MOTOBRICK MARKETPLACE => NM ~ Not Mine - Just Compeled To Post It Up => Topic started by: volador on September 21, 2019, 04:46:36 PM
Title: 1985 K100RT $800
Post by: volador on September 21, 2019, 04:46:36 PM
Your fall/winter project awaits.
Probably an easy fix.
Good day
(https://images.craigslist.org/00K0K_7JSqXwOkPeL_600x450.jpg)
https://newjersey.craigslist.org/mpo/d/matamoras-bmw-k100rt/6979463846.html
Title: Re: 1985 K100RT $800
Post by: The Mighty Gryphon on September 21, 2019, 09:42:58 PM
1985 with ABS!?
Post by: volador on September 22, 2019, 01:33:20 PM
Finest Year Known
ABS retrofit...
Front forks to mount wheel sensor
Hard brake lines to front actuator
Wiring harness with ABS wiring
ABS actuators with mounting hardware
ABS brake lines front and rear
ABS brain
Front wheel with ABS ring
Rear brake rotor with ABS ring
Late model instrument cluster
Relay box with ABS relays
Pack of PBRs
Easy peasey
Post by: The Mighty Gryphon on September 23, 2019, 09:48:54 AM
Finest Year Known
ABS retrofit...
ABS brain
Pack of PBRs
Easy peasey
If you say so.  Way more expensive than just buying a bike with working ABS.
