TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: suzuki12 on May 09, 2020, 10:48:29 AM
Title: Speedometer intermittent
Post by: suzuki12 on May 09, 2020, 10:48:29 AM
I have an 1986 K75. The speedometer on initial riding goes up to 60 kph and when ridden faster drops to 0. If I slow down a bit speedometer works again up to 65 or so. With increased riding it eventually will increase to 100 kph but never higher. It will always just drop to 0 if I go faster.
I’ve disassembled the gauge to ensure good connections and also checked and cleaned the sensor at the rear wheel. I’ve not found any other similar issues discussed on this forum.
Any thoughts?
Title: Re: Speedometer intermittent
Post by: Laitch on May 09, 2020, 11:22:10 AM
Trace the wire from the sensor to its plug located beneath the right side battery cover, clean the plug's connections, reconnect it and maybe that will help.
Post by: suzuki12 on May 09, 2020, 01:57:44 PM
I did clean and reconnect the plug on the right side with no improvement.
Thx
Post by: Laitch on May 09, 2020, 02:00:04 PM
 177381
Post by: The Mighty Gryphon on May 09, 2020, 02:49:59 PM
Do the odometer and tripmeter measure distance accurately?
The instruments work by taking the pulses from the rear wheel and splitting them two ways.  One path goes to a step motor that drives the odometer, while the other path goes to some circuitry that takes the pulses and turn them into a voltage that swings the needle on the speedometer.
If the odometer works properly, the problem is in the circuitry for the speedometer located in the cluster.  If such is the case, I would probably look for a speedometer module or complete cluster.  As far as I know, there is no information available to allow repair of the speed conditioning circuit.
Post by: Chaos on May 09, 2020, 03:39:20 PM
Did you use a good contact cleaner like Deoxit when you had the cluster apart?  Your symptoms are classic for intermittent conductivity.  I bent some of the pins to get better contact.
Post by: suzuki12 on May 09, 2020, 04:11:52 PM
The odometer only works when the speedometer is working. Nothing when the speedometer is at 0. I have had the unit apart at least 3 times to rebend the pins to improve contact. I used sandpaper on them as well. I didn't use Deoxit but the contacts certainly look to be clean with no corrosion.
Post by: suzuki12 on May 09, 2020, 04:16:37 PM
It's quite puzzling that it is initially only going to 60 and slowly increases to 100 but not higher
Post by: Laitch on May 09, 2020, 04:18:08 PM
If all else fails, this outfit (http://www.speedometer.com/page/services.html) does good work.
Post by: daveson on May 09, 2020, 06:27:36 PM
I've had that problem and fixed it with cleaning and a slight twist to the pins, as you have. Before I did the twist, I pushed the pins in and out multiple times to clean the pins sockets as well. If I ever open it again I'll definitely be using contact cleaner as well.
Post by: Chaos on May 09, 2020, 08:41:27 PM
Probably not the issue buy something to check, the speedo sensor ring (#20) in the final drive has been know to come loose, causing intermittent readings.
Post by: daveson on May 10, 2020, 12:06:13 AM
Those symptoms sound just like what I had, dunno if the odo was a go tho.
Post by: rbm on May 10, 2020, 02:13:56 PM
+1
The symptoms point to bad connectivity.  Any corrosion on the connections between the rear wheel sensor and the speed conditioning board inside the OEM gauge cluster will cause signal degradation.  The signal coming from the rear wheel is only 1 Vp-p, very small indeed.  It will manifest itself as intermittent speedo behaviour because the corrosion will cause various levels of signal loss depending on frequency.
I'd suggest an overhaul of the speedo, concentrating on cleaning the connections between the interface cards and the flexible wiring circuitry.  Use a good contact cleaner like Deoxit on both the pins and the receptacles on the flexible wiring.
Post by: suzuki12 on May 10, 2020, 07:36:25 PM
Thanks for the input. I will try the Deoxit.
Post by: suzuki12 on May 11, 2020, 04:26:05 PM
Another update. I dismantled the speedometer again and used Deoxit on all connections. Twisted all probes to ensure a good connection. I took the sensor from the final drive and cleaned again and also the connection by the battery on the right side. Everything sprayed with Deoxit.
Speedometer initially goes to 60 kph and if power is very slowly increased speedometer will increase to about 70. If power is quickly increased speedometer immediately drops to 0.
I'm stumped on this one.
Post by: rbm on May 11, 2020, 05:21:54 PM
Might be a defective conditioning card or speedometer driver card then. The Mighty Gryphon outlined the problem in an earlier post.
Post by: The Mighty Gryphon on May 11, 2020, 05:30:17 PM
You don't make it clear as to what happens if you accelerate very slowly.  If you do, will the needle move above 60-70kmh?  How far does it go in that situation?  Does it always stop at 60-70kph and drop to 0 or does it sometimes go higher?
Post by: daveson on May 11, 2020, 05:48:04 PM
Also, did you allow the deoxit to dry before plugging it back together? If not, it might come good in a few days when it dries out. And maybe see that the black/blue wire in on the coil Properly, and give it a clean. (Edit: doh, that wires for revs not speed,  I keep mixing that up)
Post by: suzuki12 on May 11, 2020, 06:01:27 PM
Deoxit was allowed to dry prior to reassembly.
Speedometer initially works correctly to 60 kph. Very slow increase it works correctly to 70. Quick increase it immediately drops to 0. A slight reduction in speed and it starts working again. I’m able to very slowly increase max speed to 100 but it takes about 30 minutes of riding. It won’t go above that speed.
The sender unit in the final drive appears to be securely fastened.
Thanks for all your input.
Post by: The Mighty Gryphon on May 11, 2020, 08:03:44 PM
As I mentioned earlier, the speedometer works by converting pulses into current to magnetize the coils in the meter movement, deflecting the needle.  These same pulses control the motor that turns the numbered wheels in the odometer and tripmeter.
Your description of the problem makes it sound pretty consistent.  That is not the way loose connections work, if that was the problem, the speedometer would be going to zero at more random speeds, and would actually work properly from time to time.
I asked if the odometer and tripmeter worked when the speedometer went to 0kph.  I think you said they stopped working at the same time as the speedometer.  If that is the case, the problem can be in one of two places; either the sensor at the final drive or the signal amplifier in the instrument cluster.  It's easier to imagine a failure in these parts creating a more consistent problem.
I would consider trying a different speed sensor first since it is the source of the pulses necessary to make things work.  It's also the least expensive and easiest part to replace.
If that doesn't get things working, the problem is probably in the signal conditioning electronics in the cluster.  Unfortunately, I don't think there is any information available on these circuits that would make it possible to troubleshoot them.  The only option would be to replace either the cluster of just the speedometer mechanism.  Fortunately, there are a fair number of used units available in places like eBay.
Post by: rbm on May 11, 2020, 10:52:06 PM
The circuit diagram for the speedometer/odometer circuitry is here: https://www.motobrick.com/index.php?topic=10566.0
Look for the section entitled Speedometer/odometer and click on the link provided.
The boards use standard off the shelf electronic parts so looking through the manufacturer's datasheets, will tell you how the circuit works.
Post by: bocutter Ed on May 12, 2020, 09:35:48 AM
Any thoughts?
I think you could be a tad more more specific with your location ...
I have a spare motometer on the shelf.
Post by: The Mighty Gryphon on May 12, 2020, 09:51:44 AM
If you can read Italian this link takes you to what looks like an explanation of how the K100 instrument cluster operates.
http://www.k100.biz/NT/NT_tachimetro.pdf
Here's info on the main IC that runs everything:
http://www.k100.biz/Electr/Strumenti/uaf2115_1ds.pdf
Post by: suzuki12 on May 15, 2020, 09:05:48 AM
Another update. My friend is an electrical engineer who is now helping me. He put his oscilloscope on the sender unit and the connection by the battery and found normal signals. He then hooked it up on the speedometer where the 3 probes are and found the intermittent signal above 60 kph. He then started probing the motometer with a multimeter. I didn’t even know anything about the motometer prior to this.
He is now almost certain a capacitor is the problem. He’s taken the unit home to solder in a new one.
Post by: Laitch on May 15, 2020, 09:09:09 AM
Thanks for the update.
Post by: The Mighty Gryphon on May 15, 2020, 09:48:10 AM
Great news!  Thanks for the update.
Post by: daveson on May 15, 2020, 11:01:00 AM
 Good one. A photo would be good if you could.
Post by: TommyT on May 15, 2020, 01:58:15 PM
Wow what a friend, I want one like him. I got three flaky flasher units I love to have him fix (for free), ha!
Post by: suzuki12 on May 16, 2020, 06:34:39 PM
The speedometer is repaired and working perfectly. My friend replaced a capacitor which can be seen on the motometer board near the center. It's green in colour and has value of 4.7uF 6.3V.  Sorry but I forgot to take a photo but a full write up is coming what was done and how he diagnosed the problem.
http://www.motobrick.com/index.php?topic=8017.0
If you look at the 4th photo in the string you will see the motometer. You can see the green capacitor near the center which was replaced.
Post by: suzuki12 on May 17, 2020, 09:04:57 AM
Failure description:  As the speed of the rear wheel reached 80km/h the speedometer would suddenly display 0 km/h.
Probing the signal from the rear hub sensor with an oscilloscope showed a signal that increased in frequency as the speed of the rear wheel increased.  There was no sudden dropout at 80km/h (~120Hz).  We did note that the signal amplitude was only around 300mV p-p.
Tracing the signal up to the speedometer head, we noted that the sensor fed into the "Moto Meter" board, via the BE pin.  Measuring at this location confirmed the same 300mVp-p signals, which would increase in frequency as the speed of the wheel increased.  No cut outs at this point.
Probing the Output  of the Moto Meter board (BA pin), saw a very large scale clean signal (at least 5V p-p, didn't actually note the exact voltage).  However, at 80km/h (~120Hz) this signal started to stutter and then completely quit.  It would return when the speed decreased below 80km/h.
The Moto Meter board utilizes a dual op-amp LM2904N chip.  After a bit of probing and measurement, view the approximate schematic in  the next post.
The first stage is configured as a comparator.  Every time the BE input signal swings  greater than 0V, the first op amp outputs a high amplitude signal.  Note however, that the input signal is first passed through a Low Pass Filter (LPF) before reaching the + input of the op amp.  (The LPF is the series resistor and capacitor to ground.)  A capacitor acts as a short circuit to ground as the frequency increases. The suspicion here is that as the frequency increases, the LPF is filtering too much of our already small signal from the rear hub away, and at some point, the comparator no longer sees it.  The 5k / 4.7uF combination makes for a 6Hz cut-off frequency, which seems very low considering that the hub sensor is sending a frequency around 150Hz at 100km/h.
Suspecting that perhaps the hub sensor normally outputs more than 300mVp-p, or perhaps the 4.7uF cap is starting to go bad.  So, removed the cap and replaced it with a 0.5uF ceramic capacitor (what we had laying around). See photo in next post.
Bench tested with a home made signal generator (using a ESP32 micropython board, that's a whole other story!) injected 300mVp-p on the bench at various frequencies.  Recreated the original failure with the original cap (LPF output dropped to 16mVp-p at 300Hz).  Confirmed that with the new capacitor value the LPF output only dropped to 45mVp-p at 300Hz.  More importantly, the output of the Moto Board on the BA pin remained strong and active the entire time.  300Hz is around 200km/h, so this seemed like more than enough operation range as a fix.
Gave the circuit  and speedometer back to Suzuki12.  And he confirmed that it fixed the problem!  So, this was either a bad cap, or a beginning-to-fail rear hub sensor that we are squeezing a little more life out of with the lower capacitor value
Post by: suzuki12 on May 17, 2020, 09:27:51 AM
