TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: sembrando on February 29, 2020, 04:08:17 PM
Title: Instrument Panel Swap Double Check
Post by: sembrando on February 29, 2020, 04:08:17 PM
Sorry to keep taking over the board...but not sorry enough, I guess. My instrument cluster is whack, but I've been running on tach only for the past few years. Found a decent replacement on Ebay (cracked front plastic, but better than mine) for a decent price (maybe one of you is the 1 current bidder...).
Before I bite, any issues I'm not foreseeing? All the mounts look fine to me.
My instrument panel:
Ebay (https://www.ebay.com/itm/BMW-K100RT-Instrument-Cluster-K75-K100-K100RS-Cracked-Glass-D991/333525029570?hash=item4da7a412c2:g:p1oAAOSwL29eUxKg):
Title: Re: Instrument Panel Swap Double Check
Post by: Laitch on February 29, 2020, 04:13:54 PM
You're every vendor's dream buyer.  :laughing4-giggles:
Post by: volador on February 29, 2020, 04:21:12 PM
Flat pins vs round pins connector
Post by: Laitch on February 29, 2020, 04:34:28 PM
The crack in that Motometer lens has probably allowed moisture to infiltrate its guts and create corrosion. I think you can find one in better condition, especially when considering many of these are being removed during cafe racer projects. Determine whether your cluster has round pin or square pin connectors at the back. Although mating up the differing connectors has been done successfully by some owners, having round-to-round or square-to-square connection is desirable.
Post by: sembrando on February 29, 2020, 04:41:58 PM
Thanks, that’s why I hang around here. Keeps me from doing stupid stuff... 112350
Post by: teuski on March 05, 2020, 02:48:22 AM
I replaced my '84 K100 original unit with a newer one with differently shaped pins. The connectors fit good and it works.
Only thing that doesn't work are the fuel lights. They sometimes light up without any logic. As far as i know the sender in the pump unit is different in older models.
Post by: Laitch on March 05, 2020, 06:12:39 AM
If you haven't purchased one already, try to get one that has Goretex ports on the rear panel. These were installed in later models to minimize condensation within the works, but you can install some yourself if necessary. As teuski has already indicated, it's possible that pins and sockets of differing profiles can be mated and function ok.
(http://www.motobrick.com/gallery/2/1601-050320072108.jpeg)
Post by: sembrando on March 05, 2020, 10:09:05 AM
Awesome, thanks for the "pro tip." I'll be keeping my eyes peeled.
