TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Classic Motobricks => Topic started by: Rcgreaves on September 22, 2019, 01:28:27 PM
So my lower tragkorb attach latch lock tumbler spins, and the tumbler mech. If not seated and key in the locked position the tumbler slides right our of the housing.
Ive studied articles but have yet to confirm if there is perhaps a set screw missing on the opposite side?
I've had this happen with two locks. There is no set screw. There are a couple of locksmiths on the forum and maybe they'll be able to explain this better than this fable I have just composed.
The wafer that prevents the lock cylinder from being pulled out of the latch housing seems to be held in position by a spring exerting force on the wafer until it is stopped from being ejected by a shoulder cut into the wafer that bears on a stop within the cylinder. You could look at an attached drawing if I had attached one but this is theoretical only. When the spring loses tension or the shoulder wears off, the wafer gets dislocated and can drop into the cylinder or fall out of the cylinder. That enables the cylinder to be pulled out.
I tried to rehabilitate one once but gave in and bought a six-pack of locks instead, one of which I used for replacement.
Thanks as always Laitch king of Latches today—- 2hrs in my rain gear eastern to SW Wisco and I’ll take a closer look at the tumbler mechanism. Cheers
its the last tang on the core that locks that in there... when they spin and come out like that the last tang may have fallen out or the ting spring that pops it out maybe gunnked up...
i have been successful scoring a used core from michlers for nothing... removing the tang and spring and installing them in my core and all is well... i have also scored a used core and dermeled so my key fitts... always keep your old cores tangs springs...
its all right here... (http://www.motobrick.com/index.php/topic,494.msg79241.html#msg79241)
Thx! I’m out not riding w Johnny. Looking at that R12 S today
