it. Maybe a K100 tank was put on it at some point in its previous life? I am at least the 3rd owner. I have have a Florida registration and it shows an SC code under the heading "Previous Registration" or something like that. I'm guessing SC might have been South Carolina? I bought it from a guy in Alberta who had imported it from the US.
That is why it is marked in MPH instead of Kilometres as a Canadian bike would have had. I like MPH better anyway. I'm old school.
Now the question: do I buy a new tank for a bike I don't intend to keep? What other option is there?
Guess you will be retro-fitting that red tank as you predicated
I think you are right Al you have a newer version petrol tank post 1993 or early 1994. To reiterate I'm coming from the K75 'S' perspective and that flat bottom tank is definitely newer version.
The sleek royal blue tank you have linked is for the pre-1993/94 K75 'S'. All 'S' tanks have the indentation or step on the lower sidewall.
A quick search on the Ebay shows a 1993 police version 'RT' with the 'groove' or 'frame channel' down the bottom center.
https://www.ebay.com/itm/1993-BMW-K75-rt-Police-Bike-Fuel-Gas-Petrol-Tank-K100-K75-Hard-to-Find/224032758339?hash=item3429649a43:g:ETQAAOSwFbFe1bW8 (https://www.ebay.com/itm/1993-BMW-K75-rt-Police-Bike-Fuel-Gas-Petrol-Tank-K100-K75-Hard-to-Find/224032758339?hash=item3429649a43:g:ETQAAOSwFbFe1bW8)
(https://i.ebayimg.com/images/g/SNMAAOSwu0Fe1bbH/s-l1600.jpg)
If you buy another petrol tank from a K100 make sure not a 1984-85. That version tank completely different & will not fit due to rear mounting tab.
(http://www.motobrick.com/gallery/2/5332-010320112521-2764652.jpeg)
Yeah there seem to a fair number of variants. Ideally I'd like to have them side beside but that is unlikely. The police tank is bit spendy in Canuck Bucks. Especially when you add in shipping. Again if I was keeping the bike it might be different. I have a US shipping address since I only live 30 miles from the border and that saves me a lot of money on shipping but the border is closed because of covid.
I have put an add on Kijiji but who knows when that will hit pay dirt? Upside is I can also sell my tank.
"The sleek royal blue tank you have linked is for the pre-1993/94 K75 'S'. All 'S' tanks have the indentation or step on the lower sidewall."
Right. My buddy noticed right away that it din't have the side panel mounting tabs. Just because you can get on doesn't mean it fits.
Okay, I went out and looked at the tanks on my three Bricks. A '91 K100RS 4V, '88 K100RS, and the '94 K75RT.
The tanks on the the K100's are the same and have the "tunnel" for the frame tube. The RT has the flat bottom like Al's RT. The tank on the RT fits, but does need a fair bit of force to push the pins down into the bushings far enough to get the clips on them.
I then went to the parts fiches at MaxBMW. Turns out the frame has the same part number for all K75 models so as far as the top tube, either version of the K75 tank should work.
As mentioned, there are two different tanks that fit the K75RT. The one with the flat bottom Like Al and I have appears to be p/n 1 611 2 307 468. It is also used on the K1, K11LT, and the K11RS.
The earlier K75RT tank with the tunnel looks to be p/n 1 611 1 455 101. That tank is also fits the K1, K1100RS 4V, K11LT, K100, K100RT, K100LT, K100RS 2V.
It certainly looks like there is a lot of interchangeability between tanks and bikes. In looking at my bikes, and with the information from the parts fiches I can't find any reason why Al's tank hits the frame tube and won't go into the bushings. I'm stumped.
Gryph, in my searching i came across another tank- part # 161 100 26098 Can't guarantee it is an RT tank but I'm pretty sure it is. I stand to be corrected.
I can't even get the rear pins to enter into the grommets with a huge amount of force. To push them in far enough to get the clips on the tank would be distorted- and that's with the strip of insulation removed.
Anyone have a tunelled tank for sale?
I'm stumped to understand how its rear pins were able to be mounted before all this happened. The frame's number in Max's fiche seems to be the same for all those RT years. The front of the tank would have needed to be elevated enough for the rear pins to fit through the rear grommets. If the front of the tank wasn't secure, there would likely have been rattling. I would be obsessed about getting it to fit again but Al seems to have transcended that obsession :laughing4-giggles: and thankfully for both of us, I'm too far away to pop in for a look-see.
Laitch, I have pondered many an hour about getting it to fit. I have had other gearheads look at it. I am at my wits end trying to understand how it fit up until now. The bottom line is that at this point it will not go down. Raising the front of the tank with the rubber cylinders removed does not allow it to into place at the rear. The frame is hitting at the back of the tank no matter how high I raise the front.
I really want the tank to fit as it but I see no way to make that happen apart from big hammers and kilotons of force.
In order to put enough pressure on the tank to make it seat properly will essentially make a crude tunnel in the tank anyway and likely distort the tank in some way. Why BMW made this change is beyond my ken. I can assure you that the tunnel tanks would NOT have this problem. So much for da fine Churman Enchineerink. Perhaps it was a cost saving measure by the bean counters to reduce the number of parts being made. But still- how they got it to work at all mystifies me.
Gryph, did you try a piece of paper under your tank? I am wondering how much clearance your bikes have?
I'm not doubting that. What is odd is that the tank has stayed put since 2017 but won't stay put no more and you can't make it. :laughing4-giggles:
Am I hearing, "Na, na, na, na, na" from you? :laughing1:
Oh, Laitch, I can make it stay. It won't be pretty but I can make it stay. I'm almost at that point now.
Maybe I'll go full redneck and just bungee strap a 5 gallon gas can to it.
There's a market for customization like that. Don't list it for less that 4K Canadian.
Good. I was also thinking of putting a spoiler wing on the back. A 2x6 would be cheap enough and easy to form with a wood rasp. Also attachable with a a bungee or duct tape.
My retired carpenter could form that spoiler up for a few cases of Moosehead
If searching for a new used tank I recently purchased parts from the Old Motorcycle Shop in Calgary AB
Thanks Volador. I have seen them around for a few years now but have never dealt with them. I have just been thinking I should give them call.
I guess the time has come.
It still seems weird that after all these years the problem rears its head now with no way of overcoming it. But the system is pretty simple.
:thisplacewhack
