MOTOBRICK.COM => Welcome To Motobrick.Com => Topic started by: koshak on February 17, 2020, 05:22:21 AM
Title: K75 in Cyprus
Post by: koshak on February 17, 2020, 05:22:21 AM
Hello
Last week picked up from the port  BMW K75, sipped overseas from Latvija.
New to bricks.
(https://i.postimg.cc/qvFtBV91/19.jpg)
Cannot find correct spare parts catalogue, as confused with model.
Running vin check, it says K75 85 (0562, 0571) 10/1989
But catalogue gives different models.
Need to find part number of my windshield, as it is broken and should be replaced.
Title: Re: K75 in Cyprus
Post by: koshak on February 17, 2020, 05:30:51 AM
It has round headlight
(http://www.motobrick.com/gallery/2/6834-170220052910.jpeg)
(http://www.motobrick.com/gallery/2/6834-170220052853.jpeg)
Post by: volador on February 17, 2020, 08:07:38 AM
Welcome
At quick glance looks like K75 S with K100 RS fairing and custom headlight fixture
https://parts.maxbmw.com/a/BMW_1989_K100RS/_57201_5830289/PAINTED-PARTS-608-AVUSSCHWARZ/51_0004.html (https://parts.maxbmw.com/a/BMW_1989_K100RS/_57201_5830289/PAINTED-PARTS-608-AVUSSCHWARZ/51_0004.html)
(https://parts.maxbmw.com/images/parts/BMW/fullsize/7017.jpg)
https://shop.maxbmw.com/fiche/PartsSearch.aspx (https://shop.maxbmw.com/fiche/PartsSearch.aspx)
https://parts.maxbmw.com/BMW___BmwMotorradK.html (https://parts.maxbmw.com/BMW___BmwMotorradK.html)
https://shop.maxbmw.com/fiche/PartsFiche.aspx (https://shop.maxbmw.com/fiche/PartsFiche.aspx)
https://www.realoem.com/bmw/select.do?kind=M&arch=1 (https://www.realoem.com/bmw/select.do?kind=M&arch=1)
https://www.bobsbmw.com/store/microfiche/BrowseSeries.aspx (https://www.bobsbmw.com/store/microfiche/BrowseSeries.aspx)
Post by: Laitch on February 17, 2020, 09:27:44 AM
Welcome!
As has already been indicated, your moto has mixed parts. The fairing is from a K100RS. The round headlight might be from a K75C or it might be custom. The handlebar has been mounted on a riser instead of using the stock mounts. The seat is a low-seat model. The side cases are late models so they have the largest capacity of all cases that were offered. The fuel tank has custom paint striping.
You should probably order engine, brake, and electrical parts based on the 1988 date. Take the screws off the fuel tank cover assembly, remove it, empty the fuel tank and inspect the tank's interior for sludge.
Thanks for posting photos. Take one of the handlebar setup from behind it with good lighting so we can see what type of dash pad it has.
Post by: koshak on February 17, 2020, 09:50:32 AM
(http://www.motobrick.com/gallery/2/6834-170220094935.jpeg)
Post by: billday on February 17, 2020, 09:56:18 AM
Whoa, where's the rest of your motorcycle?
Post by: koshak on February 17, 2020, 10:12:23 AM
stripped for inspection and cleaning.
frame did outside, engine is inside my cave.
(http://www.motobrick.com/gallery/2/6834-170220101041.jpeg)
Bike was sitting without move for 15 years.
Post by: billday on February 17, 2020, 10:20:47 AM
Cool, this looks like an interesting project. Welcome to Motobrick and keep putting up pictures!
PS It's best not to let the swingarm hang down like that, you'll tear the rubber boot (assuming it's any good after sitting for 15 years).
Post by: volador on February 18, 2020, 01:04:11 AM
'C' type handlebar and dash pad
Quite the mix
Post by: The Mighty Gryphon on February 18, 2020, 08:14:10 AM
Nice looking bike.  A former member here "Duck" built a K75RS with, I think, a turbo.  It was a really good looking bike.  I have an RS fairing here that I would like to put on my K75RT.  Your photos are giving me the itch to do it.
Have you put your frame number into the system at RealOem?  That is a good place to find the correct parts for the engine and drive train.  Your fairing is based on a K100RS.  Parts for those didn't change much over the years.
https://www.realoem.com/bmw/enUS/select?product=M&archive=1
I like the round headlight.  Whoever put that together did a nice job of fitting it.  I hope you can post a bunch of photos showing how it was built.  As far as the windscreen, it looks like it is a custom.  There are some aftermarket screens that might be able to work with a bit of rework.  Aeroflow looks pretty close to what you have.
http://aeroflowscreens.com/K100_1100RS/K100RS_K1100RS.htm
You have a really nice project there.  Good luck with your restoration, you are in the right place for information.
Post by: koshak on February 19, 2020, 03:40:20 AM
It says K75 85 (0562, 0571) 10/1989 european
Post by: koshak on February 19, 2020, 10:35:31 AM
to be continued here (http://www.motobrick.com/index.php/topic,13326.0.html)
 :welcome
Post by: volador on February 21, 2020, 02:14:55 PM
Some links for your K journey
Check parts compatibility with BMW MAX Microfiche, BOBS BMW, REAL OEM
https://www.ascycles.com/BMW-Motorcycle-Parts-Fiche
Cross reference parts like Bosch pn#'s, etc....  http://partsplusecat.com/
No spaces in the part number
Parts Vendors
https://www.beemerboneyard.com/
https://www.capitalcycle.com/
https://www.euromotoelectrics.com/
https://www.tills.de/
Headlight relay stuff if you chose to add one
https://www.motobrick.com/index.php?topic=268.0
http://www.motobrick.com/index.php/topic,4962.msg30932.html
http://culayer.com/product/matchbox-headlight-relay/
http://easternbeaver.com/Main/Wiring_Kits/H4_Kits/h4_kits.html
 Eastern Beaver site is a great reference for electrical connectors,plugs, etc...
http://www.k100-forum.com/ (http://www.k100-forum.com/)
http://www.kforum-tech.com/Tech-page.html
http://www.kforum-tech.com/electrical/EFI/bike-wont-start-EN.htm
http://www.kforum-tech.com/Downloads/electrical/diagrams/interactive_diagrams.htm
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k100tshoot/K100.Troubleshoot.Start.2018.pdf (http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k100tshoot/K100.Troubleshoot.Start.2018.pdf)
http://kbikeparts.com/index.htm
http://www.kbikeparts.com/classickbikes.com/ckb.tech/ckb.new2k.htm
http://www.kbikeparts.com/classickbikes.com/ckb.tech/ckb.tech.toc.htm
http://www.eilenberger.net/K75S/IgnitionSwitch/
http://www.verrill.com/moto/moto.shtml
this site has a lot of good info and breakdown pictures in the tech and tech resources sections for K1100 alot of the parts are on K75 & K100
http://www.k11og.org/forum/index.php?sid=2df953dde5715fd9001fbe69edec5ad0
https://ibmwr.org/index.php/k-bike-tech-articles/
This site has all kinds of technical specifications on all the BMW models    http://www.bmbikes.co.uk/mechanicalpages/kseriesmechanical.htm
http://largiader.com
