TECHNICAL DIRECTORY ~ MOTOBRICK SHOP MANUAL => Service Bulletins ~ Brochures => Topic started by: volador on December 19, 2019, 04:44:44 PM
Title: K1 K100 4V FUEL SUPPLY & ADJUSTMENTS SB 13 023 91 2475 Sept 1991
Post by: volador on December 19, 2019, 04:44:44 PM
* 2475.pdf (519.84 kB - downloaded 2365 times)
Title: Re: K1/K1004V Fuel Supply & Adjustments —SB 13 023 91 2475 September 1991
Post by: The Mighty Gryphon on December 19, 2019, 08:31:41 PM
There's no need for a KTE201 to set the TPS.
1. With the ignition OFF, connect pin #3 of the diagnostic plug to ground.
2. Turn on the ignition.
3. If it isn't lit, loosen the mounting screws and adjust the TPS so the temperature warning lamp on the instrument  cluster lights up.
4. Tighten the TPS mounting screws and rotate the throttle.  The temperature light should go out as soon as the throttle is moved off the idle position.
Post by: volador on December 20, 2019, 11:06:31 AM
Throttle Position Sensor (TPS) Test:
To test the TPS
Ignition OFF, Ground Pin #3 and monitor Pin #1 with a 12V LED (+lead to Battery + and -lead to Pin#1).
Ignition ON, Engine OFF (Pin #3 should remain grounded during this test)
The Test LED will be ON at idle (closed throttle) and OFF just above idle. You should also be able to watch the temperature warning lamp on the tachometer blink ON at idle and OFF just above idle.
Pin #1 should be Low at idle and High just above idle. In other words, if you are measuring from ground to Pin #1 with a voltmeter, Idle should be close to 0 Volts and just above Idle should be close to 12 Volts. (This test also works for Oilheads (1994-2001) with Motronic 2.2 Engine control Units but since there is no temperature warning lamp, you must use either a voltmeter or a Test LED as described above).
NOTE: Measuring the voltage between pins 1 and 4 at the TPS connector should indicate
0.375 Volts at the idle setting (closed throttle) with ignition ON engine OFF.
Snap the throttle open/closed a few times to ensure a consistent reading. To adjust the TPS, loosen the two screws slightly and rotate the TPS until the temperature warning lamp (or the Test LED) 'just' comes ON at idle and goes OFF just above idle. If you are using a voltmeter, adjust the voltage to 0.375 at idle (closed throttle). This voltage MUST remain below 0.400 Volts at idle.
http://www.k11og.org/forum/viewtopic.php?t=2110&start=0&postdays=0&postorder=asc&highlight= (http://www.k11og.org/forum/viewtopic.php?t=2110&start=0&postdays=0&postorder=asc&highlight=)
http://www.largiader.com/articles/motronic.html (http://www.largiader.com/articles/motronic.html)
Post by: The Mighty Gryphon on December 20, 2019, 12:45:13 PM
You don't need the LED to set the TPS.
Post by: Filmcamera on December 20, 2019, 06:05:24 PM
Very useful test procedure, thanks.
I did it today and my TPS was slightly off so I adjusted it. It is  a piece of cake to do.
I have not had a chance to go for a test ride yet but will report back when I do.
Thanks again.
Post by: TommyT on December 20, 2019, 07:59:50 PM
I also tried this on my 1991 K100RS 16V, the light when off as soon as I slightly turned the throttle.
Post by: The Mighty Gryphon on December 20, 2019, 11:37:56 PM
That's what it's supposed to do.  Sounds like you got it right.
Post by: TommyT on July 06, 2020, 10:11:37 AM
Well I tried this on my other 1991 K100RS I have. It a bike I picked up that had sat for many years. I got it running and I have put about 200 miles on it. Starts well but I noticed some surging at 3000 to 4000 at light to part throttle. Full throttle feels great. I just tried the TPS test and I get no light on the temp warning light. I twist the throttle and nothing. I pull the ground wire and the light comes on. I tied cleaning the TPS connector and do the test again but no light. I loosen the screws and turn the TPS but still no light. If I do ot while the bike is running it does change the idle.
Do I have bad TPS?
Title: Re: K1 K100 4V FUEL SUPPLY & ADJUSTMENTS SB 13 023 91 2475 Sept 1991
Post by: Laitch on July 06, 2020, 10:37:51 AM
Do I have bad TPS?
One way to find out for yourself is to remove the switch from the other moto and substitute it for the suspected problem child.
Post by: Dan87 on December 16, 2020, 01:43:10 PM
I know this is an older thread but I was going to mark it for future reference when I noticed the SB is for 16V K100. Does this also apply to the 4V K100's?
Post by: Laitch on December 16, 2020, 02:40:24 PM
. . . I noticed the SB is for 16V K100. Does this also apply to the 4V K100's?
16V refers to the total number of valves per engine, 4V applies to the number of valves per cylinder; the terms apply to the same type of engine. The SB applies only to those engines. Your moto, Dan, has a 2V engine. The K75/K100 2V models have a different type of switch. Instructions for setting that switch can be found in the BMW K75/K100 2V Manual downloadable from this site, and in various threads in the Workshop.
Post by: Dan87 on December 16, 2020, 04:48:17 PM
Thanks Laitch, I was thinking I had a 4V engine. Goes to show you how little I know about these bikes. I have 20 years experience with Goldwings and very little on the BMW's, I'm enjoying the learning curve. I'll take a look for that manual.
