TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: 390beretta on November 25, 2011, 08:58:44 AM
Title: Oil Filters for Motobricks
Post by: 390beretta on November 25, 2011, 08:58:44 AM
The gentleman from whom I bought my '88 K75 gave me three Bosch oil filters and three spark plugs.  A trusted mechanic and a knowledgeable friend told me to use OEM filters only.  Willing to go the cost for OEM, but would like opinions whether the OEM is really better.  Thanks
Title: Re: Bosch Oil Filter
Post by: kenray on November 25, 2011, 09:31:41 AM
Hello, I am no expert but I use the Bosch filters in my 89 K100rs with no problems. The ones I buy come with a stick on label on the filter. I make sure to peel off the sticky label and wipe any residue off with WD40 before installing. I'm sure you will get other opinions from our fellow Brick riders. Kenray in Katy TX.
Post by: DRxBMW on November 25, 2011, 05:36:10 PM
AC Delco PF 53 oil filter, over 120 K,enough said.
NAPA Gold is another brand I've used on customer's bricks.
FWIW, you can go with 2 oil drains per filter.
"ride hard ____ life's short"
Post by: Chaos on November 25, 2011, 07:40:10 PM
Bosch is a perfectly fine filter.  I've been using Delco PF53 for the last 10 years or so, before that I used Fram until they started putting the grippy stuff on em.  180k so far.
Post by: Rick G on November 25, 2011, 08:27:18 PM
The grippy junk on the fram is the only problem I have come across with non genuine filters. Some filters have a slightly lower relief valve setting but not anywhere low enough to be a problem at all.
Post by: w. h. hoon on November 26, 2011, 12:55:15 PM
Have you already checked the price of oem. filter? WOW!!!!
Napa gold is the same filter my toyota pickup uses 4.95
Napa platinum is 11.95 but rated for synthetic oil
still less than halfprice!!!
Post by: 390beretta on November 27, 2011, 05:44:11 PM
Yep, the BMW filters are spendy.  But as my very trusted mechanic said:  " I know the BMW ones work right.  You don't have to change them but every other oil change.  How many miles do you put on in a year?.....so, you're spending $15-20 more a year.  Do the right thing ;D   Well, it's hard to argue with that logic.  This guy, Motoghost.com, is one of the most knowledgeable BMW mechanics I have ever run across.  I think I'll take his advise.  I have 4 Bosch oil filters that I'll sell "cheap" if any of my friends would like them.  (you pay shipping).  Thanks
Post by: CRASH on November 27, 2011, 07:03:01 PM
I change my oil 5 to 7 times a year - 20k to 25k miles annually.  Last change there were no sparklies or metal particles on the magnetic drain plug (63k miles).  I have used nothing but Bosch on this bike and on other K-Bike forums where mechanics get talked about, Bosch is about 75% of all users, most of the others use non BMW filters (these are people that do their own work - shade tree, profession, semi profession, and some really annoying engineering geeks).  The OEMs are really no better than any other quality filter.  I also know that most 3rd party BMW shops tend to carry Bosch, Mann (OEM manufacturer) and Mahle (another BMW OEM manufacture) - Bosch being more popular probably due to accessibility.
I use Wix or Baldwin on most of my equipment (they make the Napa Gold as for example already mentioned as a good filter), usually Purolater (who also make Bosch) on my cars. I have used Bosch on motorcycles for as long as I can remember including an 84 Venture Royal that went over 185k miles ... and then more after I sold it. The only filters I would avoid like the plague .. MANN and that is only because there are so many counterfeit ones out there - from a reputable dealer I would buy one but not for a silly price. The other is FRAM just because they have been crap for so long and still are.
But all of this is just some guy on the internet telling you things that could be true or not.  I do a lot of research on things (and a million miles on bikes and 40 years of wrenching) and this is what I have learned.  Don't take someones word for it, a few minutes with a beer and the computer and you can read up on it yourself. Some good information to learn about oil filters with a little science to back it up:
http://minimopar.knizefamily.net/oilfilters/index.html (http://minimopar.knizefamily.net/oilfilters/index.html)
http://minimopar.knizefamily.net/oilfilters/opinions.html (http://minimopar.knizefamily.net/oilfilters/opinions.html)
http://minimopar.knizefamily.net/oilfilters/german.html (http://minimopar.knizefamily.net/oilfilters/german.html)
The links at the top of this page take you to several sections.  When doing your research remember Purolator makes the Bosch filter.
http://filtrationcomparisons.weebly.com/index.html (http://filtrationcomparisons.weebly.com/index.html)
or right to the meat - http://filtrationcomparisons.weebly.com/conclusions.html (http://filtrationcomparisons.weebly.com/conclusions.html)
Post by: orforester on November 27, 2011, 07:15:12 PM
My local NAPA store was having a filter sale this weekend.  Fuel Filters $2.22 for the 3032, got two and two oil filters for $2.52 each.  About 60% off, NAPA Gold.  After you take the sticker off them, they seem to work just fine.  My two cents on oil filters and oil changes, is do them often.  I used to work in Alaska many years ago.  Ford engines would last 5000 mile, yes 5000 miles, but those that had the oil changes every 1000 miles lasted 15000.  It was very dusty and hard on engines as you could tell.  Us that changed the oil, did ours at 500 miles and never had a blown engine, but the oil was dark.
Post by: 390beretta on November 27, 2011, 08:21:12 PM
Thanks you all for your input.  Greatly appreciated!
Post by: Phil Marvin on November 28, 2011, 02:03:19 PM
Hi, 390beretta,
    The Mahle OC-91 filter IS the OEM filter without the BMW logo (or price) for the Classic K.  A fellow advertises them in the BMWMOA Flea Market as well as in the BMW Owners News in the flea market section.  His price is $10 or 5 for $40, plus shipping.  I bought 10 at one time and got them for $75.  Adding shipping, they cost me just over $8.50 each in my little(?) hot hands.  Contact him at mrmrsp191 at AOL dot com.
Post by: frankenduck on November 28, 2011, 02:21:12 PM
magnetic drain plug
Is that aftermarket?  The OEM ones aren't magnetic.
Motobricks are so badass bulletproof you could probably run them without an oil filter. (Not that I'd recommend that though.)
Since this is a fairly common topic of discussion I'm going to move this thread to The Lieberry and merge in any future oil filter threads that are started.
Post by: CRASH on November 29, 2011, 01:36:59 AM
magnetic drain plug
Looks like you asked and then answered your own question in the same breath.
Post by: w. h. hoon on November 29, 2011, 06:57:28 AM
Now this is just my opinion, I believe old oil filters belong with the old oil. personally I don't care how much it costs I'm not going to run new oil and an old filter. But maybe that's just me?
Title: Re: Oil Filters for Motobricks
Post by: wmax351 on November 29, 2011, 12:38:45 PM
I usually hear that you can keep the oil, swap the filter. Modern synthetic oil will outlast the filter several times over.
To be safe, I just change both at the same time. They aren't that expensive.
Post by: Ocelot on November 29, 2011, 03:18:07 PM
Has anyone here tried the stainless steel mesh re-usable oil filters?
Post by: wmax351 on November 29, 2011, 04:07:05 PM
Nope. Don't really see why. Messy, and I don't trust it as much. Bosch 3330's are under 4 bucks from Rockauto. For 4 bucks a year, I'll make an oil change as clean as possible.
Post by: DRxBMW on November 29, 2011, 05:39:17 PM
I've seen the filter that uses a roll of toilet paper before.
POS literally _______________ LOL.
Post by: Chaos on November 29, 2011, 08:36:30 PM
I would avoid them like the plague.  They allow a much larger particle to pass.  And as for not changing the filter, you're leaving a cup of old oil in the sump.  Why no just extend your change interval some and change both.  Or use a synthetic with longer life.
Post by: rbm on November 29, 2011, 08:54:08 PM
The topic of oil always elicits a great deal of opinion.  I'll give mine.
I agree that reusable filters are not a viable option for the K-bikes.  The mesh is too coarse and allows a larger particle through than paper, as stated earlier.  Also, I've read they are difficult to clean properly although I can't verify that claim.
I use HiFlo HF163 filters in my bike  They were inexpensive, have bare metal exteriors (so no risk of flaking paint in the oil) and recommended by several other riders.  I bought in bulk and got a decent discounted price at the local bike shop.  I always change oil and filter together at the end of the season before winter storage.  I use Mobil-1 synth exclusively, so, I might be throwing out perfectly good oil after one season but I'd rather be safe than sorry.
So, I guess the next topic of discussion should be oxygenated gas and how good is that for our machines.  :)
Post by: wmax351 on November 30, 2011, 12:27:34 AM
I have used the HF163's. They seem alright.
I may switch over to the bosch, in order to know where they come from better.
Post by: Ocelot on November 30, 2011, 07:28:05 AM
Yabbut... Has anyone used them?
BTW, my Crazy Uncle Karl bought a pair of Studebaker Lark station wagons with the toilet paper filters on them. Each had about a quarter million miles on the clock when it died (he was a long distance salesman). Which was a lotta miles back when a typical car might go 40 or 50k. I had a heavy flute-sided Dodge van I drove across country had one. 240K on that slant six when it died.
Post by: voodooskin on February 04, 2012, 01:21:44 AM
The beauty of the toilet paper filters is that if you're ever caught out with a biological emergency and a simple toolkit, you are good to go (albeit: oily)  :lol:
I took my K in for tires to the local dealer and (knowing it was due) offhand asked them to change the oil while they were at it.  Figured what, $50 tops but worth it so I would not get my hands greasy this time.  But I did not ask the price in advance.
OMG: north of $100 bones for an oil change on a bike.  Really.  Over $100.
1) doh
2) doin my own oil changes evermore.
So figure if you can do oil + filter at < $50 you're below 1/2 price.
Post by: Ocelot on February 04, 2012, 07:23:34 AM
Shit... a hunnert clams gets two cases of Castrol... nuff for ten changes
Post by: DRxBMW on February 04, 2012, 08:09:46 AM
I run Mobil 1 full syn 15/50 year around, 8K drain intervals.
(https://www.dealsrusdistribution.com/store/images/mobil-1-15w-50-motorsport-5-litres-341-p.gif)
Advantage of using synthetic in a bricK is, avoidance of the dreaded sprag syndrome. Disadvantage, you may experience some misting if you wring the piss out of the ole girl. Especially in a higher mileage odometer scenario.
AC Delco PF 53 oil filter is DRxBMW's choice. Cheap, $4.00, works wunderbar, over 140K of mileage factor using them, NO issues ever.
Peel off the small paper label first, clean the adhesive off with goo off or something similar and your good to go.
FWIW, the filter is painted blue but so what.
(http://parts.olathetoyota.com/filter-compare/tacoma-ac-delco-oil-filter-hero.jpg)
Just about every filter is made outside the USA anymore, even the BMW branded ones.
Good read on the different types of filtration media below if you have an interest.
http://parts.olathetoyota.com/tacoma-oil-filter-comparison.html (http://parts.olathetoyota.com/tacoma-oil-filter-comparison.html)
Post by: Skeezer on March 20, 2012, 11:09:55 PM
 :bmwsmile So I went to My local Automotive Parts store who have served me well for many years. I Gave them the Delco Part number mention in this post. They Crossed it over to another brand "Defence" .. $4.87 Cdn and I went on my way. It fit and so I thought all was good. I went on a couple short  rides around town, everything looked good. Then I tool the K out for a Good rip, 150 km of  Hwy riding. When I was pulling into the Garage the oil light was flickering and wouldn't go out when reved up. I thought OH CRAP. But the after shutting off the bike and then restarting it the light was out.
So the Filter was removed and I cut it apart fearing some of the paper filter had blown out. The filer looked in good condition, nothing out of place. But I was still nervous, So back to the Auto Parts Store. this time I didn't get the Kid behind the counter I talked to a person I knew and told them my story. They suggested I try a Wix filter and showed me a cut away of the WIX and 3 other known brands. The WIX  looked like it used better components and the WIX book actually listed a Filter for my Bike. The cost is about the same as the BMW filter so for now I'll run the WIX. I will post after I have installed and run the Bike with the WIX . :hmm:
Post by: DRxBMW on March 21, 2012, 07:29:24 AM
:bmwsmile
dunno, I've ran the Delco PF 53 blue filter for years with absolutely ZERO issues. Possible the Defance cross was a fluke,shit happens.
Fast Edde swears by Toyota filters. Cheap, readily available.  Napa "Gold series" is another.
Website link below has tons of good info on filters. The cutaway pics are very interesting. Ha,Fram seems to be the worst offender.
Post by: Skeezer on March 21, 2012, 09:47:04 PM
Part store confirmed they gave me the wrong filter. the size and thread were  a fluke. lucky no damage was done. The WIX filter is on for now . I have a good sourse for a replacement filter now.
Post by: DRxBMW on March 22, 2012, 07:46:18 AM
Part store confirmed they gave me the wrong filter. the size and thread were  a fluke. lucky no damage was done. The WIX filter is on for now . I have a good source for a replacement filter now.
bummer, at least the engine suffered NO damage.
Curiosity ? Why did you NOT pick up on the wrong threading from the get go ?  One should always hand thread a new filter,if it does NOT start correctly something is amiss.
Post by: Skeezer on March 23, 2012, 11:47:08 PM
Sorry, What I ment was . " it was Fluke the Thread and the size of the filter worked" but the internals of the Filter are different.
