TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Martin on March 29, 2020, 07:34:50 PM
Title: Instrument pod reassembly. Corona project 1
Post by: Martin on March 29, 2020, 07:34:50 PM
Amongst my recent K75s panel and bits was this. Although disassembled it looks in good condition and worth putting a bit of effort into. I'll either get it back together or go mad trying.
Title: Re: Instrument pod reassembly. Corona project 1
Post by: natalena on March 29, 2020, 08:01:04 PM
Looks like a great project. Here in the states, it'd be a good chance to reset the odometer and turn the speedometer pot so it reads "mph" more accurately. The lenses look fantastic.
Post by: The Mighty Gryphon on March 29, 2020, 08:37:54 PM
Martin, thanks for reminding me that the "new" K100RS cluster has a loose bulb in it that is blinking.  It will be a good project for the incarceration.
Post by: Martin on March 29, 2020, 09:29:47 PM
I was making progress until I found that I seem to be missing a circuit board. I'm using an early set of instruments as a reference which is different. Mine appears to never have had the larger board which is attached to the speedo face. I don't know whether I can remove the circuits from the early board to make it work. The early one has a red light next to the 4L fuel light with a small silver label with Japanese characters on it, a red and yellow wire goes from the light to the larger circuit board. Three wires black blue and red go from this board to the board that is missing.
Post by: volador on March 29, 2020, 11:41:49 PM
* Instrument missing circuit 1.png (55.22 kB . 768x576 - viewed 1493 times)
* Instrument red warning light.png (41.17 kB . 768x576 - viewed 1489 times)
Looks like another Alli-babba special nothing these Chi-coms won't counterfeit
Post by: Martin on March 30, 2020, 12:00:34 AM
I think the red warning light might be a speed warning light unique to Japan. I wish I could read Japanese. As such I could probably remove the circuit board that I want from the early speedo. However I am reluctant to do so because I have never seen this light fitted before and I would rather keep it as an early working speedo. I also have a couple of mates with early Bricks who might require it one day. If anyone has a wrecked speedo and is willing to part with the required circuit please contact me. At this stage the speedo is back together awaiting the circuit. I wound it forward to match mine then realised I should have left it on it's original mileage. I'll rectify that later.
Post by: volador on March 30, 2020, 12:17:31 AM
I think the red warning light might be a speed warning light unique to Japan. I wish I could read Japanese...
characters read 'LIDAR Detector Bluetooth compatible Android Apple iPhone'
Post by: Martin on March 30, 2020, 12:29:09 AM
Good try Vol the first two characters represent the word speed the next two characters represent alert. Still working on the fifth.
Post by: natalena on March 30, 2020, 07:48:42 AM
Tategaki, Vol-chan, are you reading right to left? ;)
Post by: volador on March 30, 2020, 08:50:18 AM
Yokogaki, Nata-chan, left to right ;)
Post by: johnny on March 30, 2020, 09:00:35 AM
this my ongoing corona project one...
Post by: Skunky on March 30, 2020, 04:13:58 PM
Post by: Martin on March 30, 2020, 04:42:12 PM
Thanks Skunky that's close to what I got. The first two characters translated as speed the second two characters translated as alert. I haven't bothered with number five.
Post by: Skunky on March 30, 2020, 05:22:58 PM
And 'Slow down you twat!' looks completely different
Post by: TommyT on March 31, 2020, 07:48:45 AM
* Speedo Reconditioned 1.jpg (40.68 kB . 768x576 - viewed 1543 times)
During rebuild did you notice how the knob for trip odometer is attached to the rod that turns that meter? I ask because I have an pod that is missing that knob and I am wondering how I will fix that problem.
Post by: Martin on March 31, 2020, 04:09:33 PM
Tommy to remove it just give it a firm pull. To install it fit it in the hole and push. The knob should look like the picture. I some rare cases you might end up with just the black plastic piece. In that case I think you may be able to remove the back and reassemble the knob.
Post by: TommyT on March 31, 2020, 07:59:55 PM
* Odometer Knob.png (43.72 kB . 768x576 - viewed 1447 times)
Thank you for the tip and picture. Now I have to find an used knob to replace my missing one.
