TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: cbelawn on April 12, 2020, 04:34:00 PM
Title: K 1100 brake grab but will not stop at low speed.
Post by: cbelawn on April 12, 2020, 04:34:00 PM
I start diwn my driveway and end up in the road because I pull on the brake lever and it feels like it's catching on something and will not engage the brake. It took out the brake actuator pin and Lube that up has not seen to help. Only a low low speed does this occur. Anyone have any advice?
Title: Re: K 1100 brake grab but will not stop at low speed.
Post by: johnny on April 12, 2020, 05:12:27 PM
have you done a full bleed where you have good lever and pedal..
does this moto have oe rubber brake hoses or stainless brake lines...
how much meat is on the padds...
when did the brakes work properly... what has been done to this moto since then...
generally downhill driveway id be on the back brakes until i came to full stop... then hold it with the front as i wheelied onto the road...
poast up some photos of this moto...
Post by: cbelawn on April 12, 2020, 06:12:35 PM
New pads, worked in the fall,sat all winter,I did bleed brakes at caliper. Rubber horses
Post by: cbelawn on April 12, 2020, 06:16:51 PM
Good pedal and stops goog at higher speed
Post by: K1300S on April 12, 2020, 06:22:34 PM
How old are the rubber hoses?  If original, bet that is the problem.
Post by: johnny on April 12, 2020, 06:50:04 PM
how long have you had this moto...
so.... the problem is front brakes because you said lever in your 1st post...
so... if you are rolling 50mph and pull the brake lever hard does the abs engage...
so... i asked for photos... now is the time to post them here...
Post by: cbelawn on April 18, 2020, 02:12:10 PM
Abs works
The leaver acts like its hitting a stop. Not like a fluid problom owned this for 2 years  [ Invalid Attachment ]
Post by: cbelawn on April 18, 2020, 02:13:48 PM
Been snowing here
