MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: sr20clubbie on March 21, 2020, 09:46:43 PM
Motogadget m unit basic, brand new only just bought a week ago. Due to my lack of knowledge I have decided not to go the cafe racer build and am now selling some of the items I purchased for the build.
$430 aus dollars plus p&h. Located in Australia .
[ Invalid Attachment ] The new m.unit basic without Bluetooth® LE has moved on from the established m.unit v.2 by undergoing significant development and improvements. It is now equipped with 12 inputs, 10 outputs and replaceable high-quality cable clamps. It offers the same features like the m.unit blue but without Bluetooth® LE und connectivity to the m.ride app.
The m.unit basic is the digital control unit for your motorbike – the heart of the entire on-board electrical system. It can be operated using buttons or using conventional handlebar switches. It controls all necessary components on the vehicle while also performing fuse functions.
There are considerably fewer relays and individual components in the wiring harness and the vehicle can be rewired with less effort in a very short amount of time.
When using the m.button (sold separately), all switch connections are reduced to one single cable.
Features
Complete digital control using buttons possible with 4 or 5-button operation. Also latching switches possible.
Complete replacement for the fuse box. 10 independent circuits are digitally monitored and switched off if there are faults. After the fault is rectified, the safety function is automatically reset.
Integrated alarm system that can be installed in any position.
Integrated, digital flasher relay that is load-independent; automatic switch-off optional and can be set; m.wave mode can be selected.
Integrated hazard warning light.
Turn signal can optionally be set as a positioning light.
Integrated parking light and headlight flashing.
Lo-beam and Hi-beam (up to 200 W switched capacity) can be controlled using only one button.
Integrated, digital brake light modulator; flashing mode can be programmed.
Acceleration-controlled emergency brake light (automatic warning signal).
Integrated starter relay for the starter system with solenoid (up to 30 A switched capacity).
Intelligent and configurable management/switch-off of power consuming devices so that the maximum starting energy from the battery can be used when starting the motorbike.
Integrated, digital horn relay.
Two configurable additional outputs AUX1 and AUX2.
Diagnostics function for assigning inputs, outputs, the circuit switching status, short circuit diagnostics etc.
Calibration and current measurement enables faults to be detected on all lamps.
Package Contents
m.unit basic
Approx. 50 cm connecting cable for battery positive terminal with 10 mm˛ cross section
2 cable eyes
1 x M5 stainless steel bolt
2 x M5 stainless steel bolts with nut
1 x speed sensor with 2 magnets
Detailed installation and operating instructions
Specifications
L/W/H: 90 x 53 x 30 mm, bolt distance 74 mm
Weight: approx. 180 g
Fasteners: 2 x M5 stainless steel bolts (installation and ground connection), 1 x M5 screwing contact for battery Plus
Operating voltage: 6 V - 20 V
Operating temperature: -20°... +80°C
Inputs
1 x input (+12 V switched) for ignition lock or m.lock
11 x control input (minus/switched to ground) for:
Left turn signal
Right turn signal
Lo/Hi-beam
Starter
Horn
Brakelight
Kill bmp switch
Stand switch
LIN bus
AUX1
AUX2
Sold
