TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: schrocketeer on November 16, 2019, 01:41:07 AM
Title: odometer set screw gap?
Post by: schrocketeer on November 16, 2019, 01:41:07 AM
Would you please help me with the gap for the set screw that presses up against the shaft that holds the odometer gears? It's the white nylon screw that touches up against the the steel shaft with the odometer's gears. In the attached picture there is a red circle around the area.
In my last adventure going in this deep, I didn't pay attention to the gap. When my odometer hit 61,999 miles, it got stuck and would not roll over. This also kept the trip meter from functioning.
Before I put it back together, I'd like to go on more than a guess for the gap.
Thanks.
Title: Re: odometer set screw gap?
Post by: Laitch on November 16, 2019, 11:59:13 AM
I haven't found a gap measurement yet. What I've found is that screws are likely too loose according to this source (http://www.kforum-tech.com/electrical/speedo-repair/speedo-repair.htm). Read the first and second sections. Right now, you might be consigned to trial-and-error.
Post by: Chaos on November 16, 2019, 03:14:13 PM
Looking at my spare I picked up for the gears, that screw is missing.  Can't see what it was for in the first place since the odometer wheel shaft seems pretty well located.  I wonder if it was the cause of your malfunction or a red herring.
Post by: The Mighty Gryphon on November 16, 2019, 04:08:52 PM
I have been inside several speedometers in the past couple years and have never seen the set screw you speak of.  Perhaps it was only used in the early model instrument clusters.
Post by: schrocketeer on November 19, 2019, 09:14:42 PM
Ricardo Palao helped me, suggesting a gap of 2mm, on the FaceBook group "BMW-K  motorcycles K1 k75  k100  k1100 (purists)". I've put around 250 miles on it since reassembling with that tolerance, and it's working great.
