TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Gr-Racing on September 23, 2019, 11:03:22 AM
Title: Venhill Clutch and Gas Cable Kit?
Post by: Gr-Racing on September 23, 2019, 11:03:22 AM
hi I need new clutch and gas cable for my new controls I just order the venhill kits.. any tips?
thanks
Title: Re: Venhill Clutch and Gas Cable Kit?
Post by: volador on September 23, 2019, 12:19:02 PM
Lube the nipples
Post by: Martin on September 23, 2019, 03:41:29 PM
Check the lever for excess wear. Fit a grease nipple to the clutch arm.
Post by: volador on September 23, 2019, 05:32:26 PM
Clutch lever/cable perch related parts to consider:
Clutch lever nylon sleeve bushing 32721451796
Clutch lever nipple holder 32721233550
Felt Ring (may or may not be included with OE cable): feltring 32721231610
Felt Ring slides into the cable adjuster, shaped more like a very small dowel then a ring
Clutch cable adjustment procedure
https://www.youtube.com/watch?v=gBW4D2jDw2A
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/clutchadjust/clutchadjust.htm
Curing sloppy clutch and brake levers (http://www.motobrick.com/index.php?topic=3053.0)
Post by: volador on September 23, 2019, 05:49:39 PM
Throttle twist grip tube and cam disc have alignment marks
New and improved cam disc 32721457036 requires cover 32721457037
Throttle Adjust http://www.bmw-k100rt-page.eu/manual/FuelOil/18_FuelLub.htm
(http://www.motobrick.com/index.php?action=dlattach;topic=10155.0;attach=52473;image)
as per Inge:
The throttle cable have been changed two times...first version have a adjustement sleeve ~halfway length,
second version have a black plastic collar at the lower end...third version have a white plastic collar.
All inner cables have different length and a different lower bracket.....which can't be mixed.
Post by: stokester on September 23, 2019, 08:42:11 PM
I found the Venhill clutch cable to be a bit thicker than the OEM but it fit and works fine.
Be sure to clean and lube the clutch lever barrel during installation and regularly after that.
