TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: kevinu on May 20, 2020, 10:12:51 AM
Title: Speedometer needle problem
Post by: kevinu on May 20, 2020, 10:12:51 AM
A month or so ago, I repaired the odometer gears and wasn't sure how to get the speedometer needle reattached after the repair.  After two tries, I had it on and sitting at 0 mph when it should be.
Yesterday, I did a very hot (<100 F) ride that included a section of bumpy dirt road, and now the needle is at 140 mph when sitting still.
I know it sits on a very delicate pin, and care must be taken to not damage this pin.  I'm guessing I never really had it set on the pin correctly in the first place and the vibrations knocked it loose.  I need to take the needle off the pin and try to get it reset again at 0.  Should I add some type of glue before put it back on the pin?
Or maybe the problem is the pin itself?
Title: Re: Speedometer needle problem
Post by: Laitch on May 20, 2020, 10:21:30 AM
Pushing it fully onto the shaft should secure it; it's a press fit. Maybe the shaft and its connection are damaged. I'd expect a loose needle to fall off but there's no telling until you get in there and take a look.
Post by: kevinu on May 20, 2020, 10:36:02 AM
Now I have to find the time to take it apart and try the repair...
Post by: Laitch on May 20, 2020, 10:45:48 AM
These units aren't examples of Motometer's finest hour and can be exasperating, especially the older ones without the benefit of Gore-tex ventilation in the back panel. On the other hand, they can offer practice in equanimity.
Post by: Chaos on May 20, 2020, 01:01:02 PM
Smoking on startup and a flaky speedo are actually precision designs to give the bikes character.  Otherwise they would be perfect and as boring as a refrigerator.
