MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: ffbikersa on November 02, 2019, 01:07:52 PM
Title: FS: Multivario Tank Bag K75, K100, K1100, K1
Post by: ffbikersa on November 02, 2019, 01:07:52 PM
Selling BMW tank bag Multivario, fits with the corresponding base plate on many BMW motorcycles:
R65, R 65 RT, R 65 GS, R 80, R 80 RT, R 80 G / S, R 80 ST, R 100, R 100 RS, R 100 RT, K75, K75 C, K75 S, K75 RT, K100, K100 RS , K100 RT, K100 LT, K1100 RS, K1100 LT, K1 - one picture shows it on my K1100 RS
including volume enlargement parts, all zips OK
https://www.ebay.com/itm/264519621938 (https://www.ebay.com/itm/264519621938)
Title: Re: FS: Multivario Tank Bag K75, K100, K1100, K1
Post by: bocutter Ed on November 02, 2019, 02:31:26 PM
Which base is with it?
Post by: johnny on November 02, 2019, 03:12:00 PM
bocutter ed has legit question..
the base is not proper k1100 oe fittment...
* not proper.png (46.75 kB . 768x430 - viewed 3833 times)
Post by: volador on November 02, 2019, 03:41:35 PM
True to its OE Multivariable fits 22 motos
Fine looking piece of equipment
GLWS
Post by: Scott_ on November 03, 2019, 07:15:49 AM
I used to have one of those older bags, they were not intended to fit the 1100's or K1's as they use the wire loop type attachment along the gas tank seam. The side straps also have more of a straight downward angle to them, unlike the newer series that is more swept back towards the rear 1/3 of the fuel tank.
They will fit if you can manage enough free space between the side cover and the fuel tank.
The base should be stamped with what series they fit. My old one was stamped K75/K100. The stamping should be visible if the bag us unzipped from the base.
Post by: ffbikersa on November 05, 2019, 04:21:07 AM
This base did not have anything stamped (that could be seen on the ebay add pics).
From what I could figure out in BMW OEM catalogue, it would be 71602340658
Anyway, it got sold to Germany.
Now I ordered another bag made specifically for use with K1100 and hooks one has to install
(https://i.ebayimg.com/images/g/X1UAAOSw2npdbm~4/s-l1600.jpg)
(https://i.servimg.com/u/f11/18/79/83/02/side_b11.jpg)
Post by: Scott_ on November 05, 2019, 06:57:27 AM
That is the correct bag for the 1100's..... in fact, that 2nd picture is one I took of the clips on my '97.
Post by: alabrew on November 05, 2019, 05:39:44 PM
The elastic on my k100 bag (like the yellow trimmed one) is showing age. Anyone replace it? Difficult?
Post by: stokester on November 05, 2019, 06:59:24 PM
I had the same issue with my airhead Multivario bag and had the elastic replaced at a leather repair shop.  I see no reason a decent shoe repair shop could not do it as they would also have the heavy-duty sewing machines.
Post by: mdk_mdk on November 05, 2019, 08:08:49 PM
I repaired mine using 2" Underwear & Pajama elastic from Michael's Craft Store. I opened up some stitches with a stitch cutter, cut out the old elastic, glued in the new elastic and then restitched by hand through the existing holes in the leather. Came out great, holds well. I would recommend safety pinning the elastic to the strap and checking the fit first, I had to shorten up the straps more than I thought to get a fit where the elastic was slightly stretched instead of slack.
Post by: mdk_mdk on November 05, 2019, 08:09:50 PM
If you can't find the elastic, let me know, I have 1.9 yds left over!
Post by: ffbikersa on November 06, 2019, 12:17:59 AM
I have the same issue with elastic on my new bag. Planned to have it fixed now during the winter.
Post by: Scott_ on November 06, 2019, 06:58:59 AM
I've replaced the elastic on mine as well a couple of years ago. Like others, I just cut the stitching and put new elastic in then sewed it back together.
I wasn't able to find any 2" wide elastic, best I could find was 1-1/2" wide. It fits, though it's not as snug as the original.
Post by: alabrew on November 06, 2019, 02:36:59 PM
Thanks for the replies. I was sorry for highjacking a thread, butI think it worked out well.
Thanks for the offer mdk_mdk, buttts yous gotts to use black, like zip ties. =-}
Post by: BrickDad on November 06, 2019, 07:00:13 PM
.... yous gotts to use black, like zip ties. =-}
That's what black permanent markers with a wide chisel tip are for  ;-)
Post by: ffbikersa on November 07, 2019, 01:48:12 AM
I've just ordered black 4.5cm wide (1.77"), 3 meters length, from eBay - that fits exactly for my base plate:
https://www.ebay.co.uk/itm/White-Black-Flat-Elastic-Band-Lingerie-Ribbon-Trim-DIY-Sewing-Dress-Making/273986223671 (https://www.ebay.co.uk/itm/White-Black-Flat-Elastic-Band-Lingerie-Ribbon-Trim-DIY-Sewing-Dress-Making/273986223671)
Just search for the "elastic band" in ebay.co.uk's "Crafts" section, or for "gummiband" in ebay.de's, and choose "Item location: worldwide" option
Post by: Laitch on November 07, 2019, 07:47:44 AM
This stuff is perfect for suspenders, too. (https://www.seattlefabrics.com/2-Heavy-Weight-Elastic-200-yard_p_264.html)     Some of this is sublimated creativity (https://www.strapworks.com/Elastic_s/63.htm) which can be your personal secret once installed. 2" available.
Post by: mdk_mdk on November 07, 2019, 09:06:02 AM
They make black zip ties....????
I've always used these:
Post by: ffbikersa on November 07, 2019, 02:52:30 PM
Zip ties? What these have to do with elastic bands on tank bag base plates???
Post by: volador on November 07, 2019, 05:04:44 PM
(http://www.motobrick.com/index.php?action=dlattach;topic=13067.0;attach=77595;image)
A man after my own heart
