TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: aussiebeemer on May 03, 2020, 03:08:06 AM
Title: Removing Combo Pump Shaft
Post by: aussiebeemer on May 03, 2020, 03:08:06 AM
I am rebuilding my K75 Oil/ water pump and need to replace the shaft. What is the best way to remove the shaft from the gear? I have tried WD40 and a firm hammer hit while supporting the gear with wood on a solid surface. Appreciate suggestions.
Title: Re: Removing Combo Pump Shaft
Post by: Laitch on May 03, 2020, 08:07:01 AM
Heat up the shaft with a heat gun or hair dryer. Soak the shaft in Liquid Wrench, Kroll, PB Blaster or another rust penetrant. WD40 isn't as effective. Wait ten or 20 minutes then go after it with a dead blow mallet with the nut or bolt fastened on the shaft, or with the hammer and a hardwood block as you did previously.
Post by: volador on May 03, 2020, 11:26:50 AM
this ought be fecking good an aussie with a BFH...
you got a part number for that replacement shaft or you working at the Trades Guild?
